[Qgis-user] QGIS Query - Dynamic Text - Layer Credits
Alanna Mitchell A.Mitchell at aquafact.ie
Wed Jul 31 23:46:42 PDT 2024
Hi Keith,
That worked and absolutely did the job. Thanks for having a look into this for me, and thanks for the extra information.
Kind Regards,
Alanna
Sent: Friday, July 26, 2024 8:33 PM
To: Alanna Mitchell <A.Mitchell at aquafact.ie>
Cc: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] QGIS Query - Dynamic Text - Layer Credits
Caution – This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe. Contact the IT Team if you are unsure
Hi, Alanna.
I was able to replicate this issue here by adding a label to a layout
using the dynamic text "Layer Credits", which creates a label using
this expression:
[%array_to_string(map_credits())%]
It seems that that expression will include any credits specified in
the QGIS metadata for each layer that appears on the layout.  To
adjust (or remove) the credit text for a layer, open the Layer
Properties > Metadata > Access and edit the value shown for the
"Rights (attribution or copyright)" section.
I'm guessing that the text string "REQUIRED: Restrictions and legal
prerequisites for using the data set after access is granted" was in
the rights metadata of one of the datasets you are including on your
map.  I've occasionally seen such values in cases where the data
creator (even an otherwise authoritative government entity) started
their metadata from a template and never finished editing it properly.
There are some more details about the map_credits() function and its
options (like saying which data layer the credit applies to) here:
https://docs.qgis.org/3.34/en/docs/user_manual/expressions/functions_list.html#map-credits
Hope this helps!
Keith
On Fri, Jul 26, 2024 at 3:50 AM Alanna Mitchell via QGIS-User
<qgis-user at lists.osgeo.org> wrote:
> Good Day QGIS Users,
> I wanted to enquire about dynamic text - map properties - layer credits.
> I use this in the print layout, usually to credit Google or OSM. However, for Google, sometimes the dynamic text is simply 'Map data ©2015 Google', however sometimes this changes to 'REQUIRED: Restrictions and legal prerequisites for using the data set after access is granted., Map data ©2015 Google'. This may change mid map, or if I am creating two maps back to back using the same base layer (Google Satellite), between the two maps this may change. The changes could be as simple as having the same vector layer displaying different symbology/properties. Would anyone know why this is happening and how to prevent this?
> Kind regards,
> Alanna
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240801/cc989826/attachment.htm>
More information about the QGIS-User mailing list
