[Qgis-user] Shapefile symbology no longer working when zoom in
Alexandre Neto senhor.neto at gmail.com
Wed Dec 4 09:55:07 PST 2024
Hi. If there is any qml file next to the shapefile, can you remove it and
then load the shapefile again and see if it works?
Alex
A quarta, 4/12/2024, 16:44, Andrew Chapman via QGIS-User <
qgis-user at lists.osgeo.org> escreveu:
> Hi Andrea
> Sorry for the lack of feedback but I've had to put things on hold for a
> while - we've just had a Ukrainian family move in with us and are focused
> on getting them settled in. Bureaucracy is much more difficult to sort out
> than software!
> I got as far as trying 3.34.13 with no improvement. I've give an update
> when I get time to look back it it.
> Kind regards
> Andrew
> -----Original Message-----
> From: Andrea Giudiceandrea [mailto:andreaerdna at libero.it]
> Sent: 04 December 2024 15:00
> To: qgis-user at lists.osgeo.org
> Cc: andrew.chapman at donkagen.co.uk
> Subject: Re: [Qgis-user] Shapefile symbology no longer working when zoom in
> Hi Andrew,
> since I don't see any followups in the thread, I guess you have managed
> to find the root cause of the issue and to fix it.
> If so, may you please let me know what was the root cause of the issue
> and how did you manage to fix it?
> Best regards.
> Andrea
> Il 28/11/2024 20:39, Andrea Giudiceandrea ha scritto:
> > Hi Andrew,
> > are you actually using QGIS 3.34.0 or QGIS 3.40.0? If the former,
> > firstly I suggest you to use QGIS 3.34.12, instead. What is the GDAL/OGR
> > library version used by QGIS on your system?
> >> Andrew Chapman andrew.chapman at donkagen.co.uk
> >> Thu Nov 28 05:38:02 PST 2024
> >> I've tried Vector->Geometry Tools->Check Validity but the problem still
> >> exists
> > The "Check Validity" processing algorithm [1] doesn't fix any issue. You
> > can use it e.g. to export only valid geometries from the affected layer.
> > Does the issue occur also with the "Valid output" layer? Does the issue
> > occur also if you just export the ESRI Shapefile layer to a new ESRI
> > Shapefile layer or to a new GeoPackage layer and use the new layer?
> > In order to try to actually fix invalid geometries, you can use the "Fix
> > geometries" processing algorithm [2].
> >> Thu Nov 28 10:21:40 PST 2024
> >> In the layer properties->source tab if I delete the .shx file the
> >> option Create Spatial Index is grey’d out.  If the .shx file exists
> >> the same button is marked Spatial Index Exists and is again grey’d out.
> > AFAIK the correct way to create or recreate / fix the .shx file is to
> > use the "Repair Shapefile" processing algorithm [3].
> > Anyway an .shx file doesn't actually contain a spatial index. According
> > to "ESRI Shapefile / DBF" page [4], the ESRI Shapefile OGR driver can
> > read and write the non-ESRI quadtree spatial index file (.qix ) and can
> > read the ESRI spatial index file (.sbn / .sbx).
> > What are the extensions of all the affected ESRI Shapefile layer's files?
> > May you please provide the affected ESRI Shapefile layer's files or
> > create an issue report on the QGIS GitHub repository [5] providing the
> > affected layer?
> > Best reagards.
> > Andrea
> > [1]
> https://docs.qgis.org/3.34/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#check-validity
> > [2]
> https://docs.qgis.org/3.34/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#fix-geometries
> > [3]
> https://docs.qgis.org/3.34/en/docs/user_manual/processing_algs/qgis/vectorgeneral.html#repair-shapefile
> > [4]
> https://gdal.org/en/latest/drivers/vector/shapefile.html#spatial-and-attribute-indexing
> > [5] https://github.com/qgis/QGIS/issues
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241204/a8e092b9/attachment-0001.htm>
More information about the QGIS-User mailing list
