[Qgis-user] Strange shapefile behaviour
Werner Macho werner.macho at gmail.com
Wed Dec 18 05:23:40 PST 2024
Hi Andrew,
Is it possible that you might have given control to the "Layer Order" Panel?
https://docs.qgis.org/3.34/en/docs/user_manual/introduction/general_tools.html#layer-order-panel
Your description sounds a bit like that.
regards
Werner
On Wed, Dec 18, 2024 at 1:02 PM Andrew Chapman via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Having recently come back to QGIS after not using it for several years,
> I’m unable to get to a problem with new shapefiles that I try to create.
> I’m using 3.34.0 but have tried 3.40.1 with the same results. I’ve been
> investigating for a while and tried to simplify.
> I create a simple test file (point, line or polygon) and it is at the top
> of the Layers list so should always display above the other layers – scale
> dependent visibility isn’t selected.
> If I display labels for the layer they display as expected, If I try
> Symbology however the text continues to display correctly (i.e. over all
> the other layers) but the symbol is displayed many layers lower so is
> invisible unless those layers are disabled.
> Something is going on that is well beyond my skill level!
> Andrew Chapman
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241218/e35946c5/attachment.htm>
More information about the QGIS-User mailing list
