[Qgis-user] Pansharpening Images
boxerg at iinet.net.au boxerg at iinet.net.au
Thu May 23 16:00:10 PDT 2024
Thanks Micha,
That works but I don’t know why it is called “BundleToPerfectSensor”? I have searched for pansharpening algorithms previously and would never have guessed that one!
Cheers Grant
Perth WA
Sent: Thursday, May 23, 2024 10:38 PM
To: Grant Boxer <boxerg at iinet.net.au>; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Pansharpening Images
In the past I've used the pan sharpening function in Orfeo Toolbox on WorldView 3 imagery. I chose the "bayes" method, not Gram-Schmidt that you want. Orfeo implements three sharpening algorithms:
https://www.orfeo-toolbox.org/CookBook/Applications/app_BundleToPerfectSensor.html
Here's the code I used (after preparing a *.vrt from both the PAN and the Multiband files)
WV_dir="....."
region="....."
# Pan sharpening
otbcli_BundleToPerfectSensor -inp ${WV_dir}/${region}_PAN.vrt -inxs ${WV_dir}/${region}_Multi.vrt -out ${WV_dir}/${region}_pansharp_bayes.tif uint16 -method bayes -ram 8000 -progress true
# Compress
gdal_translate -co COMPRESS=ZSTD -co PREDICTOR=2 ${WV_dir}/${region}_pansharp_bayes.tif ${WV_dir}/${region}_pansharp_bayes2.tif
mv ${WV_dir}/${region}_pansharp_bayes2.tif ${WV_dir}/${region}_pansharp_bayes.tif
gdaladdo -r average --config COMPRESS_OVERVIEW ZSTD --config PREDICTOR_OVERVIEW 2 -ro ${WV_dir}/${region}_pansharp_bayes.tif
HTH
On 23/05/2024 6:43, Grant Boxer via QGIS-User wrote:
Does anyone know of a plug-in or algorithm for QGIS where I can pansharpen satellite imagery using the Gram-Schmidt method?
Cheers Grant
Perth WA
QGIS-User mailing list
QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240524/be547e1d/attachment.htm>
More information about the QGIS-User mailing list
