[Qgis-user] QGIS Server and PostgreSQL projects
Jorge Gustavo Rocha
jgr at geomaster.pt
Fri Sep 6 05:56:25 PDT 2024
It is possible and works pretty well. I do it with dozens of QGIS projects.
I use a rewrite rule in Apache to point to the project on the database.
Check our this can be done is this comment:
https://github.com/qgis/QGIS/issues/31192#issuecomment-756105179
Best regards,
Jorge
On 06/09/24 12:41, User Adminofff via QGIS-User wrote:
> Hi,
> I'm trying to make QGIS Server to serve projects from PostgreSQL
> database on the web.
> Could anyone tell me please, is it possible to do that, or I can serve
> only files?
> The general workflow should look like this:
> 1. Operators with QGIS Desktop are connecting to PostgreSQL, and
> create/modify projects in it.
> No files are involved. This part works, I was able to save test
> project on one system, and open it on the other.
> 2. After finishing project creation/modification, Operators send a
> link to it to the consumers/implementors.
> The idea is to be able to view the project in a browser on any device.
> No editing is needed, at least at this moment.
> I've installed QGIS Server on the same host as PostgreSQL, set
> nginx/related stuff, and tested that it successfully serves file project.
> Then I've tried to get the project from database. qgis user, under
> which QGIS server is run, was allowed passwordless connection to
> PostgreSQL via localhost.
> Having test URL for file like this
> https://domain.com/qgisserver/cgi-bin/qgis_mapserv.fcgi?LAYERS=countries&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:4326&WIDTH=400&HEIGHT=200&BBOX=-90,-180,90,180&MAP=/home/qgis/projects/world.qgs
> I've replaced file path with naive PostgreSQL URL like this
> https://domain.com/qgisserver/cgi-bin/qgis_mapserv.fcgi?LAYERS=countries&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:4326&WIDTH=400&HEIGHT=200&BBOX=-90,-180,90,180&MAP=postgresql://127.0.0.1:5432?sslmode=disable&dbname=qgis&schema=world&project=world
> But got this error:
> <ServerException>
> Project file error. For OWS services: please provide a SERVICE and a
> MAP parameter pointing to a valid QGIS project file
> </ServerException>
> The error says that QGIS Server wants file, no mentions about database.
> On other hand, documentation below says that for MAP parameter either
> file path or PostgreSQL URL is needed, so it should work?
> https://docs.qgis.org/3.34/en/docs/server_manual/config.html#qgis-server-envvar
> QGIS_PROJECT_FILE
> The .qgs or .qgz project file, normally passed as a parameter in the
> query string (with MAP), you can also set it as an environment
> variable (for example by using mod_rewrite Apache module).
> **Note that you may also indicate a project stored in PostgreSQL**,
> e.g.
> postgresql://localhost:5432?sslmode=disable&dbname=mydb&schema=myschema&project=myproject
> or inside a geopackage file, e.g.
> geopackage:/path/to/geopackage/file.gpkg?projectName=myProjectName.
> Searching in the Internet for the error above, I've found this bug report
> From which I've got the idea to encode PostgreSQL URL in test URL, but
> it didn't work with the same error as above.
> Also, it looks like report author is connecting with QGIS Desktop to
> QGIS Server, not browser, so this is not my case?
> Also-also, as I've stuck with nginx for unrelated to QGIS reasons, I
> cannot test proposed there Apache rewrite magic.
> I've tried to see if there is anything useful in QGIS Server logs, but
> there are no any related messages in them.
> I've set QGIS_SERVER_LOG_PROFILE to true, but that didn't change
> anything. I see my request to QGIS server only in nginx logs, but
> nothing in QGIS Server logs, and no even failed connection attempts in
> PostgreSQL logs.
> So, is there any way to have PostreSQL projects served via QGIS
> Server, or I can use only files?
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Jorge Gustavo Rocha
Geomaster, LDA
"Take the open source journey with us"
VAT/NIF: PT 510 906 109
Phone: +351 253 257 173 (landline)
Mobile: +351 910 333 888 (cellular)
Rua Afonso Palmeira, 31, 7 D
4715-278 Braga
PORTUGAL
GPS 41.54627, -8.40432
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240906/c794ced9/attachment.htm>
More information about the QGIS-User
