[Qgis-user] Using Processing for nightly ETL jobs
pathmapper
pathmapper at posteo.de
Thu May 30 00:37:21 PDT 2024
Hi Bernhard,
not sure about the native "Export to PostgreSQL" algorithm, but there's
also a GDAL alg "Export to PostgreSQL (new connection)" which allows to
configure the DB access. Using this one in your model should do the
trick..
Cheers,
Björn
On 30.05.2024 08:47, Bernhard Ströbl via QGIS-User wrote:
> Hello everybody,
> I did some experiments in the last couple days and your help was very
> valuable. I succeeded in creating two models that - when run within
> QGIS or from the console - download data of different types and write
> it into a PostgreSQL database. For automation purposes I want to run
> my models on a Linux server. I am wondering how I would configure the
> database access. The algorythm "Export to PostgreSQL" takes the
> connection name as input. The connection name is the name of a
> pg-connection configured using the GUI (and backed by a saved
> authentication in this case). There will be no GUI (and probably no
> graphic server either) on the server machine. Does anybody know if
> creating a profile with the connection (without authentication) and
> placing that as default profile in the home directory of the user
> running the model will do the trick? Or would I need a different
> approach?
> I cannot try it out because currently I still have no access to the
> server.
> Any help appreciated
> Bernhard
>> Germán Carrillo <carrillo.german at gmail.com> hat am 22.05.2024 23:30
>> CEST geschrieben:
>> Hi All,
>> have a look at:
>> https://github.com/gacarrillor/AppendFeaturesToLayer
>> It has ready-to-use models to perform transform and upsert (update or
>> insert) operations.
>> You can run it via standalone processing (Python) scripts or via QGIS
>> Process.
>> Regards,
>> Germán
>> El mié, 22 may 2024 a las 12:20, Etienne Trimaille via QGIS-User (<
>> qgis-user at lists.osgeo.org>) escribió:
>> > Hi,
>> > https://docs.qgis.org/3.34/en/docs/user_manual/processing/standalone.html
>> > Le mer. 22 mai 2024 à 18:52, NOSPAM via QGIS-User <
>> > qgis-user at lists.osgeo.org> a écrit :
>> >> Dear List,
>> >> has anybody already used QGIS' processing framework for performing
>> >> nightly ETL jobs?
>> >> I need to have nightly jobs run that
>> >> 1) download data (e.g. from a WFS server),
>> >> 2) perform some tasks like renaming fields or the like
>> >> 3) and finally load them into a PostGIS database.
>> >> My idea would be to design the process using the modeller. How can I
>> >> have the thus created model run non interactively?
>> >> Any ideas are welcome
>> >> Bernhard
>> >> _______________________________________________
>> >> QGIS-User mailing list
>> >> QGIS-User at lists.osgeo.org
>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> |\__
>> (:>__)(
>> Soluciones Geoinformáticas Libres
>> http://geotux.tuxfamily.org/
>> https://twitter.com/GeoTux2 <http://twitter.com/GeoTux2>
More information about the QGIS-User
