[Qgis-user] LAS and LAZ files cannot be opened by this QGIS install.
    andreaerdna at libero.it
    Tue Jul 30 01:19:03 PDT 2024
> Il 30/07/2024 08:46 CEST Andrea Giudiceandrea <andreaerdna at libero.it> ha scritto:
> Hi bitrat,
> for more info, please see the comments at
> https://github.com/qgis/QGIS/issues/53348 . Martin Dobias suggested that
> "if you use QGIS packages based on Ubuntugis, PDAL support will be
> included, because the Ubuntugis repository contains PDAL packages as well."
Anyway, FYI, I can open laz files using QGIS 3.38.1 installed on Ubuntu 22.04 Jammy Jellyfish with packages from default https://qgis.org/ubuntu repository (not the ubuntugis one), since PDAL is available in the Ubuntu repositories for Jammy Jellyfish https://launchpad.net/ubuntu/+source/pdal
The PDAL package should also be available in the Debian repositories for bullseye https://packages.debian.org/search?keywords=pdal&searchon=names&suite=all§ion=all
Regards.
Andrea
More information about the QGIS-User
