[Qgis-user] Triangular Legend
Drew French
fullboarfarm at gmail.com
Sun Jun 16 12:20:37 PDT 2024
On Sun, Jun 16, 2024, 8:14 AM Drew French <fullboarfarm at gmail.com> wrote:
> If you need just an image in the legend you can always make a dummy point
> layer and load an image you create as the symbol, and then in print layout
> use that for your legend even if it's not connected to anything in the
> actual map. You could also use the geometry generator but that might be a
> little tricky.
> On Sun, Jun 16, 2024, 3:00 AM Phil Wyatt <phil at wyatt-family.com> wrote:
>> I suspect this is typical of what is required (maybe not with the text?)
>> https://vro.agriculture.vic.gov.au/dpi/vro/vroimages.nsf/Images/landform_radio5/$File/radio_pyrmid.jpg
>> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Drew
>> French via QGIS-User
>> *Sent:* Sunday, June 16, 2024 7:52 AM
>> *To:* QGIS List <qgis-user at lists.osgeo.org>
>> *Subject:* [Qgis-user] Triangular Legend
>> Do you have a sample image?
>> On Sat, Jun 15, 2024 at 2:00 PM <qgis-user-request at lists.osgeo.org>
>> wrote:
>> Send QGIS-User mailing list submissions to
>> To subscribe or unsubscribe via the World Wide Web, visit
>> https://lists.osgeo.org/mailman/listinfo/qgis-user
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> qgis-user-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of QGIS-User digest..."
>> Today's Topics:
>> 1. Triangular Legend (boxerg at iinet.net.au)
>> Message: 1
>> Date: Sat, 15 Jun 2024 14:26:06 +0800
>> From: <boxerg at iinet.net.au>
>> To: <qgis-user at lists.osgeo.org>
>> Subject: [Qgis-user] Triangular Legend
>> Message-ID: <00b001dabeec$e80ff490$b82fddb0$@iinet.net.au>
>> Content-Type: text/plain; charset="us-ascii"
>> I am producing ternary radiometric images where potassium is shown in red,
>> thorium shown in green and uranium shown in blue. In geophysical maps,
>> they
>> commonly have a triangular legend with potassium at the apex and the green
>> and blue at the lower points of the triangle. Hs anyone ever created a
>> triangular legend for an RGB image?
>> Cheers Grant
>> Perth Western Australia
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.osgeo.org/pipermail/qgis-user/attachments/20240615/1a6b7a0f/attachment-0001.htm
>> Subject: Digest Footer
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> End of QGIS-User Digest, Vol 220, Issue 20
>> Andrew French
>> (715) 986-8088
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240616/d87c2572/attachment.htm>
More information about the QGIS-User
