[Qgis-user] Please help!
Zoltan Szecsei
zoltans at geograph.co.za
Tue Apr 23 01:04:12 PDT 2024
Oops - yes, quite correct.
Regards,
Zoltan
On 2024/04/23 10:01, Nigel Berjak - S3 Technologies wrote:
> Hi Zoltan
> Apologies, the CRS is ESRI 102567 and not EPSG 102567, for South
> Africa, Lo29° metres projection based upon the North/Easting
> orientation of the data.
> Cheers.
> Regards,
> Nigel Berjak
> S3 Technologies
> Geographic Information Systems & Large Format Printing specialists
> T: +27 33 3423681
> F: +27 86 6721242
> E: nigel at S3.co.za
> Website: http://www.S3.co.za <http://www.S3.co.za>
> Please consider the environment before printing this email.
> On 2024-04-22 10:44, Zoltan Szecsei via QGIS-User wrote:
>> Hi,
>> I'm guessing the '2053' might be wrong.
>> You need to know if your DEM coords are +ve East and North, or +ve
>> West and South
>> If +ve E/N then try EPSG:102567
>> I forget which of the remaining 2 (2053 and 102487) Lo29 codes are
>> left or right handed, but you only have these 3 to try.
>> When your DEM lands in the correct place in South Africa, then worry
>> about re-projecting to UTM35S
>> HTH,
>> Zoltan
>> On 2024/04/22 10:32, Stefan Bogenhofer via QGIS-User wrote:
>>> Good day
>>> I am having some trouble in regards to georeferencing a DEM which I
>>> received. The CRS of the DEM is "EPSG:2053 - Hartebeesthoek94 /
>>> Lo29" but when I reproject the DEM to the desired projection "WGS84
>>> / UTM zone 35S" it puts the DEM somewhere in Egypt although the
>>> correct position where it should be in my study area is located is
>>> in South Africa. I have tried assigning new coordinate systems to
>>> both my project, web image layer and the DEM but it simply does not
>>> want to reference it to the correct position. Any help would be much
>>> appreciated!
>>> Thank you
>>> QGIS-User mailing list
>>> QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> Zoltan Szecsei GPrGISc 0031
>> Director, Geograph (Pty) Ltd.
>> GIS and Photogrammetric Services
>> Cape Town, South Africa.
>> Mobile: +27-83-6004028 (Signal, not WhatsApp)
>> +974-5058-8729
>> +36-20-4808362
>> www.geograph.co.za <http://www.geograph.co.za>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
+974-5058-8729
+36-20-4808362
www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240423/7f8379a1/attachment.htm>
More information about the QGIS-User
