[Qgis-user] QGIS Server Performance Tips
Gerald Kogler
geraldo at servus.at
Mon Sep 9 08:46:29 PDT 2024
In my experience Nginx with systemd is the most efficient install method.
Mapproxy works well but I don't have any performance comparison to
Varnish or Geowebcache. Also have in mind combining/grouping layers in
your cache if you don't need them separated in order to avoid http requests.
On 9/9/24 17:27, Abel Gonzalez via QGIS-User wrote:
> I am using Geowebcache for caching WMS layers and works ok.
> BR/ Abel
> Den mån 9 sep. 2024 17:20Jakob Miksch via QGIS-User
> <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>> skrev:
> Hi everyone,
> I would like to the extend the documentation of QGIS Server by
> adding some tips and best practices on how to improve the
> performance. Especially for WMS.
> What I learned already:
> for WMS: try different image formats like PNG8, JPEG or WebP
> use a Cache like MapProxy or Varnish in combination with tiled
> requests
> in the client: avoid loading all layers at once (if not
> absolutely necessary)
> ensure the underlying PostGIS tables are properly indexed
> ensure the machine QGIS Server runs on has enough power
> Do you have any tips on how to improve the performance of QGIS Server?
> Could you point me to any resources about this topic?
> Thanks and Best regards,
> Jakob
> Jakob Miksch
> Consultant
> +49 170 9036956
> siticom.online
> siticom GmbH • Bahnhofsplatz 12
> <https://www.google.com/maps/search/Bahnhofsplatz+12?entry=gmail&source=g> • 76137 Karlsruhe • Deutschland
> Geschäftsführer: Jürgen Hatzipantelis, Stefan Höltken
> Sitz der Gesellschaft: Weiterstadt • Amtsgericht Darmstadt • HRB 9276
> Umsatzsteuer-ID Nr.: DE 197 925 589
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
More information about the QGIS-User
