[Qgis-user] Temporal Controller on client side of QWC2
Andreas Neumann
a.neumann at carto.net
Thu Jun 6 03:24:40 PDT 2024
Hi again,
It seems like LizMap has some support for temporal controller:
https://docs.lizmap.com/next/en/publish/lizmap_plugin/time_manager.html
But as I said - this works through sending vector data and client side
rendering - so not the full capabilities of the QGIS styling engine.
Greetings,
Andreas
On 2024-06-06 06:41, Andreas Neumann via QGIS-User wrote:
> Hi BJ,
> No - I don't think this is possible. But I am not fully up-to-date
> about QWC2, as I am not an active user. You might want to ask at the
> separate QWC2 user mailing list:
> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
> Personally, I have doubts about the feasibility of integrating the
> temporal controller with QGIS server and any web client that relies on
> raster images. QGIS server is sending raster images of map extents.
> That approach wouldn't scale very well, due to the additional lag
> between client and server. To get an acceptable performance, it would
> mean that one would have to exchange vector features (geometry and
> attributes) and render client-side - and then you loose the QGIS
> symbology features ...
> It might be more feasible to use QGIS wasm (web assembly) for this
> purpose. But it is still a young project. In QGIS wasm, the QGIS
> rendering engine runs inside the browser. It is also generating raster
> images, but it would hold the original GIS data in the client and also
> render in the client, eliminating the network lag between server and
> client. There you would maintain the QGIS rendering and labeling
> capabilities.
> If you have a serious interest in that feature, one could further
> discuss if an implementation of the temporal controller with QGIS wasm
> would be an option. But it would require an investment in the qgis-js
> API/bindings and a client side implementation of the temporal
> controller with some web framework.
> Best regards,
> Andreas
> On Wed, 5 Jun 2024 at 23:58, BJ Raval via QGIS-User
> <qgis-user at lists.osgeo.org> wrote:
>> Hi Andreas,
>> I am an occasional desktop QGIS user but this is my first time asking
>> a question for help.
>> I would like to use the Temporal Controller on a web page served by
>> QWC2 web client. Is it possible to use Temporal Controller by a user
>> on the client side on the web browser?
>> A detailed answer of "how-to" would be much appreciated if this is
>> possible.
>> Sincere thanks!
>> BJ _______________________________________________
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Andreas Neumann QGIS.ORG [1] board member (treasurer)
Links:
[1] http://QGIS.ORG
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240606/a0a264d6/attachment.htm>
More information about the QGIS-User
