[Qgis-user] Fwd: Export data with tiff and csv files in QGIS 3.36.3
ΣΟΦΙΑ ΤΣΙΤΟΥ
sofitsitou at gmail.com
Tue Jun 11 09:39:45 PDT 2024
Thank you very much both of you for your help and your comments!
Kind regards,
Sofia
Στις Τρί 11 Ιουν 2024 στις 7:14 μ.μ., ο/η chris hermansen <
clhermansen at gmail.com> έγραψε:
> Richard, Sofia and list;
> Sorry to top post here, but I wonder if this might be due to the various
> input layers being in different coordinate systems? I seem to recall a
> problem like that from "back in the day".
> On Tue, Jun 11, 2024 at 9:07 AM Richard McDonnell via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Hi Sofia,
>> I unfortunately am unable to access the files you sent, as there are
>> restrictions on our systems here in relation to accessing files.
>> Apologies for that.
>> Kind Regards,
>> Richard
>> Richard McDonnell MSc GIS, FME Certified Professional
>> *Flood Risk Management - Data Management*
>> Oifig na nOibreacha Poiblí
>> Office of Public Works
>> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
>> Jonathan Swift Street, Trim, Co Meath, C15 NX36
>> M +353 87 688 5964 T +353 46 942 2409
>> https://gov.ie/opw
>> To send me files larger than 30MB, please use the link below
>> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
>> Email Disclaimer:
>> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
>> *From:* ΣΟΦΙΑ ΤΣΙΤΟΥ <sofitsitou at gmail.com>
>> *Sent:* 11 June 2024 14:34
>> *To:* Richard McDonnell <richard.mcdonnell at opw.ie>
>> *Cc:* qgis-user at lists.osgeo.org
>> *Subject:* Re: [Qgis-user] Fwd: Export data with tiff and csv files in
>> QGIS 3.36.3
>> igme5000.tif
>> <https://drive.google.com/file/d/1vxfYWoy-Z24hCoYXNwELB6gJqQC2I6c0/view?usp=drive_web>
>> Dear Richard,
>> Thank you very much for your quick response. I followed this procedure
>> many times but unfortunately I gοt null values. Attached you can find the
>> files that I used (two different tiff maps-I use one map each time- and one
>> csv file with the coordinates). I can't find out if there's a problem with
>> my files or something I'm not doing right in the process.
>> Thank you.
>> Warm regards,
>> Sofia Tsitou
>> Στις Τρί 11 Ιουν 2024 στις 3:42 μ.μ., ο/η Richard McDonnell <
>> richard.mcdonnell at opw.ie> έγραψε:
>> Hi Sofia,
>> So I will start from the beginning, hopefully I understand your query
>> properly…
>> 1. Add your Raster to the Canvas
>> 2. Using the *Data Source Manager* and *Delimited Text*, I add the
>> CSV, making sure the Headers, Columns and rows are correct, while also
>> setting/specifying the X, Y and Z fields (as required)
>> 3. This will result in a Point Dataset being added to the Canvas,
>> with the CSV loaded as a temporary layer
>> 4. In the Processing Toolbox search bar, type “*sample*” and then
>> select *Sample raster values*
>> a. *Input layer* set to the Point Dataset
>> b. *Raster Layer* set to the Raster you want to analyse
>> c. *Output column Prefix* is handy if you have multiple datasets
>> you want to sample, as you can change this for each subsequent sample.
>> d. *Sampled* you can specify a Location for your output dataset,
>> or you can leave it as a temporary layer until you have carried out all
>> sampling.
>> I hope that clarifies things,
>> Kind Regards,
>> Richard
>> *Richard McDonnell MSc GIS, FME Certified Professional*
>> *Oifig na nOibreacha Poiblí*
>> *Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36 *
>> https://gov.ie/opw
>> Email Disclaimer:
>> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *S?F??
>> ?S???? via QGIS-User
>> *Sent:* 11 June 2024 12:52
>> *To:* qgis-user at lists.osgeo.org
>> *Subject:* [Qgis-user] Fwd: Export data with tiff and csv files in QGIS
>> 3.36.3
>> Dear QGIS team,
>> I have two maps in tiff format and coordinates in csv format and I try
>> through zonal statistics and sample raster values to export the data but it
>> gives me null values. Could you tell me the steps to extract the data
>> because I might be making a mistake?
>> Thank you in advance,
>> Sofia Tsitou
>> Tsitou Sofia
>> Αdjunct Lecturer
>> Department of Economics
>> University of Ioannina
>> Greece
>> Post Doctoral Fellow
>> University of Macedonia, Thessaloniki
>> Greece
>> Research Fellow
>> DAISSy Research Group
>> Hellenic Open University
>> Greece
>> e-mail: sofitsitou at gmail.com
>> Homepage: https://sites.google.com/view/sofiatsitou/home
>> <https://sites.google.com/view/sofiatsitou/home>
>> Tsitou Sofia
>> Αdjunct Lecturer
>> Greece
>> Greece
>> Research Fellow
>> Greece
>> Tsitou Sofia
>> Αdjunct Lecturer
>> Greece
>> Greece
>> Research Fellow
>> Greece
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
Tsitou Sofia
Αdjunct Lecturer
Greece
Greece
Research Fellow
Greece
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240611/5605b9fc/attachment.htm>
More information about the QGIS-User
