[Qgis-user] Search through folders and combine SHP files
    Even Rouault
    even.rouault at spatialys.com
    Sun May 12 14:59:36 PDT 2024
The GDAL ogrtindex might be of good help to create an index of various
vector sources: https://gdal.org/programs/ogrtindex.html
And you can possibly "gdalmanage identify -r some_path" to find all GDAL
recognizable datasets: https://gdal.org/programs/gdalmanage.html
Even
Le 12/05/2024 à 23:41, Tony Shepherd (FarmMaps NZ) via QGIS-User a écrit :
> Hi Nigel
> Thank you, that works a treat, although it does fail if I try to merge
> a line feature at the same time as a polygon.  That is not a big deal
> and can get around that.
> Your comment, “Then parse these through to the merge vector layer”.  I
> can’t see a way of parsing the filelist.txt to the tool. I am not
> experienced in using python.
> Cheers
> TIby
> *From:*Nigel Berjak - S3 Technologies <nigel at s3.co.za>
> *Sent:* Friday, May 10, 2024 6:03 PM
> *To:* Nyall Dawson <nyall.dawson at gmail.com>
> *Cc:* Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz>;
> qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Search through folders and combine SHP files
> Hi
> For your listing, although it would not provide the file type i.e.
> point, line, polygon etc, you could simply create a DOS batch command
> (dir/s *.shp > shapefilelist.txt) to locate all the file and generate
> a list of their locations. Then parse these through to the merge
> vector layer. If you are merging them all into a Geopackage, then file
> type would not be relevant and you could then sort them once they are
> in a single location. I don't think the Geopackage would have a
> limitation on the number of files and records in it.
> Perhaps this can assist.
> Regards,
> Nigel Berjak
> S3 Technologies
> Geographic Information Systems & Large Format Printing specialists
> T: +27 33 3423681
> F: +27 86 6721242
> E: nigel at S3.co.za <mailto:nigel at S3.co.za>
> Website: http://www.S3.co.za <http://www.S3.co.za>
> Please consider the environment before printing this email.
> On 2024-05-10 04:06, Nyall Dawson via QGIS-User wrote:
>     On Fri, 10 May 2024 at 09:06, Tony Shepherd (FarmMaps NZ) via
>     QGIS-User <qgis-user at lists.osgeo.org
>     <mailto:qgis-user at lists.osgeo.org>> wrote:
>         Hi
>         I have loads, literally thousands, of SHP, GPKG, TAB files
>         located in loads of different folders and sub-folders.
>         Is there a plugin that will trawl through a set of folders,
>         copy say just the polygons from each file into a new file, and
>         populate a field with say the filename and folder the
>         polygon(s) came from?
>         Essentially combining a heap of files into one with some
>         metadata about where the data came from?
>         Why?  I have files from clients dating back about 20 years.
>         Clients sell properties.  Properties get subdivided.  New
>         clients come and see us, and often we don't realise we have
>         GIS info on file for that property from many years ago,
>         usually under a different name.  It would be handy to see a
>         polygon on the screen and easily go back to some old GIS data.
>         Maybe I am missing an easy tool to do this, but I can't see
>         anything obvious.
>     You could use the "Merge Vector Layers" tool from the Processing
>     toolbox, that does everything you want. The trickiest bit would be
>     getting a master list of ALL your shapefiles/etc you want to
>     combine and passing this to the tool. It's not going to be easy
>     from the GUI itself, as that only allows you to add files from a
>     single folder at once.
>     I'd run the tool on the files from a single folder, then checkout
>     the processing history dialog and copy the python command which
>     corresponds to what you just did. You could then adapt this
>     command to pass a complete list of all the files you want to
>     combine. (It's quite straightforward in Python to build a list of
>     files which recursively match a file pattern -- see eg
>     https://stackoverflow.com/a/2186565
>     <https://stackoverflow.com/a/2186565>)
>     Hope that helps!
>     Nyall
>         Cheers
>         Tony
>         *Tony Shepherd*
>         /  GeoSpatial Manager @ FarmMaps NZ & Photographer @ Shepherd
>         Photos/
>         /*Phone*/*–* 027 435 6193  | /*Website*/*–
>         *shepherdphotos.co.nz <http://shepherdphotos.co.nz/>
>         /*Email*/*– Maps*tony at farmmaps.nz <mailto:tony at farmmaps.nz>|
>         /*Email*/*– Photos* tony at shepherdphotos.co.nz
>         <mailto:tony at shepherdphotos.co.nz>
>         /*Facebook*/TonyShepherdPhotos
>         <https://www.facebook.com/TonyShepherdPhotos>
>         FM_logo1_small (Custom)
>         _______________________________________________
>         QGIS-User mailing list
>         QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>         <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>         Unsubscribe:
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240512/fc299f08/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240512/fc299f08/attachment-0001.jpg>
More information about the QGIS-User
