[Qgis-user] Can't accomplish comparisions between different Map Layer Table's
oisin.kelly.wild at gmail.com oisin.kelly.wild at gmail.com
Tue May 14 12:41:05 PDT 2024
No it won't work. It's not SQL syntax, it's expression syntax. So you need to use a function to get the corresponding feature from another layer. Hence getfeature() or one of the  overlay_ functions.
You will end up with a long expression.
Or, you could use sql in dB manager?
⁣Oisin
07570 977449
Get BlueMail for Android ​
On 14 May 2024, 20:35, at 20:35, Guillermo Parra <meminp_24 at yahoo.com> wrote:
>Hello Oisin,
>Thank you for your guidance regarding this topic, and I am sorry if I
>need further assistance, but I'm kind of new to QGIS.
>Regarding the need to define the layer for each attribute, will it work
>if I stated like I had wroten before?
>i.e.:'Table1.H3centr_h9_cobcubierto'  = 1
>OR 'Table2.H3centr_h9_cobcubierto' = 1 Will QGIS recognize it?
>And to find the comparable record, certaingly I can use a common id. So
>I will explore the getfeature( ) tool that you suggest, thank you very
>much.
>Regards.
>Guillermo Parra Montealegre e-mail: meminp_24 at yahoo.com
>El martes, 14 de mayo de 2024, 13:23:07 GMT-6,
>oisin.kelly.wild at gmail.com <oisin.kelly.wild at gmail.com> escribió:
>You definitely need to define the layer for each attribute (except the
>current layer).
>You also need a way to find the comparable record, e.g.
>(i) with a common id (use getfeature() to access attribute) or
>(ii) spatially use one of the overlay functions.
>Oisin
>Get BlueMail for Android On 14 May 2024, at 19:52, Guillermo Parra via
>QGIS-User <qgis-user at lists.osgeo.org> wrote:
>Hi,
>I have several tables with the same fields, same grid information, but
>different field data for each one (information from different
>providers, let's say).
>Particularly, I have a field with 0 and 1 which represent if each
>provider have, or not have coverage in that area.
>I want to compare the values of each table to set "1" if at least one
>of the providers have coverage in each area, or "0" if None of them
>have it, so I used the field calculator and the expression builder with
>this sql statement:
>if( 'H3centr_h9_cobcubierto'  = 1 OR 'H3centr_h9_cobcubierto' = 1
>OR'H3centroides_h9_cobGT3D cubierto' = 1
>OR'H3centroides_h9_cob_cubierto'  = '1' OR'H3centr_h9_cob_cubierto' =
>'1' OR'H3cent_cob_cubierto'  = '1' OR"H3centrR9_Tc3D_cubierto"  ='1',
>1, 0)
>The problem is that apparently it is considering only the last field in
>double quotes (which is in the same table that the new column where I
>want to fill the data), and the other fields apparently are beign
>ignored.
>I would guest that it would be better to specify the table and field
>where each data will be taken ( like  if(
>'Table1.H3centr_h9_cobcubierto'  = 1 OR 'Table2.H3centr_h9_cobcubierto'
>= 1 OR... etc.)but when I make double click over each layer field, QGIS
>writes it that way, so I asume it is correct.
>So, if someone have an idea on how I can make it work, I would greatly
>appreciate any suggestion.Thanks,
>Guillermo.
>QGIS-User mailing list
>QGIS-User at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240514/9cc4d22c/attachment.htm>
More information about the QGIS-User mailing list
