[Qgis-user] Advance Digitising Tools- compass bearings
    Richard Greenwood
    richard.greenwood at gmail.com
    Fri May 17 05:38:59 PDT 2024
On Fri, May 17, 2024 at 6:16 AM Jeremy Jackson via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> A related question, what about grid to ground conversions and vice-versa,
> are there plugins which support this?  Surveys here in Canada always
> specify a "combined scale factor", which is tedious to apply manually to
> each vertex when digitizing.
Gid to ground is a scale factor. So you can enter everything with the given
bearings and distances, then when you're done, use the "Scale Feature"
tool. To do that correctly you need to know the point where the combined
factor is applied. Hold the control key while clicking that point and then
enter the combined factor in the box in the upper right corner. If you
don't know the point where the combined factor is calculated, pick a point
near the center of your feature(s), not the origin of the coordinate system
(0, 0).
Richard W. Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240517/07350781/attachment.htm>
More information about the QGIS-User
