[Qgis-user] RASTER RESOLUTION REDUCING
Richard McDonnell richard.mcdonnell at opw.ie
Tue May 14 01:51:14 PDT 2024
Hi Nuno,
As usual there are a number of ways to do this. Grass: r.resamp.stats as Em suggested would work, but might I also suggest the Warp tool, based on gdal_warp.
This can be found by going to the Menu bar select Raster, Projections and Warp.
Parameters:
Input Layer
Set this to the Raster you want to resample
Source/Target CRS
If you’re not transforming your dataset to another CRS then you can leave these alone, but you can also set these to the value of the Raster CRS
Resampling method to use
As you are looking for the average of the Pixel values, you can select Average here.
No Data value for output Bands:
Set if required
Output file resolution……:
This is the one of most interest to you, here you can set the resolution of the output to 2500
Reprojected:
Specify the Location and Filename that you want the new Dataset to have, you can leave it blank if you like for a Temporary file to be created.
Hope this helps!
Kind Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
Flood Risk Management - Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Emma Hain via QGIS-User
Sent: 14 May 2024 02:20
To: Nuno Manuel de Figueiredo de Santos Loureiro <nlourei at ualg.pt>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] RASTER RESOLUTION REDUCING
Hi Nuno
Apologies in advance, I am no raster specialist, but perhaps try using some of the other tools such as Grass: r.resamp.stats
To get the information, would the GDAL Raster Information tool<https://docs.qgis.org/3.34/en/docs/user_manual/processing_algs/gdal/rastermiscellaneous.html#raster-information> assist?
Cheers
Em
On Tue, 7 May 2024 at 23:16, Nuno Manuel de Figueiredo de Santos Loureiro via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> wrote:
Dear all,
I need to reduce the resolution of a raster, from a 30 meter pixel to a 2500 meter pixel.
Performing this operation via "Creating new layers from an existing layer" and using the "Resolution" raster parameter is very easy.
But the value of the new 2500 meter grids is not the average of the values ​​of the 30 meter grids.
How can I determine that in the destination grids its value is the average of the values ​​in the original grids?
Suggestions will be very welcome!
Grateful,
Nuno
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Emma Hain — Product Manager/Senior GIS Analyst
emma at north-road.com<mailto:emma at north-road.com>
[https://north-road.com]
North Road
Cartography • Development • Spatial Analysis
north-road.com<http://north-road.com>
[https://ci3.googleusercontent.com/mail-sig/AIorK4xbsQ72BNIM2cWMZcuEKVer1Bwaq_gqYkdbtrjK2ifrqv-4o7aWjcvilgYXtNGpXLNgD00xgmQ]<https://twitter.com/northroadgeo>[https://ci3.googleusercontent.com/mail-sig/AIorK4zEBWGJKio8gqmFT0h_51t4ZnmoGgbmV7SeL-4FKvwWApFWDWyK7p-c0-cSskUe7pjQzjEZj9Q]<https://www.linkedin.com/company/north-road-studios>[https://ci3.googleusercontent.com/mail-sig/AIorK4wlMciFPm8hqQZB_Qi57PUCv1dJqUC1A2i9qEMzWRFLcJ7Jil30YnULdJLxT6-qMfI6J4kcac4]<https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240514/aa1a0aff/attachment-0001.htm>
More information about the QGIS-User mailing list
