[Qgis-user] Query Builder - I thought I understood what I was doing.
oisin.kelly.wild at gmail.com oisin.kelly.wild at gmail.com
Wed Jun 12 12:08:32 PDT 2024
Are you entering the filter in the expression builder from the attribute table. If so, type
substring("DateSale") in ('2021',  '2022', '2023', '2024')
This should filter the table to show features with "DateSale"='2021' or '2022' or '2023' or '2024'.
⁣Oisin
Get BlueMail for Android ​
On 12 Jun 2024, 20:01, at 20:01, Jeremy via QGIS-User <qgis-user at lists.osgeo.org> wrote:
>this explanation is opaque. can you explain how i use this in the query
>builder? is it a matter of adding an attribute that is calculated by
>the
>slicing?
>This message would have been encrypted if you were using Delta Chat or
>some other autocrypt-compatible email client.
>I am also reachable by Signal, Matrix, SMS, and telephone calls.
>Find more information here:
>| Delta Chat      | https://delta.chat/en/ |
>| autocrypt       | https://autocrypt.org/ |
>| Signal          | https://signal.org/en/ |
>| Matrix          | https://element.io/    |
>| SMS & telephone | +18149337465           |
>_______________________________________________
>QGIS-User mailing list
>QGIS-User at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240612/f7a77c2c/attachment.htm>
More information about the QGIS-User mailing list
