[Qgis-user] Create virtual fields with pyQGIS with standalone scripts
Roland Berger
roland.berger at steinerpartner.com
Sat Jul 27 01:38:20 PDT 2024
Hi Hannes and Ujaval
I found the problem. After adding a virtual field I also loaded style
from a qml file for that layer:
layer.loadNamedStyle("mystyle.qml", QgsMapLayer./Symbology/)
Looks like even when I only load the stye for the /Symbology/ also the
/Fields/ settings are somehow changed/overwritten.
Thanks
Roland
On 7/26/24 16:39, Johannes Kröger (WhereGroup) via QGIS-User wrote:
> QGIS' virtual fields (expression fields) are not
> https://www.postgresql.org/docs/current/ddl-generated-columns.html
> They are conceptually similar between QGIS and PostgreSQL, but they
> are not propagated from QGIS to the data source as a new column there.
> They live only in the QGIS project.
> If you want a generated column in your PostgreSQL database, you need
> to add it another way. E.g. via an SQL query.
> Cheers, Hannes
> On 26.07.24 12:46, Roland Berger via QGIS-User wrote:
>> Hi
>> I would like to add a virtual field to a PostGIS vector layer with
>> PyQGIS with standalone scripts
>> (https://docs.qgis.org/3.34/en/docs/pyqgis_developer_cookbook/intro.html#python-applications)
>> All examples I have found so far with google, chatgpt4 and JetBrains
>> AI Assistant gave me solutions that do not work. They only work in
>> the Python Console inside QGIS.
>> Does anybody know of a solution that works with PyQGIS with
>> standalone scripts?
>> See below what I have tried so far in different variations.
>> Thanks for any help
>> Roland
>> Example created by chatgpt:
>> field_name = "virtual_field"
>> expression = '"attribute_name" * 2' # Example expression
>> # Create and add the virtual field
>> layer.startEditing()
>> layer.addExpressionField(expression, QgsField(field_name, QVariant.Double))
>> layer.commitChanges()
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Johannes Kröger / GIS-Entwickler/-Berater
> FOSS Academy Sommerschule: Kompaktkurs zum Aufbau einer GDI
> 02.-06. September 2024, Präsenzveranstaltung in Bonn
> https://www.foss-academy.com/kompaktkurse
> WhereGroup GmbH
> c/o KK03 GmbH
> Lange Reihe 29
> 20099 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> johannes.kroeger at wheregroup.com
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
*Steiner & Partner Landschaftsarchitektur GmbH**
*Roland Berger - Geschäftsführer Stv.
Waisenhausstrasse 2
CH-3600 Thun
Mobile: +41 79 709 56 89 <tel:+41%2079%20709%2056%2089>
Tel: +41 33 335 76 53 <tel:+41%2033%20335%2076%2053>
www.steinerpartner.com <http://www.steinerpartner.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240727/a7ed65d8/attachment.htm>
More information about the QGIS-User
