[Qgis-user] Warning and errors netcdf when running a command
    Andrea Giudiceandrea
    andreaerdna at libero.it
    Fri Mar 15 03:13:59 PDT 2024
> Langers, Fransje fransje.langers at wur.nl
> Fri Mar 15 01:05:24 PDT 2024
> This was indeed the situation. Thanks for solving my problem!
You are welcome. I suggest you to also ensure that the "Default output
vector layer extension" is set to the value "gpkg" (GeoPackage), since I
guess it is probably also incorrectly set to the "xtf" value which will
also lead to issues with the GDAL processing algorithms having vector
layer as output.
Since I suppose you have not intentionally set such options (like many
other users experiencing similar issues), it would be very useful if you
could remember what have you done after the last time the algorithm
worked without issues and the first time it didn't work: have you
upgraded / downgraded QGIS, or installed / uninstalled any plugin or
used an older version and a newer version of QGIS with the same QGIS
user profile, or...?
Every detail would help to find the root cause of the issue and try to
permanently fix it.
Best regards.
Andrea
More information about the QGIS-User
