[Qgis-user] Copy features from multiple layers
Huesmann, Michaela michaela.huesmann at Stadt-Steinfurt.de
Mon Nov 18 00:20:56 PST 2024
Hello Hailiang,
what geometry type and database are your layers you want to combine? And what kind of database should the combined layer be?
For example if you need a shapefile you can not combine objects of different geometry type. I mostly use Geopackage layers where you can combine different geometry types.
Also you must be aware that the combined objects need the same data fields.
The easiest way is to select the needed objects in the base layer and copy them in the cache. Then activate editing mode for the destination layer and paste the features there.
[cid:image001.png at 01DB399B.2BDE61B0]
Another option is to export all objects or selected objects of one layer to a new or existing layer. If the layer already exists you can choose if you want to replace or to add.
Hope it helps you!
Best regards,
Michaela
[Kreisstadt Steinfurt]<http://www.steinfurt.de>
 - 48565 Steinfurt
www.steinfurt.de<http://www.steinfurt.de>
Mit freundlichen Grüßen
im Auftrag
Michaela Huesmann
Geodaten
Fachdienst Tiefbau
Tel.: +49 2552 925 219
Fax:
E-Mail: michaela.huesmann at Stadt-Steinfurt.de<mailto:michaela.huesmann at Stadt-Steinfurt.de>
Bitte denken Sie an die Umwelt, bevor Sie diese E-Mail ausdrucken.
-----Ursprüngliche Nachricht-----
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Hailiang Shen via QGIS-User
Gesendet: Freitag, 15. November 2024 23:30
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Copy features from multiple layers
Hello all,
I am trying to copy features from multiple layers and paste into one, but couldn’t find a way. Am I missing something or this is not supported in QGIS UI?
Thanks,
Hailiang
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241118/6f9b99eb/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241118/6f9b99eb/attachment-0001.png>
Type: image/jpeg
Desc: imaged07870.JPG
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241118/6f9b99eb/attachment-0001.jpe>
More information about the QGIS-User mailing list
