[Qgis-user] QGIS server tutorial: XML file does not appear to have any style information
Meehan, Thomas Barnes tbm247 at mun.ca
Tue Oct 15 19:54:20 PDT 2024
Apologies for polluting the mail serv but solved this issue by removing all
the spaces in the call for the GetMap request. The docs had listed:
http://qgis.demo/qgisserver?  MAP=/home/qgis/projects/world.qgs&
LAYERS=countries&  SERVICE=WMS&  VERSION=1.3.0&  REQUEST=GetMap&
CRS=EPSG:4326&  WIDTH=400&  HEIGHT=200&  BBOX=-90,-180,90,180
Which kept failing to retrieve the map.
A one liner got me the map ->
http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?MAP=/home/qgis/projects/world.qgs&LAYERS=countries&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:4326&WIDTH=400&HEIGHT=200&BBOX=-90,-180,90,180
Yes the server was not broken the call was...
Thomas
On Tue, Oct 15, 2024 at 10:38 PM Meehan, Thomas Barnes <tbm247 at mun.ca>
wrote:
> I am at a loss here. The GetCapabilities request gives me the same layer
> error now with the updated prefix path. Removing the prefix path gives me
> the getcapabilities request back but getting the same service unsupported
> error for the getmap request. Not sure on what to try next. Going to have
> to think on it.
> Thomas
> On Tue, Oct 15, 2024 at 10:22 PM Meehan, Thomas Barnes <tbm247 at mun.ca>
> wrote:
>> After some more digging, I fondant old bug report
>> <https://issues.qgis.org/issues/18230> mentioning to update FcgidInitialEnv
>> QGIS_PREFIX_PATH /usr which I did to no avail but noticed the full path to
>> qgis_mapser included /lib so an update to QGIS_PREFIX_PATH /usr/lib removed
>> the service unknown error only to be hit with another.
>> "Accept" :
>>  "text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/png,image/svg+xml,*/*;q=0.8"
>> "Host" :  "qgis.demo"
>> "User-Agent" :  "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:131.0)
>> Gecko/20100101 Firefox/131.0"
>> 22:12:23 INFO Server[8259]: Using configuration file path from
>> environment: /home/qgis/projects/world.qgs
>> 22:12:23 INFO Server[8259]:   BBOX:-90,-180,90,180
>> 22:12:23 INFO Server[8259]:   CRS:EPSG:4326
>> 22:12:23 INFO Server[8259]:   HEIGHT:200
>> 22:12:23 INFO Server[8259]:   LAYERS:countries
>> 22:12:23 INFO Server[8259]:   MAP:/home/qgis/projects/world.qgs
>> 22:12:23 INFO Server[8259]:   REQUEST:GetMap
>> 22:12:23 INFO Server[8259]:   SERVICE:WMS
>> 22:12:23 INFO Server[8259]:   VERSION:1.3.0
>> 22:12:23 INFO Server[8259]:   WIDTH:400
>> 22:12:23 WARNING [8259]: Invalid data provider spatialite
>> 22:12:23 CRITICAL Server[8259]: Error, Layer(s)
>> airports20160924201425088, countries20160903162230262,
>> countries20160910105437623, places20160903164057641 not valid in project
>> 22:12:23 WARNING Server[8259]: <?xml version="1.0" encoding="UTF-8"?>
>> <ServerException>Layer(s) not valid</ServerException>
>> 22:12:23 INFO Server[8259]: Request finished in 100 ms
>> I wonder if this is an issue with the version of the SQLite database the
>> layers are stored in. The file opens fine in QGIS application and I can see
>> the layers. Looking into spatialite to understand that piece. Just wanted
>> to update the post.
>> Thomas
>> On Tue, Oct 15, 2024 at 9:22 PM Meehan, Thomas Barnes <tbm247 at mun.ca>
>> wrote:
>>> Thanks for the heads up. The curl request does eliminate the XML style
>>> error. The tutorial seems to indicate that the last http request will
>>> return a map but this is not happening.
>>> The curl response:
>>> curl http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?
>>>   LAYERS=countries&
>>>   SERVICE=WMS&
>>>   VERSION=1.3.0&
>>>   REQUEST=GetMap&
>>>   CRS=EPSG:4326&
>>>   WIDTH=400&
>>>   HEIGHT=200&
>>> <ServiceExceptionReport xmlns="http://www.opengis.net/ogc"
>>> version="1.3.0">
>>>  <ServiceException code="Service configuration error">Service unknown or
>>> unsupported. Current supported services (case-sensitive): WMS WFS WCS WMTS
>>> SampleService, or use a WFS3 (OGC API Features) endpoint</ServiceException>
>>> </ServiceExceptionReport>
>>> [1] 5880
>>> [2] 5881
>>> [1]   Done                    MAP=/home/qgis/projects/world.qgs
>>> [3] 5882
>>> [4] 5883
>>> [5] 5884
>>> [2]   Done                    LAYERS=countries
>>> [3]   Done                    SERVICE=WMS
>>> [4]   Done                    VERSION=1.3.0
>>> [6] 5885
>>> [5]   Done                    REQUEST=GetMap
>>> [7] 5886
>>> [6]   Done                    CRS=EPSG:4326
>>> [8] 5887
>>> [7]   Done                    WIDTH=400
>>> Possibly, by continuing, I will need to configure my project properly in
>>> the next section of the tutorial. The docs indicate that "If you obtain the
>>> next image, then QGIS Server is running correctly:" but I do not obtain an
>>> image. The first HTTP request ->
>>> http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>> makes sense that XML is being returned, and it was my misunderstanding that
>>> the XML complaint was normal. Why is the GetMap request failing? Improper
>>> project configuration? It is the default project I curled from the docs.
>>> I Appreciate any knowledge you may bestow upon me :-)
>>> Thomas
>>> On Tue, Oct 15, 2024 at 8:07 PM Jorge Gustavo Rocha via QGIS-User <
>>> qgis-user at lists.osgeo.org> wrote:
>>>> Hi,
>>>> Everything is ok. The server returned an XML, as expected.
>>>> The message "XML file does not appear to have any style information" is
>>>> from your browser; nothing related with QGIS Server. If you do the same
>>>> request with curl or wget, they will not complain.
>>>> Please go on.
>>>> Regards,
>>>> Jorge Gustavo
>>>> On 15/10/24 21:28, Meehan, Thomas Barnes via QGIS-User wrote:
>>>> I am trying to set up QGIS server for the first time. Following the
>>>> online documentation for QGIS 3.34
>>>> <https://docs.qgis.org/3.34/en/docs/server_manual/getting_started.html#serve-a-project>.
>>>> Installed as instructed on the same tutorial for Ubuntu Noble 24.04. I
>>>> followed the instructions and the Apache server answered with the default
>>>> index file at /var/www/html/index.html
>>>> When using the test http ->
>>>> I get the following XML ->
>>>> This XML file does not appear to have any style information associated with it. The document tree is shown below.
>>>> <WMS_Capabilities version="1.3.0" xsi:schemaLocation="http://www.opengis.net/wms http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd http://www.opengis.net/sld http://schemas.opengis.net/sld/1.1.0/sld_capabilities.xsd http://www.qgis.org/wms http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&REQUEST=GetSchemaExtension">
>>>> <Service>
>>>> <Name>WMS</Name>
>>>> <Title>QGIS Server Demo</Title>
>>>> <Abstract>
>>>> This is a simple World map that showcases QGIS Server capabilities.
>>>> </Abstract>
>>>> <KeywordList>
>>>> <Keyword vocabulary="ISO">infoMapAccessService</Keyword>
>>>> <Keyword>QGIS Server World</Keyword>
>>>> </KeywordList>
>>>> <OnlineResource xlink:href="http://qgis.demo/cgi-bin/qgis_mapserv.fcgi" xlink:type="simple"/>
>>>> <ContactInformation>
>>>> <ContactPersonPrimary>
>>>> <ContactPerson>Tudor Bărăscu</ContactPerson>
>>>> <ContactOrganization>qgis.org</ContactOrganization>
>>>> </ContactPersonPrimary>
>>>> <ContactElectronicMailAddress>tudor.barascu at qtibia.ro</ContactElectronicMailAddress>
>>>> </ContactInformation>
>>>> <Fees>conditions unknown</Fees>
>>>> <AccessConstraints>None</AccessConstraints>
>>>> </Service>
>>>> <Capability>
>>>> <Request>
>>>> <GetCapabilities>
>>>> <Format>text/xml</Format>
>>>> <DCPType>
>>>> <HTTP>
>>>> <Get>
>>>> <OnlineResource xlink:href="http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?" xlink:type="simple"/>
>>>> </Get>
>>>> </HTTP>
>>>> </DCPType>
>>>> </GetCapabilities>
>>>> <GetMap>
>>>> <Format>image/jpeg</Format>
>>>> <Format>image/png</Format>
>>>> <Format>image/png; mode=16bit</Format>
>>>> <Format>image/png; mode=8bit</Format>
>>>> <Format>image/png; mode=1bit</Format>
>>>> <Format>application/dxf</Format>
>>>> <Format>application/pdf</Format>
>>>> <DCPType>
>>>> <HTTP>
>>>> <Get>
>>>> </Get>
>>>> </HTTP>
>>>> </DCPType>
>>>> </GetMap>
>>>> <GetFeatureInfo>
>>>> <Format>text/plain</Format>
>>>> <Format>text/html</Format>
>>>> <Format>application/vnd.ogc.gml</Format>
>>>> <Format>application/vnd.ogc.gml/3.1.1</Format>
>>>> <Format>application/json</Format>
>>>> <Format>application/geo+json</Format>
>>>> <DCPType>
>>>> <HTTP>
>>>> <Get>
>>>> </Get>
>>>> </HTTP>
>>>> </DCPType>
>>>> </GetFeatureInfo><sld:GetLegendGraphic>
>>>> <DCPType>
>>>> <HTTP>
>>>> <Get>
>>>> </Get>
>>>> </HTTP>
>>>> </DCPType>
>>>> </sld:GetLegendGraphic><sld:DescribeLayer>
>>>> <DCPType>
>>>> <HTTP>
>>>> <Get>
>>>> </Get>
>>>> </HTTP>
>>>> </DCPType>
>>>> </sld:DescribeLayer><qgs:GetStyles>
>>>> <DCPType>
>>>> <HTTP>
>>>> <Get>
>>>> </Get>
>>>> </HTTP>
>>>> </DCPType>
>>>> </qgs:GetStyles>
>>>> </Request>
>>>> <Exception>
>>>> <Format>XML</Format>
>>>> </Exception>
>>>> <sld:UserDefinedSymbolization RemoteWCS="0" SupportSLD="1" UserStyle="1" InlineFeature="0" RemoteWFS="0" UserLayer="0"/>
>>>> <Layer queryable="1">
>>>> <Abstract>
>>>> </Abstract>
>>>> <KeywordList>
>>>> </KeywordList>
>>>> <CRS>CRS:84</CRS>
>>>> <CRS>EPSG:900913</CRS>
>>>> <CRS>EPSG:4326</CRS>
>>>> <CRS>EPSG:3857</CRS>
>>>> <EX_GeographicBoundingBox>
>>>> <westBoundLongitude>-189</westBoundLongitude>
>>>> <eastBoundLongitude>189</eastBoundLongitude>
>>>> <southBoundLatitude>-123</southBoundLatitude>
>>>> <northBoundLatitude>118</northBoundLatitude>
>>>> </EX_GeographicBoundingBox>
>>>> <BoundingBox CRS="EPSG:3857" maxy="44927335.428" minx="-19970716.649" maxx="19970716.649" miny="-44927335.428"/>
>>>> <BoundingBox CRS="EPSG:4326" maxy="189" minx="-123" maxx="118" miny="-189"/>
>>>> <BoundingBox CRS="EPSG:900913" maxy="30772816.154" minx="-19960441.004" maxx="19960441.004" miny="-19293806.199"/>
>>>> <Name>airports</Name>
>>>> <Title>airports</Title>
>>>> <CRS>CRS:84</CRS>
>>>> <westBoundLongitude>-175.135635</westBoundLongitude>
>>>> <eastBoundLongitude>179.195443</eastBoundLongitude>
>>>> <southBoundLatitude>-53.781475</southBoundLatitude>
>>>> <northBoundLatitude>78.246717</northBoundLatitude>
>>>> <BoundingBox CRS="EPSG:3857" maxy="14502137.594" minx="-19496009.708" maxx="19947945.359" miny="-7128878.351"/>
>>>> <BoundingBox CRS="EPSG:4326" maxy="179.195443" minx="-53.781475" maxx="78.246717" miny="-175.135635"/>
>>>> <BoundingBox CRS="EPSG:900913" maxy="14502137.594" minx="-19496009.708" maxx="19947945.359" miny="-7128878.351"/>
>>>> <Style>
>>>> <Name>default</Name>
>>>> <Title>default</Title>
>>>> <LegendURL>
>>>> <OnlineResource xlink:href="http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetLegendGraphic&LAYER=airports&FORMAT=image/png&STYLE=default&SLD_VERSION=1.1.0" xlink:type="simple"/>
>>>> </LegendURL>
>>>> </Style>
>>>> <MinScaleDenominator>1</MinScaleDenominator>
>>>> <MaxScaleDenominator>3.66192e+06</MaxScaleDenominator>
>>>> </Layer>
>>>> <Name>places</Name>
>>>> <Title>places</Title>
>>>> <CRS>CRS:84</CRS>
>>>> <westBoundLongitude>-175.220565</westBoundLongitude>
>>>> <eastBoundLongitude>179.216648</eastBoundLongitude>
>>>> <southBoundLatitude>-41.299974</southBoundLatitude>
>>>> <northBoundLatitude>64.150024</northBoundLatitude>
>>>> <BoundingBox CRS="EPSG:3857" maxy="9387963.682" minx="-19505464.015" maxx="19950305.897" miny="-5056688.948"/>
>>>> <BoundingBox CRS="EPSG:4326" maxy="179.216648" minx="-41.299974" maxx="64.150024" miny="-175.220565"/>
>>>> <BoundingBox CRS="EPSG:900913" maxy="9387963.682" minx="-19505464.015" maxx="19950305.897" miny="-5056688.948"/>
>>>> <Style>
>>>> <LegendURL>
>>>> <OnlineResource xlink:href="http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetLegendGraphic&LAYER=places&FORMAT=image/png&STYLE=default&SLD_VERSION=1.1.0" xlink:type="simple"/>
>>>> </LegendURL>
>>>> </Style>
>>>> </Layer>
>>>> <Name>countries</Name>
>>>> <Title>countries</Title>
>>>> <CRS>CRS:84</CRS>
>>>> <westBoundLongitude>-180</westBoundLongitude>
>>>> <eastBoundLongitude>180</eastBoundLongitude>
>>>> <southBoundLatitude>-90</southBoundLatitude>
>>>> <northBoundLatitude>83.623597</northBoundLatitude>
>>>> <BoundingBox CRS="EPSG:3857" maxy="18418382.138" minx="-20037508.343" maxx="20037508.343" miny="-44927335.428"/>
>>>> <BoundingBox CRS="EPSG:4326" maxy="180" minx="-90" maxx="83.623597" miny="-180"/>
>>>> <BoundingBox CRS="EPSG:900913" maxy="18418382.138" minx="-20037508.343" maxx="20037508.343" miny="-242528680.944"/>
>>>> <Style>
>>>> <Name>classified_by_name</Name>
>>>> <Title>classified_by_name</Title>
>>>> <LegendURL>
>>>> <OnlineResource xlink:href="http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetLegendGraphic&LAYER=countries&FORMAT=image/png&STYLE=classified_by_name&SLD_VERSION=1.1.0" xlink:type="simple"/>
>>>> </LegendURL>
>>>> </Style>
>>>> <Style>
>>>> <Name>classified_by_population</Name>
>>>> <Title>classified_by_population</Title>
>>>> <LegendURL>
>>>> <OnlineResource xlink:href="http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetLegendGraphic&LAYER=countries&FORMAT=image/png&STYLE=classified_by_population&SLD_VERSION=1.1.0" xlink:type="simple"/>
>>>> </LegendURL>
>>>> </Style>
>>>> </Layer>
>>>> <Name>countries_shapeburst</Name>
>>>> <Title>countries_shapeburst</Title>
>>>> <CRS>CRS:84</CRS>
>>>> <Style>
>>>> <Name>blue</Name>
>>>> <Title>blue</Title>
>>>> <LegendURL>
>>>> <OnlineResource xlink:href="http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetLegendGraphic&LAYER=countries_shapeburst&FORMAT=image/png&STYLE=blue&SLD_VERSION=1.1.0" xlink:type="simple"/>
>>>> </LegendURL>
>>>> </Style>
>>>> <Style>
>>>> <LegendURL>
>>>> <OnlineResource xlink:href="http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetLegendGraphic&LAYER=countries_shapeburst&FORMAT=image/png&STYLE=default&SLD_VERSION=1.1.0" xlink:type="simple"/>
>>>> </LegendURL>
>>>> </Style>
>>>> <Style>
>>>> <Name>green</Name>
>>>> <Title>green</Title>
>>>> <LegendURL>
>>>> <OnlineResource xlink:href="http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetLegendGraphic&LAYER=countries_shapeburst&FORMAT=image/png&STYLE=green&SLD_VERSION=1.1.0" xlink:type="simple"/>
>>>> </LegendURL>
>>>> </Style>
>>>> <MaxScaleDenominator>2.5e+08</MaxScaleDenominator>
>>>> </Layer>
>>>> </Layer>
>>>> </Capability>
>>>> </WMS_Capabilities>
>>>> I get a similar problem from the final request ->
>>>> <ServiceExceptionReport version="1.3.0">
>>>> Service unknown or unsupported. Current supported services (case-sensitive): WMS WFS WCS WMTS SampleService, or use a WFS3 (OGC API Features) endpoint
>>>> </ServiceException>
>>>> I assume this is some type of basic configuration problem but have no way of being directed to what the problem may be.
>>>> I get the proper response when testing the server by hostname ->
>>>> /usr/lib/cgi-bin/qgis_mapserv.fcgi
>>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment variable.
>>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP environment variable.
>>>> "Loading native module /usr/lib/qgis/server/liblandingpage.so"
>>>> "Loading native module /usr/lib/qgis/server/libwcs.so"
>>>> "Loading native module /usr/lib/qgis/server/libwfs.so"
>>>> "Loading native module /usr/lib/qgis/server/libwfs3.so"
>>>> "Loading native module /usr/lib/qgis/server/libwms.so"
>>>> "Loading native module /usr/lib/qgis/server/libwmts.so"
>>>> Content-Length: 0
>>>> Location: http:/index.json
>>>> Server:  QGIS FCGI server - QGIS version 3.38.3-Grenoble
>>>> Status:  302
>>>> The APACHE error log ->
>>>> "Accept" :  "text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/png,image/svg+xml,*/*;q=0.8"
>>>> "User-Agent" :  "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:131.0) Gecko/20100101 Firefox/131.0"
>>>> 15:58:54 INFO Server[10767]: Using configuration file path from environment: /home/qgis/projects/world.qgs
>>>> 15:58:54 INFO Server[10767]: REQUEST:GetCapabilities
>>>> 15:58:54 INFO Server[10767]: SERVICE:WMS
>>>> 15:58:54 INFO Server[10767]: VERSION:1.3.0
>>>> 15:58:54 WARNING Server[10767]: WMS capabilities document not found in cache
>>>> 15:58:54 WARNING Server[10767]: Set WMS capabilities document in cache
>>>> 15:58:54 INFO Server[10767]: Request finished in 207 ms
>>>> 16:00:03 INFO Server[10767]: ******************** New request ***************
>>>> 16:00:03 INFO Server[10767]: Request URL: http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>> 16:00:03 INFO Server[10767]: Environment:
>>>> 16:00:03 INFO Server[10767]: ------------------------------------------------
>>>> 16:00:03 INFO Server[10767]: SERVER_NAME: qgis.demo
>>>> 16:00:03 INFO Server[10767]: REQUEST_URI: /cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>> 16:00:03 INFO Server[10767]: SCRIPT_NAME: /cgi-bin/qgis_mapserv.fcgi
>>>> 16:00:03 INFO Server[10767]: REMOTE_ADDR: 127.0.0.1
>>>> 16:00:03 INFO Server[10767]: SERVER_PORT: 80
>>>> 16:00:03 INFO Server[10767]: QUERY_STRING: SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>> 16:00:03 INFO Server[10767]: REQUEST_METHOD: GET
>>>> 16:00:03 INFO Server[10767]: QGIS_PROJECT_FILE: /home/qgis/projects/world.qgs
>>>> 16:00:03 INFO Server[10767]: SERVER_PROTOCOL: HTTP/1.1
>>>> Headers:
>>>> 16:00:03 INFO Server[10767]: Using configuration file path from environment: /home/qgis/projects/world.qgs
>>>> 16:00:03 INFO Server[10767]: REQUEST:GetCapabilities
>>>> 16:00:03 INFO Server[10767]: SERVICE:WMS
>>>> 16:00:03 INFO Server[10767]: VERSION:1.3.0
>>>> 16:00:03 WARNING Server[10767]: Found WMS capabilities document in cache
>>>> 16:00:03 INFO Server[10767]: Request finished in 0 ms
>>>> 16:00:45 INFO Server[10767]: ******************** New request ***************
>>>> 16:00:45 INFO Server[10767]: Request URL: http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?  MAP=/home/qgis/projects/world.qgs&  LAYERS=countries&  SERVICE=WMS&  VERSION=1.3.0&  REQUEST=GetMap&  CRS=EPSG:4326&  WIDTH=400&  HEIGHT=200&  BBOX=-90,-180,90,180
>>>> 16:00:45 INFO Server[10767]: Environment:
>>>> 16:00:45 INFO Server[10767]: ------------------------------------------------
>>>> 16:00:45 INFO Server[10767]: SERVER_NAME: qgis.demo
>>>> 16:00:45 INFO Server[10767]: REQUEST_URI: /cgi-bin/qgis_mapserv.fcgi?%20%20MAP=/home/qgis/projects/world.qgs&%20%20LAYERS=countries&%20%20SERVICE=WMS&%20%20VERSION=1.3.0&%20%20REQUEST=GetMap&%20%20CRS=EPSG:4326&%20%20WIDTH=400&%20%20HEIGHT=200&%20%20BBOX=-90,-180,90,180
>>>> 16:00:45 INFO Server[10767]: SCRIPT_NAME: /cgi-bin/qgis_mapserv.fcgi
>>>> 16:00:45 INFO Server[10767]: REMOTE_ADDR: 127.0.0.1
>>>> 16:00:45 INFO Server[10767]: SERVER_PORT: 80
>>>> 16:00:45 INFO Server[10767]: QUERY_STRING: %20%20MAP=/home/qgis/projects/world.qgs&%20%20LAYERS=countries&%20%20SERVICE=WMS&%20%20VERSION=1.3.0&%20%20REQUEST=GetMap&%20%20CRS=EPSG:4326&%20%20WIDTH=400&%20%20HEIGHT=200&%20%20BBOX=-90,-180,90,180
>>>> 16:00:45 INFO Server[10767]: REQUEST_METHOD: GET
>>>> 16:00:45 INFO Server[10767]: QGIS_PROJECT_FILE: /home/qgis/projects/world.qgs
>>>> 16:00:45 INFO Server[10767]: SERVER_PROTOCOL: HTTP/1.1
>>>> Headers:
>>>> 16:00:45 INFO Server[10767]: Using configuration file path from environment: /home/qgis/projects/world.qgs
>>>> 16:00:45 INFO Server[10767]:   BBOX:-90,-180,90,180
>>>> 16:00:45 INFO Server[10767]:   CRS:EPSG:4326
>>>> 16:00:45 INFO Server[10767]:   HEIGHT:200
>>>> 16:00:45 INFO Server[10767]:   LAYERS:countries
>>>> 16:00:45 INFO Server[10767]:   MAP:/home/qgis/projects/world.qgs
>>>> 16:00:45 INFO Server[10767]:   REQUEST:GetMap
>>>> 16:00:45 INFO Server[10767]:   SERVICE:WMS
>>>> 16:00:45 INFO Server[10767]:   VERSION:1.3.0
>>>> 16:00:45 INFO Server[10767]:   WIDTH:400
>>>> 16:00:45 INFO Server[10767]: Trying URL path: '/cgi-bin/qgis_mapserv.fcgi' for '/wfs3'
>>>> 16:00:45 INFO Server[10767]: Trying URL path: '/cgi-bin/qgis_mapserv.fcgi' for '/'
>>>> 16:00:45 CRITICAL Server[10767]: Service  is not registered
>>>> 16:00:45 WARNING Server[10767]: <?xml version="1.0" encoding="UTF-8"?>
>>>> <ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc">
>>>>  <ServiceException code="Service configuration error">Service unknown or unsupported. Current supported services (case-sensitive): WMS WFS WCS WMTS SampleService, or use a WFS3 (OGC API Features) endpoint</ServiceException>
>>>> 16:00:45 INFO Server[10767]: Request finished in 0 ms
>>>> 16:04:48 INFO Server[10767]: ******************** New request ***************
>>>> 16:04:48 INFO Server[10767]: Request URL: http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>> 16:04:48 INFO Server[10767]: Environment:
>>>> 16:04:48 INFO Server[10767]: ------------------------------------------------
>>>> 16:04:48 INFO Server[10767]: SERVER_NAME: qgis.demo
>>>> 16:04:48 INFO Server[10767]: REQUEST_URI: /cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>> 16:04:48 INFO Server[10767]: SCRIPT_NAME: /cgi-bin/qgis_mapserv.fcgi
>>>> 16:04:48 INFO Server[10767]: REMOTE_ADDR: 127.0.0.1
>>>> 16:04:48 INFO Server[10767]: SERVER_PORT: 80
>>>> 16:04:48 INFO Server[10767]: QUERY_STRING: SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>> 16:04:48 INFO Server[10767]: REQUEST_METHOD: GET
>>>> 16:04:48 INFO Server[10767]: QGIS_PROJECT_FILE: /home/qgis/projects/world.qgs
>>>> 16:04:48 INFO Server[10767]: SERVER_PROTOCOL: HTTP/1.1
>>>> Headers:
>>>> 16:04:48 INFO Server[10767]: Using configuration file path from environment: /home/qgis/projects/world.qgs
>>>> 16:04:48 INFO Server[10767]: REQUEST:GetCapabilities
>>>> 16:04:48 INFO Server[10767]: SERVICE:WMS
>>>> 16:04:48 INFO Server[10767]: VERSION:1.3.0
>>>> 16:04:48 WARNING Server[10767]: Found WMS capabilities document in cache
>>>> 16:04:48 INFO Server[10767]: Request finished in 0 ms
>>>> 16:13:01 INFO Server[10767]: ******************** New request ***************
>>>> 16:13:01 INFO Server[10767]: Request URL: http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>> 16:13:01 INFO Server[10767]: Environment:
>>>> 16:13:01 INFO Server[10767]: ------------------------------------------------
>>>> 16:13:01 INFO Server[10767]: SERVER_NAME: qgis.demo
>>>> 16:13:01 INFO Server[10767]: REQUEST_URI: /cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>> 16:13:01 INFO Server[10767]: SCRIPT_NAME: /cgi-bin/qgis_mapserv.fcgi
>>>> 16:13:01 INFO Server[10767]: REMOTE_ADDR: 127.0.0.1
>>>> 16:13:01 INFO Server[10767]: SERVER_PORT: 80
>>>> 16:13:01 INFO Server[10767]: QUERY_STRING: SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>> 16:13:01 INFO Server[10767]: REQUEST_METHOD: GET
>>>> 16:13:01 INFO Server[10767]: QGIS_PROJECT_FILE: /home/qgis/projects/world.qgs
>>>> 16:13:01 INFO Server[10767]: SERVER_PROTOCOL: HTTP/1.1
>>>> Headers:
>>>> 16:13:01 INFO Server[10767]: Using configuration file path from environment: /home/qgis/projects/world.qgs
>>>> 16:13:01 INFO Server[10767]: REQUEST:GetCapabilities
>>>> 16:13:01 INFO Server[10767]: SERVICE:WMS
>>>> 16:13:01 INFO Server[10767]: VERSION:1.3.0
>>>> 16:13:01 WARNING Server[10767]: Found WMS capabilities document in cache
>>>> 16:13:01 INFO Server[10767]: Request finished in 0 ms
>>>> 16:20:08 INFO Server[10767]: ******************** New request ***************
>>>> 16:20:08 INFO Server[10767]: Request URL: http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?  MAP=/home/qgis/projects/world.qgs&  LAYERS=countries&  SERVICE=WMS&  VERSION=1.3.0&  REQUEST=GetMap&  CRS=EPSG:4326&  WIDTH=400&  HEIGHT=200&  BBOX=-90,-180,90,180
>>>> 16:20:08 INFO Server[10767]: Environment:
>>>> 16:20:08 INFO Server[10767]: ------------------------------------------------
>>>> 16:20:08 INFO Server[10767]: SERVER_NAME: qgis.demo
>>>> 16:20:08 INFO Server[10767]: REQUEST_URI: /cgi-bin/qgis_mapserv.fcgi?%20%20MAP=/home/qgis/projects/world.qgs&%20%20LAYERS=countries&%20%20SERVICE=WMS&%20%20VERSION=1.3.0&%20%20REQUEST=GetMap&%20%20CRS=EPSG:4326&%20%20WIDTH=400&%20%20HEIGHT=200&%20%20BBOX=-90,-180,90,180
>>>> 16:20:08 INFO Server[10767]: SCRIPT_NAME: /cgi-bin/qgis_mapserv.fcgi
>>>> 16:20:08 INFO Server[10767]: REMOTE_ADDR: 127.0.0.1
>>>> 16:20:08 INFO Server[10767]: SERVER_PORT: 80
>>>> 16:20:08 INFO Server[10767]: QUERY_STRING: %20%20MAP=/home/qgis/projects/world.qgs&%20%20LAYERS=countries&%20%20SERVICE=WMS&%20%20VERSION=1.3.0&%20%20REQUEST=GetMap&%20%20CRS=EPSG:4326&%20%20WIDTH=400&%20%20HEIGHT=200&%20%20BBOX=-90,-180,90,180
>>>> 16:20:08 INFO Server[10767]: REQUEST_METHOD: GET
>>>> 16:20:08 INFO Server[10767]: QGIS_PROJECT_FILE: /home/qgis/projects/world.qgs
>>>> 16:20:08 INFO Server[10767]: SERVER_PROTOCOL: HTTP/1.1
>>>> Headers:
>>>> 16:20:08 INFO Server[10767]: Using configuration file path from environment: /home/qgis/projects/world.qgs
>>>> 16:20:08 INFO Server[10767]:   BBOX:-90,-180,90,180
>>>> 16:20:08 INFO Server[10767]:   CRS:EPSG:4326
>>>> 16:20:08 INFO Server[10767]:   HEIGHT:200
>>>> 16:20:08 INFO Server[10767]:   LAYERS:countries
>>>> 16:20:08 INFO Server[10767]:   MAP:/home/qgis/projects/world.qgs
>>>> 16:20:08 INFO Server[10767]:   REQUEST:GetMap
>>>> 16:20:08 INFO Server[10767]:   SERVICE:WMS
>>>> 16:20:08 INFO Server[10767]:   VERSION:1.3.0
>>>> 16:20:08 INFO Server[10767]:   WIDTH:400
>>>> 16:20:08 INFO Server[10767]: Trying URL path: '/cgi-bin/qgis_mapserv.fcgi' for '/wfs3'
>>>> 16:20:08 INFO Server[10767]: Trying URL path: '/cgi-bin/qgis_mapserv.fcgi' for '/'
>>>> 16:20:08 CRITICAL Server[10767]: Service  is not registered
>>>> 16:20:08 WARNING Server[10767]: <?xml version="1.0" encoding="UTF-8"?>
>>>> I left the qgis.demo hostname there as my hostname, host file was updated as per instruction.
>>>> I can not find any troubleshooting information for this. Does anyone have any suggestions on places to look. I saw mention that I may need to pint the var/www/html file to the proper project but this was not mentioned in the tutorial.
>>>> QGIS new user
>>>> _______________________________________________
>>>> QGIS-User mailing listQGIS-User at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241015/b0e9cabd/attachment-0001.htm>
More information about the QGIS-User mailing list
