[Qgis-user] QGIS Server and PostgreSQL projects
User Adminoff
satadm at gmail.com
Sat Sep 7 03:21:02 PDT 2024
Hi Alessandro,
This is an interesting feature, but am I see right that it doesn't have
any access rights restrictions?
Alessandro Pasotti wrote:
> Another possibility:
> https://docs.qgis.org/3.34/en/docs/server_manual/catalog.html
> You will need co configure an env variable:
> QGIS_SERVER_LANDING_PAGE_PROJECTS_PG_CONNECTIONS
> all projects stored in the connections above will be listed in the
> catalog.
> On Fri, Sep 6, 2024 at 4:26 PM Abel Gonzalez via QGIS-User
> <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>> wrote:
> Hi! I just installed QGIS server on my windows server under Apache
> HTTPD and postgres in the sabe server and works fine. There after
> if you want to show the qgis projects on a map you should install
> QGIS Web Client or Lizmap. In order to serve WMS, WFS , etc qgis
> project should no be saved on postgis, otherwise will require
> extra configuration.
> Good luck!
> Abel
> Den fre 6 sep. 2024 16:09User Adminofff via QGIS-User
> <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>> skrev:
> Hi,
> I'm trying to make QGIS Server to serve projects from
> PostgreSQL database on the web.
> Could anyone tell me please, is it possible to do that, or I
> can serve only files?
> The general workflow should look like this:
> 1. Operators with QGIS Desktop are connecting to PostgreSQL,
> and create/modify projects in it.
> No files are involved. This part works, I was able to save
> test project on one system, and open it on the other.
> 2. After finishing project creation/modification, Operators
> send a link to it to the consumers/implementors.
> The idea is to be able to view the project in a browser on any
> device. No editing is needed, at least at this moment.
> I've installed QGIS Server on the same host as PostgreSQL, set
> nginx/related stuff, and tested that it successfully serves
> file project.
> Then I've tried to get the project from database. qgis user,
> under which QGIS server is run, was allowed passwordless
> connection to PostgreSQL via localhost.
> Having test URL for file like this
> https://domain.com/qgisserver/cgi-bin/qgis_mapserv.fcgi?LAYERS=countries&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:4326&WIDTH=400&HEIGHT=200&BBOX=-90,-180,90,180&MAP=/home/qgis/projects/world.qgs
> I've replaced file path with naive PostgreSQL URL like this
> https://domain.com/qgisserver/cgi-bin/qgis_mapserv.fcgi?LAYERS=countries&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:4326&WIDTH=400&HEIGHT=200&BBOX=-90,-180,90,180&MAP=postgresql://127.0.0.1:5432?sslmode=disable&dbname=qgis&schema=world&project=world
> But got this error:
> <ServerException>
> Project file error. For OWS services: please provide a SERVICE
> and a MAP parameter pointing to a valid QGIS project file
> </ServerException>
> The error says that QGIS Server wants file, no mentions about
> database.
> On other hand, documentation below says that for MAP parameter
> either file path or PostgreSQL URL is needed, so it should work?
> https://docs.qgis.org/3.34/en/docs/server_manual/config.html#qgis-server-envvar
> QGIS_PROJECT_FILE
> The .qgs or .qgz project file, normally passed as a parameter
> in the query string (with MAP), you can also set it as an
> environment variable (for example by using mod_rewrite Apache
> module).
> **Note that you may also indicate a project stored in
> PostgreSQL**, e.g.
> postgresql://localhost:5432?sslmode=disable&dbname=mydb&schema=myschema&project=myproject
> or inside a geopackage file, e.g.
> geopackage:/path/to/geopackage/file.gpkg?projectName=myProjectName.
> Searching in the Internet for the error above, I've found this
> bug report
> https://github.com/qgis/QGIS/issues/31192
> From which I've got the idea to encode PostgreSQL URL in test
> URL, but it didn't work with the same error as above.
> Also, it looks like report author is connecting with QGIS
> Desktop to QGIS Server, not browser, so this is not my case?
> Also-also, as I've stuck with nginx for unrelated to QGIS
> reasons, I cannot test proposed there Apache rewrite magic.
> I've tried to see if there is anything useful in QGIS Server
> logs, but there are no any related messages in them.
> I've set QGIS_SERVER_LOG_PROFILE to true, but that didn't
> change anything. I see my request to QGIS server only in nginx
> logs, but nothing in QGIS Server logs, and no even failed
> connection attempts in PostgreSQL logs.
> So, is there any way to have PostreSQL projects served via
> QGIS Server, or I can use only files?
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
> Alessandro Pasotti
> QCooperative: www.qcooperative.net <https://www.qcooperative.net>
> ItOpen: www.itopen.it <http://www.itopen.it>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240907/b2438c77/attachment.htm>
More information about the QGIS-User
