[Qgis-user] Advance Digitising Tools- compass bearings
Philip Ryan
philipjryan135 at gmail.com
Thu May 16 18:50:12 PDT 2024
Hello,
I am trying to digitise a series of old gold lease "portion plans" produced in the 1880s in Australia by a mining surveyor using a compass and chain. The data for each gold lease includes a table of 1) compass bearings in degrees and 2) distance measurements in links (0.2 m) for each vertex of the lease polygon (mostly a rectangle or trapezoid but sometimes more complex).
The Advance Digitizing Tools would seem to be ideal for this data except for the angle measure (a) which I can't input as a compass bearing (0-360 deg). The current settings with 90 deg E as the zero makes conversion of compass bearings very tedious.
Is it possible to change the angle variable (a) to a compass bearing?
Regards,
Phil Ryan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240517/f1bf66f1/attachment.htm>
More information about the QGIS-User
