[Qgis-user] Showing 2D-Data in QGIS Elevation Profile View QGIS 3.38
Drexel Peter
Peter.Drexel at vorarlberg.at
Thu Jul 11 05:45:31 PDT 2024
Hallo,
In the Elevation-settings of the Layer-Properties of a 3D-Shapefile (shapeZ) I can select one of the 3 Clamping-Types "Clamped to Terrain", "Relative to Terrain" or "Absolute".
In the Elevation-settings of the Layer-Properties of a 2D-Shapefile I can only select one of 2 Clamping-Types "Clamped to Terrain" or "Absolute".
I want to draw 2D-Line Features (in my case Contour-Lines) "draped" on the Terrain-Line in the Elevation Profile View. Each time the Profile-Line crosses a Contour-Line a Point-Symbol should be drawn "on" the Profile-Line in the Elevation Profile View.
* When I select "Clamped to Terrain" the Point-Symbol is drawn at Elevation 0m
* When I select "Absolute" the Point-Symbol is again drawn at Elevation 0m
* For 2D-Data I cannot select "Relative to Terrain"
In my Point of View "Clamped to Terrain" should do the trick but it does not...
Is there anyone out there who can help or at least is able to replicate the behavior?
Regards
Peter
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240711/00613b90/attachment.htm>
More information about the QGIS-User
