[Qgis-user] seeing coordinates in the data table
Michael Dufty MDufty at mbsenvironmental.com.au
Wed Sep 4 07:26:58 PDT 2024
Probably not what you are after, but if you go to options-data sources you can set copy features as to "plain text, wkt geometry" then when you copy data out of the table and paste it into a text file or spreadsheet it will have a wkt geometry column (I think may truncate long wkts though).
I rather liked the feature of Manifold GIS which has "intrinsic columns" in the tables, these are hidden columns with coordinates, areas, length etc, which you can just turn on if you want to see them rather than having to calculate, would have been even better if you could default them to visible.  I've long intended to make a qgis feature request for it.
Michael Dufty
Senior Environmental Engineer
MBS ENVIRONMENTAL
4 Cook Street, West Perth  WA 6005
t:    08 9226-3166
e:   mdufty at mbsenvironmental.com.au
w:   www.mbsenvironmental.com.au
Disclaimer:
The information contained in this message is intended for those to whom it is addressed. It may contain confidential or privileged information and if you are not the intended recipient, you must not copy, distribute or take any action in reliance on it. If you received this message in error please destroy it and reply to the sender immediately or contact Martinick Bosch Sell Pty Ltd. on +61 8 9226 3166 immediately. All care has been taken to ensure that this message and any attachments are virus free; we do not accept responsibility for any virus infections caused by receipt of this message
-----Original Message-----
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Greg Troxel via QGIS-User
Sent: Tuesday, 3 September 2024 3:38 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] seeing coordinates in the data table
When I open the data table, I can't find a way to see the geometry object, in either layer CRS or project CRS.
I do see a way to generate a layer which has the attributes as fields:
  https://docs.qgis.org/3.34/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#add-geometry-attributes
But I don't really  want to make a layer (which is a copy not a view).
I just want the data table to show me the geometry, because it is a column and has a value.  (I don't mind that it is read only.)
Perhaps I should be using postgis and views to make a layer with extra fields.  Any other advice?
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User mailing list
