[Qgis-user] Installation of QGIS on Ubuntu 22.4 LTS (Jammy) seems to use old library versions from 20.04 LTS (Focal)
Schoemans Maxime maxime.schoemans at ulb.be
Fri Jan 26 15:17:58 PST 2024
This is my first email on the qgis-user mailing list, I hope this is the
correct place to send my questions.
I have recently upgraded Ubuntu twice (first 18.04 -> 20.04, then 20.4
-> 22.04).
I am now trying to install QGIS 3.34.3 in Ubuntu 22.4 LTS (Jammy), but I
seem to have many issues of the form:
/usr/lib/qgis/crssync: error while loading shared libraries:
libqhull_r.so.7: cannot open shared object file: No such file or directory
This specific error was related to libqhull 7, which is the version for
'Focal' (20.04), while 'Jammy' (22.04) uses libqull 8 (see
https://pkgs.org/search/?q=libqhull).
After manually downloading and installing libqhull 7 from pkgs.org, I am
now hitting a similar error for another library:
libwebp.so.6: cannot open shared object file: No such file or directory
Again, the libwebp library is using the 'Focal' version (libwebp 6),
instead of the 'Jammy' version (libwebp 7).
I suspect I will hit more similar errors if I keep manually installing
the requested 'older' library versions.
My question is thus: Am I doing something wrong, or is this normal and I
should continue manually downloading previous library versions as needed?
Best regards,
Maxime Schoemans
More information about the QGIS-User mailing list
