[Qgis-user] Adding QgsLayoutItemPolyline to the print layout legend
Asim al-sofi asim56 at gmail.com
Sat Oct 19 16:16:02 PDT 2024
Hi all
Iam trying to add legend to the print layout of a polyline that have been
created using QgsLayoutItemPolyline.
I managed to draw the polyline on the map composer and play with its
properties, but could not add the corresponding line to the legend.
Any ideas/suggestions?
The code that corresponds to the legend is:
polygon2 = QPolygonF()
polygon2.append(QPointF(50.0, 150.0))
polygon2.append(QPointF(150.0, 80.0))
polygon2.append(QPointF(250.0, 100.0))
polygon2.append(QPointF(10.0, 200.0))
layoutItemPolyline = QgsLayoutItemPolyline(polygon2, layout)
layout.addLayoutItem(layoutItemPolyline)
props = {}
props["color"] = "green"
props["style"] = "solid"
symbol = QgsLineSymbol.createSimple(props)
layoutItemPolyline.setSymbol(symbol)
legend = QgsLayoutItemLegend(layout)
legend.setAutoUpdateModel(False)
root = legend.model().rootGroup()
legend.setTitle("Legend")
legend.setLinkedMap(map)
legend.setLegendFilterByMapEnabled(True)
layout.addLayoutItem(legend)
legend.attemptMove(QgsLayoutPoint(235, 36, QgsUnitTypes.LayoutMillimeters))
Thanks in advance
Kind regards,
Asim
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241020/15d92b53/attachment.htm>
More information about the QGIS-User mailing list
