[Qgis-user] Iterative calls of processing algorithm fails
morten at styrke10.dk
Fri Oct 11 01:38:14 PDT 2024
Hi all,
I have written a processing script for QGIS 3.x, which itself calls a native
processing function (qgis:shortestpathpointtolayer) in a for loop.
from qgis.PyQt.QtCore import QCoreApplication
from qgis.core import (QgsProcessing,
QgsFeatureRequest,
QgsExpression,
QgsProcessingContext,
QgsProcessingException,
QgsProcessingAlgorithm,
QgsProcessingParameterVectorLayer,
QgsProcessingFeatureSourceDefinition)
from qgis import processing
class findDownstreamPathAlgorithm(QgsProcessingAlgorithm):
This is an algorithm that calculates downstream paths on
a simplified network.
INPUT_NETWORK = 'INPUT_NETWORK'
INPUT_VALVES = 'INPUT_VALVES'
def tr(self, string):
return QCoreApplication.translate('Processing', string)
def createInstance(self):
return findDownstreamPathAlgorithm()
def name(self):
return 'iterateclusters'
def displayName(self):
return self.tr('Iterate clusters')
def group(self):
return self.tr('Thvilum')
def groupId(self):
return 'lukkelister'
def shortHelpString(self):
return self.tr("Iterate clusters in a simplified network")
def initAlgorithm(self, config=None):
self.addParameter(
QgsProcessingParameterVectorLayer(
self.INPUT_NETWORK,
self.tr('Netværkslag'),
[QgsProcessing.SourceType.TypeVectorLine]
self.addParameter(
self.INPUT_VALVES,
self.tr('Ventillag'),
[QgsProcessing.SourceType.TypeVectorPoint]
def processAlgorithm(self, parameters, context, feedback):
# Retrieve the feature sources
network = self.parameterAsVectorLayer(
parameters,
self.INPUT_NETWORK,
context
valves = self.parameterAsVectorLayer(
parameters,
self.INPUT_VALVES,
context
if network is None:
raise QgsProcessingException(self.invalidSourceError(parameters,
self.INPUT_NETWORK))
if valves is None:
self.INPUT_VALVES))
# Store inlets from valves layer in separate scractch layer
inlets =
valves.materialize(QgsFeatureRequest(QgsExpression("situation =
'IsInlet'")))
# Collect clusters to evaluate
clusterList = []
for feat in network.getFeatures():
clusterList.append(feat["cluster"])
# Remove duplicates and sort list
clusterList = sorted(set(clusterList))
if len(clusterList) > 0:
total = 100.0 / len(clusterList)
else:
total = 0
isCanceled = False
for current, cluster in enumerate(clusterList):
# Update the progress bar
feedback.setProgress(int(current * total))
valves.selectByExpression("cluster = {} and situation =
'Flow'".format(cluster))
for feat in valves.selectedFeatures():
# Stop the algorithm if cancel button has been clicked
if feedback.isCanceled():
isCanceled = True
break
vertex_id = feat["vertexId"]
valve_geom = feat.geometry()
network.selectByExpression("cluster != {}".format(cluster))
parameters = {
'DEFAULT_DIRECTION' : 2,
'DEFAULT_SPEED' : 50,
'DIRECTION_FIELD' : '',
'END_POINTS' : inlets,
'INPUT' : QgsProcessingFeatureSourceDefinition(
network.id(), selectedFeaturesOnly=True),
'OUTPUT' : 'TEMPORARY_OUTPUT',
#'OUTPUT_NON_ROUTABLE' : 'TEMPORARY_OUTPUT',
'SPEED_FIELD' : '',
'START_POINT' : valve_geom,
'STRATEGY' : 0,
'TOLERANCE' : 0,
'VALUE_BACKWARD' : '',
'VALUE_BOTH' : '',
'VALUE_FORWARD' : ''
result = processing.run("qgis:shortestpathpointtolayer",
parameters, context=context, feedback=feedback, is_child_algorithm=True)
shortest_path =
QgsProcessingContext.takeResultLayer(context, result['OUTPUT'])
# Do something with the path
del shortest_path
if isCanceled:
break
return {self.INPUT_NETWORK: network}
When running this script on QGIS 3.28.4 it runs a couple of iterations and
then raises an exception (access violation) with the following description:
**Python Stack Trace**
Windows fatal exception: access violation
Thread 0x00005d8c (most recent call first):
File
"C:\PROGRA~1/QGIS32~2.4/apps/qgis-ltr/./python/plugins\processing\gui\Algori
thmExecutor.py", line 72 in execute
results, ok = alg.run(parameters, context, feedback, {}, False)
File
"C:\PROGRA~1/QGIS32~2.4/apps/qgis-ltr/./python/plugins\processing\core\Proce
ssing.py", line 187 in runAlgorithm
ret, results = execute(alg, parameters, context, feedback,
catch_exceptions=False)
File
"C:\PROGRA~1/QGIS32~2.4/apps/qgis-ltr/./python/plugins\processing\tools\gene
ral.py", line 116 in run
return Processing.runAlgorithm(algOrName, parameters,
onFinish=post_process, feedback=feedback, context=context)
File
"C:\Users\morte\AppData\Roaming\QGIS\QGIS3\profiles\default\processing\scrip
ts\iterateClusters.py", line 156 in processAlgorithm
result = processing.run("qgis:shortestpathpointtolayer", parameters,
Current thread 0x000075e0 (most recent call first):
File
"C:\PROGRA~1/QGIS32~2.4/apps/qgis-ltr/./python/plugins\processing\Processing
Plugin.py", line 394 in executeAlgorithm
dlg.exec_()
File
"C:\PROGRA~1/QGIS32~2.4/apps/qgis-ltr/./python/plugins\processing\gui\Proces
singToolbox.py", line 234 in executeAlgorithm
self.executeWithGui.emit(alg.id(), self, self.in_place_mode, False)
On QGIS 3.38.3 the process also runs for a couple of iteration and then just
freezes the whole application.
Running a simple (=non processing) version of this script from the Python
console works beautifully on both QGIS versions!
What am I missing in my processing script?
Best regards,
Morten
Morten Storm
Styrke 10 ApS
House of Innovation | Jernbanegade 27 | 6000 Kolding | Denmark
www: https://styrke10.dk
mobile: +45 51 51 09 29
More information about the QGIS-User
