[Qgis-user] Search through folders and combine SHP files
Nyall Dawson
nyall.dawson at gmail.com
Thu May 9 19:06:56 PDT 2024
On Fri, 10 May 2024 at 09:06, Tony Shepherd (FarmMaps NZ) via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi
> I have loads, literally thousands, of SHP, GPKG, TAB files located in
> loads of different folders and sub-folders.
> Is there a plugin that will trawl through a set of folders, copy say just
> the polygons from each file into a new file, and populate a field with say
> the filename and folder the polygon(s) came from?
> Essentially combining a heap of files into one with some metadata about
> where the data came from?
> Why? I have files from clients dating back about 20 years. Clients sell
> properties. Properties get subdivided. New clients come and see us, and
> often we don’t realise we have GIS info on file for that property from many
> years ago, usually under a different name. It would be handy to see a
> polygon on the screen and easily go back to some old GIS data.
> Maybe I am missing an easy tool to do this, but I can’t see anything
> obvious.
You could use the "Merge Vector Layers" tool from the Processing toolbox,
that does everything you want. The trickiest bit would be getting a master
list of ALL your shapefiles/etc you want to combine and passing this to the
tool. It's not going to be easy from the GUI itself, as that only allows
you to add files from a single folder at once.
I'd run the tool on the files from a single folder, then checkout the
processing history dialog and copy the python command which corresponds to
what you just did. You could then adapt this command to pass a complete
list of all the files you want to combine. (It's quite straightforward in
Python to build a list of files which recursively match a file pattern --
see eg https://stackoverflow.com/a/2186565 )
Hope that helps!
Nyall
> Cheers
> Tony
> *Tony Shepherd*
> * GeoSpatial Manager @ FarmMaps NZ & Photographer @ Shepherd Photos*
> *Phone* *–* 027 435 6193 | *Website – *shepherdphotos.co.nz
> *Email** – Maps* tony at farmmaps.nz | *Email – Photos*
> tony at shepherdphotos.co.nz
> *Facebook* TonyShepherdPhotos
> <https://www.facebook.com/TonyShepherdPhotos>
> [image: FM_logo1_small (Custom)]
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240510/33d17946/attachment.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240510/33d17946/attachment.jpg>
More information about the QGIS-User
