[Qgis-user] QGIS Server and PostgreSQL projects
Abel Gonzalez abel.gonzalez.c at gmail.com
Fri Sep 6 07:25:58 PDT 2024
Hi! I just installed QGIS server on my windows server under Apache HTTPD
and postgres in the sabe server and works fine.  There after if you want to
show the qgis projects on a map you should install QGIS Web Client or
Lizmap. In order to serve WMS, WFS , etc qgis project should no be saved on
postgis, otherwise will require extra configuration.
Good luck!
Abel
Den fre 6 sep. 2024 16:09User Adminofff via QGIS-User <
qgis-user at lists.osgeo.org> skrev:
> Hi,
> I'm trying to make QGIS Server to serve projects from PostgreSQL database
> on the web.
> Could anyone tell me please, is it possible to do that, or I can serve
> only files?
> The general workflow should look like this:
> 1. Operators with QGIS Desktop are connecting to PostgreSQL, and
> create/modify projects in it.
> No files are involved. This part works, I was able to save test project on
> one system, and open it on the other.
> 2. After finishing project creation/modification, Operators send a link to
> it to the consumers/implementors.
> The idea is to be able to view the project in a browser on any device. No
> editing is needed, at least at this moment.
> I've installed QGIS Server on the same host as PostgreSQL, set
> nginx/related stuff, and tested that it successfully serves file project.
> Then I've tried to get the project from database. qgis user, under which
> QGIS server is run, was allowed passwordless connection to PostgreSQL via
> localhost.
> Having test URL for file like this
> https://domain.com/qgisserver/cgi-bin/qgis_mapserv.fcgi?LAYERS=countries&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:4326&WIDTH=400&HEIGHT=200&BBOX=-90,-180,90,180&MAP=/home/qgis/projects/world.qgs
> I've replaced file path with naive PostgreSQL URL like this
> https://domain.com/qgisserver/cgi-bin/qgis_mapserv.fcgi?LAYERS=countries&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:4326&WIDTH=400&HEIGHT=200&BBOX=-90,-180,90,180&MAP=postgresql://127.0.0.1:5432?sslmode=disable&dbname=qgis&schema=world&project=world
> But got this error:
> <ServerException>
> Project file error. For OWS services: please provide a SERVICE and a MAP
> parameter pointing to a valid QGIS project file
> </ServerException>
> The error says that QGIS Server wants file, no mentions about database.
> On other hand, documentation below says that for MAP parameter either file
> path or PostgreSQL URL is needed, so it should work?
> https://docs.qgis.org/3.34/en/docs/server_manual/config.html#qgis-server-envvar
> QGIS_PROJECT_FILE
> The .qgs or .qgz project file, normally passed as a parameter in the query
> string (with MAP), you can also set it as an environment variable (for
> example by using mod_rewrite Apache module).
> **Note that you may also indicate a project stored in PostgreSQL**, e.g.
> postgresql://localhost:5432?sslmode=disable&dbname=mydb&schema=myschema&project=myproject
> or inside a geopackage file, e.g.
> geopackage:/path/to/geopackage/file.gpkg?projectName=myProjectName.
> Searching in the Internet for the error above, I've found this bug report
> https://github.com/qgis/QGIS/issues/31192
> From which I've got the idea to encode PostgreSQL URL in test URL, but it
> didn't work with the same error as above.
> Also, it looks like report author is connecting with QGIS Desktop to QGIS
> Server, not browser, so this is not my case?
> Also-also, as I've stuck with nginx for unrelated to QGIS reasons, I
> cannot test proposed there Apache rewrite magic.
> I've tried to see if there is anything useful in QGIS Server logs, but
> there are no any related messages in them.
> I've set QGIS_SERVER_LOG_PROFILE to true, but that didn't change anything.
> I see my request to QGIS server only in nginx logs, but nothing in QGIS
> Server logs, and no even failed connection attempts in PostgreSQL logs.
> So, is there any way to have PostreSQL projects served via QGIS Server, or
> I can use only files?
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240906/74c7f27b/attachment.htm>
More information about the QGIS-User mailing list
