[Qgis-user] Export from csv layer to geopackage changes date and time attributes to string
    Reetz, Michael (NLPVW)
    Michael.Reetz at nlpvw.niedersachsen.de
    Wed Nov 20 23:44:45 PST 2024
Dear Totò,
thank you very much. This solves my problem. Explicitly defining datatypes that are allowed in a geopackage and formatting the date and time values in the csv-file accordingly leads to the required result.
Best regards
Michael
Von: Totò Fiandaca <pigrecoinfinito at gmail.com>
Gesendet: Mittwoch, 20. November 2024 17:18
An: Reetz, Michael (NLPVW) <Michael.Reetz at nlpvw.niedersachsen.de>
Cc: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Export from csv layer to geopackage changes date and time attributes to string
ACHTUNG!! Diese E-Mail erreicht Sie von einem Absender außerhalb der niedersächsischen Landesverwaltungs-Infrastruktur mit TLS-Verschlüsselung. Bitte klicken Sie auf keine Links oder öffnen Sie keine E-Mail-Anhänge, falls Sie den Absender nicht kennen und nicht wissen, ob der Inhalt sicher ist.
Try to create the auxiliary file of the csv file, that is, the file with the same name as the csv file, but with the extension csvt.
The csvt file has only one line and contains the data type.
https://anitagraser.com/2011/03/07/how-to-specify-data-types-of-csv-columns-for-use-in-qgis/
saluti
Il giorno mer 20 nov 2024 alle ore 17:02 Reetz, Michael (NLPVW) via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> ha scritto:
Dear all,
I have added a csv file as layer to my project. Date and time columns are identified correctly. Now I’m trying to export the layer into a geopackage. The date and time attributes are all changed into strings although date and datetime are possible in a geopackage (as far as I know). Any idea why this happens and how to work around this?
Best regards
Michael
Michael Reetz
Datenbanken und Anwendungsentwicklung
Nationalpark-Verwaltung Niedersächsisches Wattenmeer
Virchowstr. 1 | 26382 Wilhelmshaven
Tel.: +49 (0) 4421 911 291
e-mail: michael.reetz at nlpvw.niedersachsen.de<mailto:michael.reetz at nlpv-wattenmeer.niedersachsen.de>
Web: https://www.<https://www./>nationalpark-wattenmeer.de<http://nationalpark-wattenmeer.de>
[cid:image001.png at 01DB3BEA.D1E3B9B0]
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Ing. Salvatore Fiandaca
mobile.:+39 327.493.8955
m: pigrecoinfinito at gmail.com<mailto:pigrecoinfinito at gmail.com>
C.F.: FNDSVT71E29Z103G
P.IVA: 06597870820
membro QGIS Italia - http://qgis.it/
socio GFOSS.it - http://gfoss.it/
member OSGeo - https://www.osgeo.org/member/fiandaca/
blog: https://pigrecoinfinito.com/<https://pigrecoinfinito.com/>
FB: Co-admin - https://www.facebook.com/qgis.it/ <https://www.facebook.com/qgis.it/>
TW: <http://goog_95411464> https://twitter.com/totofiandaca
37°35'11.4"N 14°10'25.1"E - EPSG:4326
“Se la conoscenza deve essere aperta a tutti,
perchè mai limitarne l’accesso?”
R. Stallman
Questo documento, allegati inclusi, contiene informazioni di proprietà di FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario in relazione alle finalità per le quali è stato ricevuto. E' vietata qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega di informare tempestivamente il mittente e distruggere la copia in proprio possesso.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241121/3451e787/attachment.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241121/3451e787/attachment.png>
More information about the QGIS-User
