[Qgis-user] Python code to select polygon at location
Zoltan Szecsei
zoltans at geograph.co.za
Sun Aug 25 06:19:34 PDT 2024
I'm doing my "once a year need to do something in python with QGIS" :-/
Using QGIS 3.38 and PyCharm.
I have a SHP file with 28000 polygons.
Another SHP file with 22000 Points
Both in EPSG:4326
Without using QGIS processing, what is the quickest way to, for each
point 1 by 1, find the underlying polygon and read the attribute field
values of that polygon?
The code snippet below is far too inefficient - but I cannot find code
that selects at XY and benefits from any spatial index on the polygons.
lyr_poly = QgsVectorLayer(polygon_shp, '', 'Ogr') point =
QgsPointXY(lon, lat) request =
QgsFeatureRequest().setFilterRect(lyr_poly.extent()) for
feature in lyr_poly.getFeatures(request): geom =
feature.geometry() if
geom.contains(QgsGeometry.fromPointXY(point)):
lyr_poly.select(feature.id()) print(f"Feature with ID
{feature.id()} is selected.") break
Thanks in advance,
Zoltan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240825/f191c32f/attachment.htm>
More information about the QGIS-User
