[Qgis-user] QGIS master password
Paul Wittle
paul.wittle at dorsetcouncil.gov.uk
Tue May 28 02:16:41 PDT 2024
Hi QGIS Users,
I've been battling with the 'master' password for years now because I've been trying to work with a centrally managed password store. The method is simple enough, you have a plugin that you distribute to the devices you are configuring, and the plugin sets and activates your password store. This works fine and is all good until someone breaks or disables the plugin.
In this situation, by design, the user doesn't know the password and needs our help, which is fine, but the issue is that QGIS asks for the password once (or more) for every layer in any project they open. This creates a nasty user experience if they open a project with a lot of layers.
Is there a way to suppress the message completely?
I ask for two reasons:
1. QGIS already handles it fine as without the prompt the layers will just fail and we will get the handle bad layers dialogue. This means I don't think the master password prompt is needed at project load at all*.
2. The term 'master' is not favoured anymore and I'd rather this were renamed to 'primary' or 'main' password if we are going to continue having the prompt.
* I think the prompt is only really needed when you click on the authentication tab in the settings.
I'm happy to switch to the developer list and look at whether I can at least do the name change as I'm sure that should be mostly just UI changes but ideally there would just be an option to supress the dialogue completely. I'm aware some will want it so I was just hoping there is a setting under advanced I can use. Does anyone know if there is one?
Thanks,
Paul Wittle
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/data-protection
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240528/86bc8806/attachment.htm>
More information about the QGIS-User
