[Qgis-user] QGIS installer options
Paul Wittle paul.wittle at dorsetcouncil.gov.uk
Wed Dec 11 12:11:57 PST 2024
I notice that the proj library has become pretty big in recent times and I've discovered that if I remove a bunch of worldwide projections are I can significantly reduce the size of QGIS installs.
Whilst I understand that supporting a huge range of projections is an amazing feature of the QGIS, I suspect there might be others who may also want to occasionally tailor their download to a particular region or set of regions.
Would it be possible to have an option in the OSGeo4W installer to download a smaller geographical region?
Perhaps that might be something like:
  *   Americas (North America, South America, Central America, Caribbean)
  *   Asia Pacific (Central & South Asia, Northeastern Asia, Southeastern Asia, Australia and Oceania)
  *   Europe (Northern Europe, Southern Europe, Eastern Europe, Western Europe)
  *   Middle East/Africa (Middle East, Northern Africa, Southern Africa)
I did steel those definitions from a website, but I was assuming it would be most practical if there were only a few regions and that gives four.
I believe the current size is just under 800MB but UK / world only is just 5MB. You can see that makes a pretty big difference in size and I have found that is useful in a company setting where you are trying to install the application on devices.
Not a big deal if that is not a good idea but I thought I'd share it in case others would also like to be able to install QGIS with a smaller proj library.
Thanks,
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/data-protection
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241211/a5516949/attachment.htm>
More information about the QGIS-User mailing list
