[Qgis-user] Help with Composers
Nigel Berjak - General
nigel at s3.co.za
Thu Dec 5 00:17:40 PST 2024
Hi Derek
As per Alex's email, you can input them manually for a project. You may
also be able to export your defined project/global reference scales from
2.x and import them into 3.x.
Good luck.
Regards,
Nigel Berjak
Please consider the environment before printing this email.
On 2024-12-04 21:27, Alexandre Neto via QGIS-User wrote:
> Hi,
> You have a lot to gain from moving into a earlier version of QGIS. The
> GUI changes weren't that drastic, but with much more capability.
> I can't remember if it was in the same place in 2.18, but currently you
> can configure your prefered scales in th global options.
> Settings > Options > Map tools > predefined scales.
> Alex Neto
> A segunda, 2/12/2024, 10:21, DEREK Beddis via QGIS-User
> <qgis-user at lists.osgeo.org> escreveu:
>> Hi,
>> I have been working with QGIS 2.18.28 for the past 5 years, just had
>> to buy a new desktop and when I installed QGIS 2.18, the site
>> recommended me to instal QGIS 3.40 which I did, but unfortunately I
>> couldn't understand it, so went back to QGIS 2.18. But on downloading
>> my info I managed to get the raster project fine, then I opened the
>> New Composer, transferred the map over OK, but when I entered the
>> Composition details that was OK, but then I wanted to change the scale
>> on the "Item Properties" and found a totally different system?
>> I used to be able to put in 50,000 or 25000, now it is a 10 digit
>> number, which makes no sense to me?
>> I am totally lost, tried various things but getting nowhere.
>> I would like scales of 50000 down to 10000, how do I do it Please?
>> Thanks if anyone can help
>> Derek Beddis _______________________________________________
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241205/ffe08df1/attachment.htm>
More information about the QGIS-User
