[Qgis-user] Setting configuration of a field in a vector layer
Roland Berger
roland.berger at steinerpartner.com
Fri Aug 2 10:25:18 PDT 2024
Hi Etienne
Thanks. Worked!
Do you know of a good documentation explaining the Philosophie of the
pyQgis API?
I never know which approach I need to take to change/add information:
Working directly on the object, when to use a data provider, when to
call layer.startEditing() / layer.commitChanges() / layer.updateField()
and so on.
Or in other words: From where do you know that I worked on a copy of the
QgsField?
Regards
Roland
On 8/2/24 11:50, Etienne Trimaille wrote:
> Hi,
> You should use the method in QgsVectorLayer, otherwise, you are
> updating a "copy" of the QgsField :
> for field in layer.fields():
> layer.setFieldConfigurationFlag(
> layer.fields().indexFromName(field.name
> <http://field.name>()), Qgis.FieldConfigurationFlag.HideFromWfs, True)
> On GitHub.com, I often search for a piece of code to see existing
> plugin how they deal with a piece of code :
> https://github.com/search?q=FieldConfigurationFlag+language%3APython&type=code&l=Python
> <https://github.com/search?q=FieldConfigurationFlag+language%3APython&type=code&l=Python>
> There is only one script, as this API is quite new, but still nice to
> know for next time.
> Le jeu. 1 août 2024 à 17:09, Roland Berger via QGIS-User
> <qgis-user at lists.osgeo.org> a écrit :
> Hi
> I try to set the configuration for a vector layer with python.
> Below is one of the many ways I tried to do it.
> Now I'm of out of ideas (chatgpt, intellij ai assistent and google as
> well) and would be thankful for a working example.
> Thanks Roland
> Code you can use in a Python Console Editor. First it creates a
> layer to
> use for the test and then tries to set the field configuration.
> # Setup Layer with field
> # Create a vector layer
> layer = QgsVectorLayer("Point?crs=EPSG:4326", "MyLayer", "memory")
> if not layer.isValid():
> print("Failed to create the layer!")
> sys.exit(1)
> # Add fields to the layer
> layer_data_provider = layer.dataProvider()
> layer_data_provider.addAttributes([QgsField("field1",
> QVariant.String)])
> layer.updateFields()
> # Add a feature to the layer
> feature = QgsFeature(layer.fields())
> feature.setGeometry(QgsGeometry.fromPointXY(QgsPointXY(0, 0)))
> feature.setAttribute("field1", "value1")
> layer_data_provider.addFeature(feature)
> layer.updateExtents()
> # Add the layer to the project
> project = QgsProject.instance()
> project.addMapLayer(layer)
> # Try to set field configuration
> config_flags = field.configurationFlags()
> config_flags |= Qgis.FieldConfigurationFlag.HideFromWfs
> field.setConfigurationFlags(config_flags)
> #layer.updateFields()
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
*Steiner & Partner Landschaftsarchitektur GmbH**
*Roland Berger - Geschäftsführer Stv.
Waisenhausstrasse 2
CH-3600 Thun
Mobile: +41 79 709 56 89 <tel:+41%2079%20709%2056%2089>
Tel: +41 33 335 76 53 <tel:+41%2033%20335%2076%2053>
www.steinerpartner.com <http://www.steinerpartner.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240802/202efd6e/attachment.htm>
More information about the QGIS-User
