[Qgis-user] Query Builder - I thought I understood what I was doing.
Árni Geirsson
arni at alta.is
Wed Jun 12 12:08:42 PDT 2024
Or this:
right("string",4) in ('2022','2023','2024')
Árni Geirsson
*Alta ehf* // +354 582 5003 // +354 897 9549
On Wed, 12 Jun 2024 at 19:07, chris hermansen via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Jeremy, list;
> On Wed, Jun 12, 2024 at 11:40 AM Jeremy Swarm via QGIS-User <
>> I have a set of vectors (it's a parcel map) from my county. This layer
>> has a number of attributes defined. I would like to filter the features by
>> an attribute called "DateSale". it is formatted MM/DD/YYYY. I believe it is
>> astring. I would like to find features which end with any of
>> 2021,2022,2023, ,or 2024. I have not been able to build a successful filter
>> with the query builder.
>> You don't say why you "believe" it is a string. You can check the field
> types...
> Anyway, in case it's a date, you can use the year function in the query
> builder e.g. year(DateSale)
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240612/007ece25/attachment.htm>
More information about the QGIS-User
