[Qgis-user] Issue with Adding Dynamic Images in QGIS Report
Max Hoyer maxhoyer1 at gmail.com
Sun Jun 9 01:57:20 PDT 2024
I am writing to seek assistance regarding an issue I am experiencing while
trying to add dynamic images to a report in QGIS. I have followed the
recommended steps, but the images are not displaying correctly. Here are
the details of my issue:
1. **QGIS Version**: I am using QGIS 3.28.15.
2. **Setup**:
   - I have created a text field in the attribute table of my layer to
store the file paths of the images. The field is named "Bild".
   - The file paths are entered in the following format: D:\Huddinge.jpg
   - I have confirmed that QGIS has access to the image files and can
display them when not using the attribute table.
3. **Steps Taken**:
   - I opened the Print Layout.
   - I added an image object to the layout.
   - In the properties of the image object, I selected "Raster image" →
"Attribute Field".
   - I selected the correct layer and the "Bild" field.
   - I ensured the "Field type: string" option is enabled.
4. **Issue**:
   - Despite following these steps, the image does not display in the
report layout. Instead, I see a red "X" indicating that the image could not
be loaded.
5. **Additional Checks**:
   - I verified that the file paths in the attribute table are correct and
accessible.
   - I tried using both absolute and relative paths without success.
   - I tested different image formats (.jpg, .png) to rule out format
issues.
   - I ensured there are no invisible characters or spaces in the file
paths.
   - I restarted QGIS and recreated the image object in the report layout.
6. **Other Details**:
   - When adding an image directly (not via the attribute table), it
displays correctly, confirming that the file paths and image files are not
the issue.
Thanks for your help.
Max
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240609/95641e3d/attachment.htm>
More information about the QGIS-User mailing list
