[Qgis-user] Labeling: Allow HTML Formatting, text-size and map units
    Thomas Schüttenberg
    thomas at qgis.de
    Wed May 15 06:04:06 PDT 2024
Hi Stefan,
thanks for the hint.
The size value can be made variable (as visible in the expression builder preview), but on the canvas there is yet no dynamic change what so ever.  :-/
Best regards
Thomas
> Stefan Giese (WhereGroup) via QGIS-User <qgis-user at lists.osgeo.org> hat am 15.05.2024 10:24 CEST geschrieben:
> Hi Thomas,
> you can try to involve the map_scale variable into a dynamic size of the
> HTML Label, something like:
> with_variable('fs', 25000/@map_scale,
>        format(
>       '<h1 style="font-size:%1pt;">%2</h1>',
>       @fs , title( "Name" )))
> Best regards
> Stefan
> Am 15.05.2024 um 09:13 schrieb Thomas Schüttenberg via QGIS-User:
> > Hi there!
> > I am just playing arund with html enhanced labeling, using the option "Allow HTML Formatting" on the text tab (https://docs.qgis.org/3.34/en/docs/user_manual/style_library/label_settings.html#text-tab).
> > Now I wonder how/if it is possible to override the text-size in such a manner, that my label as a whole is still scale dependend and is respecting the given map units including the minimum and maximum scale (https://docs.qgis.org/3.34/en/docs/user_manual/introduction/general_tools.html#unit-selector)?
> > Imagine you have a multi line label with the text size set to 2 meters map units and a maximum scale at 1:5000.
> > Now the first line should be double in text size and therefore I use something like style="font-size:20pt" (see example in manual above).
> > But only pt (points) seams to work as the unit in this place, which gives a fixed size throughout all scales and does not respect the behavior of the map units with maximum scale setting.
> > Does anyone know a trick to achieve this anyhow?
> > All the Best!
> > Thomas
> > QGIS-User mailing list
> > QGIS-User at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> WhereGroup GmbH
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Tel.: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> stefan.giese at wheregroup.com
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
More information about the QGIS-User
