[Qgis-user] Help with Composers
    Nigel Berjak - General
    nigel at s3.co.za
    Mon Dec  9 23:56:58 PST 2024
Hi Derek
Below are two screenshots of the 2.x and 3.x Map tools, where Predefined
scales can be inputted, either manually or possibly exported from 2.x
and imported into 3.x. Open 2.x. or 3.x and on the main menu, select
Settings, then click Options. On the screen that opens, select Map tools
down the left panel. To the right of predefined scales you will find the
Save button. Save the XML file and then, on 3.x, following the same
process, try load the XML file saved.
2.x
3.x
Regards,
Nigel Berjak
Please consider the environment before printing this email.
On 2024-12-09 11:50, DEREK Beddis wrote:
> Hi Both
> Sorry, I am not very Tech savvy.
> Alex, I tried opening the Settings on both the QGIS and the project
> page and putting in 50000 on the scale bit, but unfortunately there was
> no difference on the "item properties" on the project bit?
> Nigel, I do not understand where I find the project/global reference
> scales, therefore have no idea (2,x and import into 3.x), sorry
> I am utterly lost on this.
> Please help with basic pointers?
> Thanks for trying
> Derek Beddis
> From: Nigel Berjak - General <nigel at s3.co.za>
> Sent: 05 December 2024 08:17
> To: DEREK Beddis <derek_beddis at hotmail.com>
> Cc: QGIS-user at lists.osgeo.org <QGIS-user at lists.osgeo.org>; Alexandre
> Neto <senhor.neto at gmail.com>
> Subject: Re: [Qgis-user] Help with Composers
> Hi Derek
> As per Alex's email, you can input them manually for a project. You may
> also be able to export your defined project/global reference scales
> from 2.x and import them into 3.x.
> Good luck.
> Regards,
> Nigel Berjak
> On 2024-12-04 21:27, Alexandre Neto via QGIS-User wrote:
> Hi,
> You have a lot to gain from moving into a earlier version of QGIS. The
> GUI changes weren't that drastic, but with much more capability.
> I can't remember if it was in the same place in 2.18, but currently you
> can configure your prefered scales in th global options.
> Settings > Options > Map tools > predefined scales.
> Alex Neto
> A segunda, 2/12/2024, 10:21, DEREK Beddis via QGIS-User
> <qgis-user at lists.osgeo.org> escreveu:
> Hi,
> I have been working with QGIS 2.18.28 for the past 5 years, just had to
> buy a new desktop and when I installed QGIS 2.18, the site recommended
> me to instal QGIS 3.40 which I did, but unfortunately I couldn't
> understand it, so went back to QGIS 2.18. But on downloading my info I
> managed to get the raster project fine, then I opened the New Composer,
> transferred the map over OK, but when I entered the Composition details
> that was OK, but then I wanted to change the scale on the "Item
> Properties" and found a totally different system?
> I used to be able to put in 50,000 or 25000, now it is a 10 digit
> number, which makes no sense to me?
> I am totally lost, tried various things but getting nowhere.
> I would like scales of 50000 down to 10000, how do I do it Please?
> Thanks if anyone can help
> Derek Beddis _______________________________________________
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user [1]
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user [1]
Links:
[1] https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241210/f74df744/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241210/f74df744/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241210/f74df744/attachment-0003.png>
More information about the QGIS-User
