[Qgis-user] Advance Digitising Tools- compass bearings
C Hamilton
adenaculture at gmail.com
Fri May 17 04:00:00 PDT 2024
Phil,
The Shape Tools plugin has an "Azimuth distance digitizer" and for what you
are talking about an "Azimuth distance sequence digitizer". With the latter
function you click on a starting location and then give a list of azimuth,
distance sequences. I have used this for old surveys like this. There is
also an declination offset just in case your surveys were using magnetic
north and not true north. In that case you have to look up what the
declination offset was for your 1880s date.
Regards,
Calvin
On Thu, May 16, 2024 at 9:50 PM Philip Ryan via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hello,
> I am trying to digitise a series of old gold lease "portion plans"
> produced in the 1880s in Australia by a mining surveyor using a compass and
> chain. The data for each gold lease includes a table of 1) compass
> bearings in degrees and 2) distance measurements in links (0.2 m) for each
> vertex of the lease polygon (mostly a rectangle or trapezoid but sometimes
> more complex).
> The Advance Digitizing Tools would seem to be ideal for this data except
> for the angle measure (a) which I can't input as a compass bearing (0-360
> deg). The current settings with 90 deg E as the zero makes conversion of
> compass bearings very tedious.
> Is it possible to change the angle variable (a) to a compass bearing?
> Regards,
> Phil Ryan
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240517/897dac58/attachment.htm>
More information about the QGIS-User
