[Qgis-user] Get QgsProcessingParameterFeatureSource's parent layer
andre at nammail.net
Tue Dec 3 07:47:22 PST 2024
Dear all,
I have a processing algorithm that names its output based on the input
layer's name, e.g. if buffering a layer called 'powerlines_110kW' with
40m the output layer would be called 'powerlines_110kW+40m'. For the
input I use QgsProcessingParameterFeatureSource (instead of
VectorLayer), so that the "Selected features only" option is available.
My problem is, when "Selected features" is unchecked, I can get the
input layer's name with the 'parameterAsVectorLayer(parameters, 'INPUT',
context).name()' method. However, when "Selected features" is checked,
'parameterAsVectorLayer()' returns None. This makes sense, as I believe
the input becomes wrapped in a QgsProcessingFeatureSourceDefinition. Is
there any way to get the layer's name before the selected features are
extracted/filtered from the selected vector layer (the one given by the
user in the ComboBox)?
Many thanks
André
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241203/add80b72/attachment.htm>
More information about the QGIS-User
