[Qgis-user] QGIS 3.34 and QGZ on network drives
Thomas Schüttenberg thomas at qgis.de
Thu May 2 07:12:35 PDT 2024
Update on "Unable to unzip file '<file path to project.qgz>'": This issue does not appear with QGIS 3.34.5.
All findings described below refer to QGIS 3.34.6.
I am affraid it is connected to the extensive updates liste here https://lists.osgeo.org/pipermail/qgis-user/2024-April/054334.html ?
Anyway, still interested to hear, if someone experienced something similar.
All the best
Thomas
> Thomas Schüttenberg via QGIS-User <qgis-user at lists.osgeo.org> hat am 02.05.2024 14:44 CEST geschrieben:
> Hello everyone,
> I am currently preparing the rollout of QGIS 3.34.6 for our administration and have encountered a strange and very inconsistent behaviour when opening project files from our network drives (Windows):
> When double-clicking on such a project tile on the welcome page, the error message.
> "Unable to unzip file '<file path to project.qgz>'" is displayed and the project does not open.
> If you try it via the selection in the menu 'Project - Open recent' you get the same result.
> If you use 'Open project' (Ctrl+O) to open the Windows File Explorer and select the QGZ in question, it works.
> If you close the project and then click again on its 'Recent projects' entry on the welcome page or in the 'Recently used' menu, this also works now.
> However, if you wait a while (approx. 1-2 minutes) before clicking on a recent link, it does not work any more!
> The time can also elapse while the project is open, i.e. closing the project and then clicking on the recent link does not work (any more).
> First I thought, that saving or re-saving a QGZ with QGIS 3.34 would solve the problem, but today I encounter the same phenomenon on 3.34-QGZs, which I saved a few days ago.
> Furthermore, if the link to a project on the welcome page does not work and I then touch (i.e. single click) this qgz-file via the Windows file explorer, the recent link in QGIS works afterwards.
> User profiles or age or version of the QGZ do not seem to play a role. All of this cannot be reproduced with QGIS 3.28 using the same project-files.
> So, there seems to be a strange interference between QGIS 3.34 and the access to our network drives, which could become quite a blocker for our rollout. Only local QGZ are not affected.
> What do you think, has anyone heard of similar phenomena? I am grateful for any ideas!
> Best regards
> Thomas
> QGIS-DE e.V. | https://qgis.de | thomas at qgis.de
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
