[Qgis-user] Zero pixels within a Shp
Andrea Giudiceandrea
andreaerdna at libero.it
Tue Dec 24 01:26:23 PST 2024
Hi Allan,
have you managed to achieve the desired results?
Regards.
Andrea
Il 16/12/2024 00:03, Andrea Giudiceandrea ha scritto:
>> Allan López allosa01 at gmail.com
>> Sat Dec 14 07:41:45 PST 2024
>> I need to remove-erase-delete all the pixels inside a Shp file within a
>> DEM, leaving the region, lakes in this case, with zero pixels.
> While I'm not sure I understand what the problem is, I guess you just
> need to use the "Rasterize (overwrite with fixed value)"
> https://docs.qgis.org/3.34/en/docs/user_manual/processing_algs/gdal/vectorconversion.html#rasterize-overwrite-with-fixed-value
> Regards.
> Andrea
More information about the QGIS-User
