[Qgis-user] MMQGIS - Reverse geocoding -REQUEST_DENIED
krishna Ayyala ayyalakrishna at gmail.com
Thu Sep 19 17:28:19 PDT 2024
In continuation to the question posted below, I am also attaching
mmqgis_library file. I opened this in notepad++ .In line 288, I don’t see
anything that starts with 'http://'. However, someone in the QGIS forums
suggested changing the URL in line 288 of mmqgis_library.py to begin with
'https' instead of 'http'.
---------- Forwarded message ---------
Date: Thu, Sep 19, 2024 at 5:43 PM
Subject: MMQGIS - Reverse geocoding -REQUEST_DENIED
To: qgis-user <qgis-user at lists.osgeo.org>
Hello,
I do not know scripting or programming. I am using Reverse Geocode tool as
shown below. I am getting the below error. Can anyone help me fix this?
Regards.
[image: image.png]
[image: image.png]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240919/e4620441/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240919/e4620441/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240919/e4620441/attachment-0003.png>
#    mmqgis_library - mmqgis operation functions
#    begin		: 10 May 2010
#    copyright		: (c) 2010 - 2019 by Michael Minn
#    email		: See michaelminn.com
#   MMQGIS is free software and is offered without guarantee
#   or warranty. You can redistribute it and/or modify it
#   under the terms of version 2 of the GNU General Public
#   License (GPL v2) as published by the Free Software
#   Foundation (www.gnu.org).
import io
import re
import csv
import sys
import ssl
import time
import json
import math
import locale
import random
import os.path
import operator
import tempfile
import urllib.parse
import urllib.request
import xml.etree.ElementTree
from qgis.core import *
from PyQt5.QtCore import *
from PyQt5.QtGui import *
# Used instead of "import math" so math functions can be used without "math." prefix
from math import *
#    mmqgis_animate_lines
def mmqgis_animate_lines(print_layout, input_layer, fixed_speed, frame_count, frame_directory, status_callback = None):
	# Error Checks
	if not print_layout:
		return "Invalid print layout"
	exporter = QgsLayoutExporter(print_layout)
	if not exporter:
		return "No exporter found for print layout " + print_layout.name()
	if not input_layer:
		return "Invalid map layer"
	if (input_layer.wkbType() in [QgsWkbTypes.LineString25D, QgsWkbTypes.MultiLineString25D]):
		return "2.5-D not supported. Modify -> Convert Geometry Type to line to animate"
	if (input_layer.type() != QgsMapLayer.VectorLayer) or\
	   (input_layer.wkbType() not in [QgsWkbTypes.LineString, QgsWkbTypes.LineString25D, \
				QgsWkbTypes.MultiLineString, QgsWkbTypes.MultiLineString25D]):
		return "Input needs to be a line layer"
	if frame_count <= 0:
		return "Invalid number of frames specified: " + str(frame_count)
	if not os.path.isdir(frame_directory):
		return "Invalid output directory: " + str(frame_directory)
	# Convert features to lists of points
	points = []
	length = []
	for feature_index, feature in enumerate(input_layer.getFeatures()):
		# This doesn't actually work for 2.5D geometries = waiting for API to support them 2/22/2017
		fpoints = []
		if (feature.geometry().wkbType() == QgsWkbTypes.LineString) or \
		   (feature.geometry().wkbType() == QgsWkbTypes.LineString25D):
			fpoints = feature.geometry().asPolyline()
		elif (feature.geometry().wkbType() == QgsWkbTypes.MultiLineString) or \
		     (feature.geometry().wkbType() == QgsWkbTypes.MultiLineString25D):
			for line in feature.geometry().asMultiPolyline():
				fpoints.extend(line)
		else:
			return "Invalid geometry type " + str(feature.geometry().wkbType())
		points.append(fpoints)
		#print str(feature_index) + " = " + str(len(points)) + " = " + str(len(fpoints)) + \
		#	" = " + str(feature.geometry().wkbType()) + " = " + str(type(points))
		# Calculate total shape length
		# Can't use length() function because it does not consider circuity
		flength = 0
		for point in range(0,len(fpoints) - 1):
			flength = flength + \
				sqrt(pow(fpoints[point].x() - fpoints[point + 1].x(), 2) + \
				pow(fpoints[point].y() - fpoints[point + 1].y(), 2))
		length.append(flength)
	if len(length) <= 0:
		return "No features in layer to animate"
	max_length = max(length)
	# Iterate Frames
	for frame in range(frame_count + 1):
		if status_callback:
			if status_callback(100 * frame / frame_count, "Rendering frame " + str(frame)):
				return "Animate lines cancelled on frame " + str(frame)
		input_layer.startEditing()
			fpoints = points[feature_index]
			if (len(fpoints) <= 0):
				continue
			if fixed_speed:
				visible_length = min([length[feature_index], max_length * frame / frame_count])
			else:
				visible_length = length[feature_index] * frame / frame_count
			total_length = 0
			visible = [fpoints[0], fpoints[0]]
			for z in range(1, len(fpoints)):
				segment_length = pow(pow(fpoints[z].x() - fpoints[z - 1].x(), 2) + \
					pow(fpoints[z].y() - fpoints[z - 1].y(), 2), 0.5)
				# print "   " + str(total_length) + " + " + str(segment_length)
				if (total_length >= visible_length):
					break
				elif (total_length + segment_length) <= visible_length:
					visible.append(fpoints[z])
					total_length = total_length + segment_length
				else: # only display part of line segment
					fraction = (visible_length - total_length) / segment_length
					x = fpoints[z - 1].x() + ((fpoints[z].x() - fpoints[z - 1].x()) * fraction)
					y = fpoints[z - 1].y() + ((fpoints[z].y() - fpoints[z - 1].y()) * fraction)
					visible.append(QgsPointXY(x, y))
					break
			# print str(visible_length) + ", " + str(len(visible)) + ", " + \
			#	str(total_length) + ", " + str(max_length)
			input_layer.changeGeometry(feature.id(), QgsGeometry.fromPolylineXY(visible))
		# Write Frame
		framefile = frame_directory + "/frame" + format(frame, "06d") + ".png"
		exporter.exportToImage(framefile, QgsLayoutExporter.ImageExportSettings())
		# Clean up: Constantly starting and stopping editing is slow,
		# but leaving editing open and accumulating successive changes
		# seems to be even slower
		input_layer.rollBack()
	if status_callback:
		status_callback(100, str(frame_count) + " frames exported")
	return None
#    mmqgis_animate_location - Animate with linear interpolation from source to destination locations
def mmqgis_animate_location(print_layout, source_layer, source_key_field, \
			destination_layer, destination_key_field, frame_count, \
	# Error Checks
	if not exporter:
	if (not source_layer) or (source_layer.type() != QgsMapLayer.VectorLayer) or (source_layer.featureCount() <= 0):
		return "Invalid source layer"
	if (not destination_layer) or (destination_layer.type() != QgsMapLayer.VectorLayer) or \
	   (destination_layer.featureCount() <= 0):
		return "Invalid destination layer"
	source_key_index = source_layer.dataProvider().fieldNameIndex(source_key_field)
	if (source_key_index < 0):
		return "Invalid source key field: " + str(long_col)
	destination_key_index = destination_layer.dataProvider().fieldNameIndex(destination_key_field)
	if (destination_key_index < 0):
		return "Invalid destination key field: " + str(long_col)
	transform = QgsCoordinateTransform(destination_layer.crs(), source_layer.crs(), QgsProject.instance())
	# Find each feature's differential change with each frame
	xdifferential = {}
	ydifferential = {}
	animated_features = 0
	for feature in source_layer.getFeatures():
		x_start = feature.geometry().centroid().asPoint().x()
		y_start = feature.geometry().centroid().asPoint().y()
		source_key = str(feature.attributes()[source_key_index])
		expression = "\"" + str(destination_key_field) + "\" = '" + source_key + "'"
		for destination in destination_layer.getFeatures(expression):
			geometry = destination.geometry()
			geometry.transform(transform)
			x_end = geometry.centroid().asPoint().x()
			y_end = geometry.centroid().asPoint().y()
			xdifferential[feature.id()] = (x_end - x_start) / frame_count
			ydifferential[feature.id()] = (y_end - y_start) / frame_count
			#print("Feature " + str(feature.id()) + " " + str(feature.attributes()[2]) + \
			#	": " + str(xdifferential[feature.id()]) + ", " + str(ydifferential[feature.id()]))
			animated_features = animated_features + 1
			break
	# Iterate Frames
		if status_callback:
				str(animated_features) + " features, frame " + str(frame) + " of " + str(frame_count)):
				return "Animate columns cancelled on frame " + str(frame)
		# Translate (move) shapes
		source_layer.startEditing()
			if feature.id() in xdifferential:
				x_shift = xdifferential[feature.id()] * frame
				y_shift = ydifferential[feature.id()] * frame
				#print(str(feature.id()) + ": " + str(x_shift) + ", " + str(y_shift))
				source_layer.translateFeature(feature.id(), x_shift, y_shift)
		# Write Frame
		frame_file = frame_directory + "/frame" + format(frame, "06d") + ".png"
		exporter.exportToImage(frame_file, QgsLayoutExporter.ImageExportSettings())
		# seems to be even slower (6/5/2014)
		source_layer.rollBack()
	if status_callback:
		status_callback(100, str(animated_features) + " features, " + str(frame_count) + " frames")
	return None
#    mmqgis_animate_sequence - Create animations by displaying successive rows
def mmqgis_animate_sequence(print_layout, layers, cumulative, frame_directory, status_callback = None):
	# Error Checks
	if not exporter:
	frame_count = 0
	for layer in layers:
		if frame_count < layer.featureCount():
			frame_count = layer.featureCount()
		if not layer.startEditing():
			return "A layer must be editable to animate"
		layer.rollBack()
	if frame_count <= 1:
		return "At least one animated layer must have more than one feature"
	# Store geometries in a list and delete them from features
	geometries = [[] * len(layers)]
	feature_ids = [None] * len(layers)
	for layer_index, layer in enumerate(layers):
		feature_ids[layer_index] = layer.allFeatureIds()
		for feature_index, feature in enumerate(layer.getFeatures()):
			geometries[layer_index].append(QgsGeometry(feature.geometry()))
			layer.changeGeometry(feature_ids[layer_index][feature_index], QgsGeometry())
			#feature.setGeometry(QgsGeometry(QgsGeometry.fromPoint(QgsPoint(0,0))))
	# Iterate frames
	# qgis.mapCanvas().renderComplete.connect(temp_render_complete)
	#qgis.mapCanvas().setParallelRenderingEnabled(False)
	#qgis.mapCanvas().setCachingEnabled(False)
	for frame in range(int(frame_count + 1)):
		if status_callback:
				return "Animate rows cancelled on frame " + str(frame)
			if frame < len(geometries[layer_index]):
				layer.changeGeometry(feature_ids[layer_index][frame], \
					QgsGeometry(geometries[layer_index][frame]))
				if (frame > 0) and (not cumulative):
					layer.changeGeometry(feature_ids[layer_index][frame - 1], QgsGeometry())
		# qgis.mapCanvas().refresh()
		#pixmap = QPixmap(qgis.mapCanvas().mapSettings().outputSize().width(),
		#	qgis.mapCanvas().mapSettings().outputSize().height())
		# qgis.mapCanvas().saveAsImage(framefile, pixmap)
		# print("Saved " + str(frame))
		# return
	# Restore geometries
		layer.rollBack()
	if status_callback:
	return None
#    mmqgis_animate_zoom - Create animations by zoomin into or out of a map
def mmqgis_animate_zoom(print_layout, start_lat, start_long, start_zoom, \
		end_lat, end_long, end_zoom, frame_count, frame_directory, status_callback = None):
	# Error checks
	if (not print_layout) or (type(print_layout) != QgsPrintLayout):
	if (type(start_lat) not in [int, float]) or (start_lat < -90) or (start_lat > 90) or \
	   (type(start_long) not in [int, float]) or (start_long < -180) or (start_long > 180):
		return "Start location out of range"
	if (type(end_lat) not in [int, float]) or (end_lat < -90) or (end_lat > 90) or \
	   (type(end_long) not in [int, float]) or (end_long < -180) or (end_long > 180):
		return "End location out of range"
	if (type(start_zoom) not in [int, float]) or (start_zoom < 1) or (start_zoom > 20):
		return "Start zoom out of range"
	if (type(end_zoom) not in [int, float]) or (end_zoom < 1) or (end_zoom > 20):
		return "End zoom out of range"
	if (type(frame_count) != int) or (frame_count <= 0):
		return "Frame count must be positive"
	if (not frame_directory) or (not os.path.isdir(frame_directory)):
		return "Invalid frame directory"
	map_item_count = 0
	for page_number in range(print_layout.pageCollection().pageCount()):
		for item in print_layout.pageCollection().itemsOnPage(page_number):
			if item.type() == QgsLayoutItemRegistry.LayoutMap:
				map_item_count = map_item_count + 1
	if not map_item_count:
		return "No map items in the print layout"
	wgs84 = QgsCoordinateReferenceSystem("PROJ4:+proj=longlat +datum=WGS84 +no_defs")
	# Export frame images
		if status_callback:
			if status_callback(100 * frame / float(frame_count), "Frame " + str(frame)):
				return "Cancelled at frame " + str(frame) + " of " + str(frame_count)
		# Calculate the smoothed zoom, latitude, and longitude
		ratio = (1 - math.cos((frame / frame_count) * math.pi)) / 2
		zoom = start_zoom + ((end_zoom - start_zoom) * ratio)
		degree_height = 360 * math.pow(0.5, zoom)
		center_lat = start_lat + (ratio * (end_lat - start_lat))
		center_long = start_long + (ratio * (end_long - start_long))
		# print("Ratio " + str(ratio) + " = " + str(zoom) + " = " + str(degree_height) + " degrees")
		# Zoom in/out
		old_extents = []
					# Save the old extent for restoration after printing the fram
					old_extent = item.extent()
					old_extents.append(old_extent)
					# Find the extent top/bottom based on zoom level and center
					top = QgsPointXY(center_long, center_lat + (degree_height / 2))
					bottom = QgsPointXY(center_long, center_lat - (degree_height / 2))
					transform = QgsCoordinateTransform(wgs84, item.crs(), QgsProject.instance())
					top = transform.transform(top)
					bottom = transform.transform(bottom)
					# Find the new width based on the aspect ratio of the old extent
					new_width = old_extent.width() * (top.x() - bottom.x()) / old_extent.height()
					new_extent = QgsRectangle(bottom.x() - (new_width / 2), bottom.y(),
							bottom.x() + (new_width / 2), top.y())
					# print(str(new_extent))
					item.zoomToExtent(new_extent)
		# Print the frame image
		file_name = frame_directory + "/frame%04d.png" % frame
		exporter.exportToImage(file_name, exporter.ImageExportSettings())
		# Restore old extents
					if len(old_extents) > 0:
						item.zoomToExtent(old_extents[0])
						old_extents.remove(old_extents[0])
	if status_callback:
	return None
#    mmqgis_attribute_export - Export attributes to CSV file
def mmqgis_attribute_export(input_layer, attribute_names, output_csv_name, \
		field_delimiter = ",", line_terminator = "\n", decimal_mark = ".", \
	# Error checks
	if (not input_layer) or (input_layer.type() != QgsMapLayer.VectorLayer) or (input_layer.featureCount() <= 0):
		return "Invalid layer"
	if not attribute_names:
		return "No attributes specified for export"
	# CSV Options
	layer_options = []
	if line_terminator == "\r\n":
		layer_options.append("LINEFORMAT=CRLF")
	else:
		layer_options.append("LINEFORMAT=LF")
	if field_delimiter == ";":
		layer_options.append("SEPARATOR=SEMICOLON")
	elif field_delimiter == "\t":
		layer_options.append("SEPARATOR=TAB")
	elif field_delimiter == " ":
		layer_options.append("SEPARATOR=SPACE")
	else:
		layer_options.append("SEPARATOR=COMMA")
	if not decimal_mark:
		decimal_mark = "."
	# Build field list
	fields = QgsFields()
	attribute_indices = []
	for attribute in attribute_names:
		found = False
		for index, field in enumerate(input_layer.fields()):
			if field.name() == attribute:
				fields.append(field)
				attribute_indices.append(index)
				found = True
				break
		if not found:
			return "Invalid attribute name: " + attribute
	if not attribute_indices:
		return "No valid attributes specified"
	# Create file writer
	outfile = QgsVectorFileWriter(output_csv_name, "utf-8", fields, \
		QgsWkbTypes.Unknown, driverName = "CSV", layerOptions = layer_options)
	if (outfile.hasError() != QgsVectorFileWriter.NoError):
		return "Failure creating output file: " + str(outfile.errorMessage())
	# Iterate through each feature in the source layer
	for index, feature in enumerate(input_layer.getFeatures()):
		if ((index % 50) == 0) and status_callback:
			if status_callback(100 * index / input_layer.featureCount(), \
					"Exporting " + str(index) + " of " + str(input_layer.featureCount())):
				return "Export attributes cancelled on feature " + str(index)
		attributes = []
		for x in attribute_indices:
			attributes.append(feature.attributes()[x])
		newfeature = QgsFeature()
		newfeature.setAttributes(attributes)
		outfile.addFeature(newfeature)
	del outfile
	if status_callback:
		status_callback(100, str(input_layer.featureCount()) + " records exported")
	return None
#    mmqgis_attribute_join - Join attributes from a CSV file to a shapefile
def mmqgis_attribute_join(input_layer, input_layer_attribute, input_csv_name, input_csv_attribute, \
			output_file_name, status_callback = None):
	# Error checks
	try:
		if (input_layer.type() != QgsMapLayer.VectorLayer):
			return "Invalid layer type " + str(input_layer.type()) + " for attribute export"
	except Exception as e:
		return "Invalid layer: " + str(e)
	if (input_layer.wkbType() == None) or (input_layer.wkbType() == QgsWkbTypes.NoGeometry):
		return "Layer has no geometries"
	join_index = input_layer.dataProvider().fieldNameIndex(input_layer_attribute)
	if join_index < 0:
		return "Invalid CSV field name: " + str(input_layer_attribute)
	if not output_file_name:
		return "No output file name given"
	file_formats = { ".shp":"ESRI Shapefile", ".geojson":"GeoJSON", ".kml":"KML", ".sqlite":"SQLite", ".gpkg":"GPKG" }
	if os.path.splitext(output_file_name)[1] not in file_formats:
		return "Unsupported output file format: " + str(output_file_name)
	output_file_format = file_formats[os.path.splitext(output_file_name)[1]]
	# Open CSV file and read the header
	if not input_csv_name:
		return "No input CSV file name given"
	input_csv = QgsVectorLayer(input_csv_name)
	if (not input_csv) or (input_csv.featureCount() <= 0) or (len(input_csv.fields()) <= 0):
		return "Failure opening input file: " + str(input_csv_name)
	header = [x.name() for x in input_csv.fields()]
	# Read shapefile field names
	# 12/27/2016: Real numbers imported from shapefiles have a precision of
	# zero, which causes them to be written as integers, which causes
	# loss of decimal points and total loss of value when values exceed MAXINT.
	# This kludge sets the precision to an arbitrary value, which causes
	# the OGR writer to consider them floating point.
	newfields = QgsFields()
	for field in input_layer.fields():
		if field.type() == QVariant.Double:
			newfields.append(QgsField(field.name(), field.type(), field.typeName(), 12, 4))
		else:
				field.length(), field.precision()))
	# Create a combined list of fields with shapefile-safe (<= 10 char) unique names
	csv_index = -1
	for index in range(0, len(header)):
		if header[index].strip().lower() == input_csv_attribute.strip().lower():
			csv_index = index
		else:
			# Shapefile-safe = 10 characters or less
			fieldname = header[index].strip()[0:10]
			# Rename fields that have duplicate names
			suffix = 1
			while (newfields.indexFromName(fieldname) >= 0):
				suffix = suffix + 1
				if (suffix <= 9):
					fieldname = fieldname[0:9] + str(suffix)
				else:
					fieldname = fieldname[0:8] + str(suffix)
			# 12/27/2016: String length of 254 is used to prevent a warning thrown
			# when the default 255 exceeds the 254 char limit
			newfields.append(QgsField(fieldname, QVariant.String, "String", 254))
	if csv_index < 0:
		return "Field " + str(input_csv_attribute) + " not found in " + str(input_csv_name)
	# Create the output shapefile
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", newfields, \
		input_layer.wkbType(), input_layer.crs(), output_file_format)
	matched_count = 0
		if status_callback and ((feature_index % 50) == 0):
			if status_callback(100 * feature_index / input_layer.featureCount(), \
				"Feature " + str(feature_index) + " of " + str(input_layer.featureCount()) + \
				" (" + str(matched_count) + " matched)"):
				return "Cancelled on feature " + str(feature.id()) + " of " + str(input_layer.featureCount())
		if feature.geometry() == None:
			return "No geometry in on feature " + str(feature_index)
		attributes = feature.attributes()
		key = attributes[join_index].lower().strip()
		for row_index, row in enumerate(input_csv.getFeatures()):
			if row.attribute(csv_index).strip().lower() == key:
				# print(key + " --------------")
				newattributes = []
				for value in attributes:
					newattributes.append(value)
				for combine_index in range(len(row.attributes())):
					if combine_index != csv_index:
						newattributes.append(row.attribute(combine_index))
				newfeature.setAttributes(newattributes)
				newfeature.setGeometry(feature.geometry())
				matched_count += 1
	del outfile
	if matched_count <= 0:
		return "No matching records found"
	if status_callback:
		status_callback(100, str(input_layer.featureCount()) + " layer + " \
			+ str(input_csv.featureCount()) + " CSV = " + str(matched_count) + " features")
	return None
#    mmqgis_buffers - Create buffers around shapes
def mmqgis_bearing(start, end):
	# Assumes points are WGS 84 lat/long
	# http://www.movable-type.co.uk/scripts/latlong.html
	start_lon = start.x() * pi / 180
	start_lat = start.y() * pi / 180
	end_lon = end.x() * pi / 180
	end_lat = end.y() * pi / 180
	return atan2(sin(end_lon - start_lon) * cos(end_lat), \
		(cos(start_lat) * sin(end_lat)) - \
		(sin(start_lat) * cos(end_lat) * cos(end_lon - start_lon))) \
		* 180 / pi
def mmqgis_endpoint(start, distance, degrees):
	# Assumes points are WGS 84 lat/long, distance in meters,
	# bearing in degrees with north = 0, east = 90, west = -90
	# Uses the haversine formula for calculation:
	radius = 6378137.0 # meters
	bearing = degrees * pi / 180
	end_lat = asin((sin(start_lat) * cos(distance / radius)) +
		(cos(start_lat) * sin(distance / radius) * cos(bearing)))
	end_lon = start_lon + atan2( \
		sin(bearing) * sin(distance / radius) * cos(start_lat),
		cos(distance / radius) - (sin(start_lat) * sin(end_lat)))
	return QgsPointXY(end_lon * 180 / pi, end_lat * 180 / pi)
def mmqgis_buffer_geometry(geometry, meters):
	if meters <= 0:
		return None
	# To approximate meaningful meter distances independent of the original CRS,
	# the geometry is transformed to an azimuthal equidistant projection
	# with the center of the polygon as the origin. After buffer creation,
	# the buffer is transformed to WGS 84 and returned. While this may introduce
	# some deviation from the original CRS, buffering is assumed in practice
	# to be a fairly inexact operation that can tolerate such deviation
	latitude = str(geometry.centroid().asPoint().y())
	longitude = str(geometry.centroid().asPoint().x())
	#proj4 = "+proj=aeqd +lat_0=" + str(geometry.centroid().asPoint().y()) + \
	#	" +lon_0=" + str(geometry.centroid().asPoint().x()) + \
	#	" +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs"
	# For some reason, Azimuthal Equidistant transformation noticed to not be
	# working on 10 July 2014. World Equidistant Conic works, but there may be errors.
	proj4 = "+proj=eqdc +lat_0=0 +lon_0=0 +lat_1=60 +lat_2=60 " + \
		"+x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs"
	azimuthal_equidistant = QgsCoordinateReferenceSystem()
	azimuthal_equidistant.createFromProj4(proj4)
	transform = QgsCoordinateTransform(wgs84, azimuthal_equidistant, QgsProject.instance())
	newgeometry = geometry.buffer(meters, 7)
	wgs84 = QgsCoordinateReferenceSystem()
	wgs84.createFromProj4("+proj=longlat +datum=WGS84 +no_defs")
	transform = QgsCoordinateTransform(azimuthal_equidistant, wgs84, QgsProject.instance())
	newgeometry.transform(transform)
	return newgeometry
def mmqgis_buffer_point(point, meters, edges, rotation_degrees):
	if (meters <= 0) or (edges < 3):
		return None
	# Points are treated separately from other geometries so that discrete
	# edges can be supplied for non-circular buffers that are not supported
	# by the QgsGeometry.buffer() function
	# print "Point " + str(point.x()) + ", " + str(point.y()) + " meters " + str(meters)
	polyline = []
	for edge in range(0, edges + 1):
		degrees = ((float(edge) * 360.0 / float(edges)) + rotation_degrees) % 360
		polyline.append(mmqgis_endpoint(QgsPointXY(point), meters, degrees))
	return QgsGeometry.fromPolygonXY([polyline])
def mmqgis_buffer_line_side(geometry, width, direction):
	# width in meters
	# direction should be 0 for north side, 90 for east, 180 for south, 270 for west
	# print "\nmmqgis_buffer_line_side(" + str(direction) + ")"
	if (geometry.wkbType() == QgsWkbTypes.MultiLineString) or \
	   (geometry.wkbType() == QgsWkbTypes.MultiLineString25D):
		multipolygon = None
		for line in geometry.asMultiPolyline():
			segment = mmqgis_buffer_line_side(QgsGeometry.fromPolylineXY(line), width, direction)
			if multipolygon == None:
				multipolygon = segment
			else:
				multipolygon = multipolygon.combine(segment)
			# print "  Build multipolygon " + str(multipolygon.isGeosValid())
		# Multiline always has multipolygon buffer even if buffers merge into one polygon
		if multipolygon.wkbType() == QgsWkbTypes.Polygon:
			multipolygon = QgsGeometry.fromMultiPolygonXY([multipolygon.asPolygon()])
		# print "Final Multipolygon " + str(multipolygon.isGeosValid())
		return multipolygon
	if (geometry.wkbType() != QgsWkbTypes.LineString) and \
	   (geometry.wkbType() != QgsWkbTypes.LineString25D):
		return geometry
	points = geometry.asPolyline()
	line_bearing = mmqgis_bearing(points[0], points[-1]) % 360
	# Determine side of line to buffer based on angle from start point to end point
	# "bearing" will be 90 for right side buffer, -90 for left side buffer
	direction = round((direction % 360) / 90) * 90
	if (direction == 0): # North
		if (line_bearing >= 180):
			bearing = 90 # Right
		else:
			bearing = -90 # Left
	elif (direction == 90): # East
		if (line_bearing >= 270) or (line_bearing < 90):
		else:
	elif (direction == 180): # South
		if (line_bearing < 180):
		else:
	else: # West
		if (line_bearing >= 90) and (line_bearing < 270):
		else:
	# Buffer individual segments
	polygon = None
	for z in range(0, len(points) - 1):
		b1 = mmqgis_bearing(points[z], points[z + 1]) % 360
		# Form rectangle beside line
		# 2% offset mitigates topology floating-point errors
		linestring = [QgsPointXY(points[z])]
		if (z == 0):
			linestring.append(mmqgis_endpoint(points[z], width, b1 + bearing))
		else:
			linestring.append(mmqgis_endpoint(points[z], width, b1 + (1.02 * bearing)))
		linestring.append(mmqgis_endpoint(points[z + 1], width, b1 + bearing))
		# Determine if rounded convex elbow is needed
		if (z < (len(points) - 2)):
			b2 = mmqgis_bearing(points[z + 1], points[z + 2]) % 360
			elbow = b2 - b1
			if (elbow < -180):
				elbow = elbow + 360
			elif (elbow > 180):
				elbow = elbow - 360
			# print str(b1) + ", " + str(b2) + " = " + str(elbow)
			# 8-step interpolation of arc
			if (((bearing > 0) and (elbow < 0)) or \
			    ((bearing < 0) and (elbow > 0))):
				for a in range(1,8):
					b = b1 + (elbow * a / 8.0) + bearing
					linestring.append(mmqgis_endpoint(points[z + 1], width, b))
					# print "  arc: " + str(b)
				linestring.append(mmqgis_endpoint(points[z + 1], width, b2 + bearing))
		# Close polygon
		linestring.append(QgsPointXY(points[z + 1]))
		linestring.append(QgsPointXY(points[z]))
		segment = QgsGeometry.fromPolygonXY([linestring])
		# print linestring
		# print "  Line to polygon " + str(segment.isGeosValid())
		if (polygon == None):
			polygon = segment
		else:
			polygon = polygon.combine(segment)
		#print "  Polygon build " + str(polygon.isGeosValid())
		#if not polygon.isGeosValid():
		#	print polygon.asPolygon()
	# print "  Final polygon " + str(polygon.isGeosValid())
	return polygon
def mmqgis_buffers(input_layer, selected_only, radius_attribute, radius, radius_unit, \
	edge_attribute, edge_count, rotation_attribute, rotation_degrees, \
	# Error checking
	try:
			return "Invalid layer type for buffering: " + str(input_layer.type())
	# Radius
	radius_attribute_index = -1
	if radius_attribute:
		radius_attribute_index = input_layer.dataProvider().fieldNameIndex(radius_attribute)
		if (radius_attribute_index < 0):
			return "Invalid radius attribute name: " + str(radius_attribute)
	else:
		try:
			radius = float(radius)
			return "Invalid radius: " + str(radius)
		if (radius <= 0):
			return "Radius must be greater than zero (" + str(radius) + ")"
	# Edges
	edge_attribute_index = -1
	if (input_layer.wkbType() in [QgsWkbTypes.Point, QgsWkbTypes.PointZ, QgsWkbTypes.Point25D, \
			QgsWkbTypes.MultiPoint, QgsWkbTypes.MultiPointZ, QgsWkbTypes.MultiPoint25D]):
		if edge_attribute:
			edge_attribute_index = input_layer.dataProvider().fieldNameIndex(edge_attribute)
			if (edge_attribute_index < 0):
				return "Invalid edge attribute name: " + str(edge_attribute)
		else:
			try:
				edge_count = int(edge_count)
				return "Invalid edge count: " + str(edge_count)
			if (edge_count <= 0):
				return "Number of edges must be greater than zero (" + str(edge_count) + ")"
	# Rotation
	rotation_attribute_index = -1
	if rotation_attribute:
		rotation_attribute_index = input_layer.dataProvider().fieldNameIndex(rotation_attribute)
		if (rotation_attribute_index < 0):
			return "Invalid rotation attribute name: " + str(rotation_attribute)
	else:
		try:
			rotation_degrees = float(rotation_degrees)
			return "Invalid rotation degrees: " + str(rotation_degrees)
	# Create the output file
	transform = QgsCoordinateTransform(input_layer.crs(), wgs84, QgsProject.instance())
	# print layer.crs().toProj4() + " -> " + wgs84.toProj4()
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", input_layer.fields(), \
		QgsWkbTypes.Polygon, wgs84, output_file_format)
		return str(outfile.errorMessage())
	# Create buffers for each feature
	buffercount = 0
	feature_count = input_layer.featureCount();
	if selected_only:
		feature_list = input_layer.selectedFeatures()
	else:
		feature_list = input_layer.getFeatures()
	for feature_index, feature in enumerate(feature_list):
		if status_callback:
			if status_callback(100 * feature.id() / feature_count, \
					"Feature " + str(feature.id()) + " of " + str(feature_count)):
				return "Buffering cancelled on feature " + str(feature.id()) + " of " + str(feature_count)
		if radius_attribute_index < 0:
			feature_radius = radius
		else:
			try:
				feature_radius = float(feature.attributes()[radius_attribute_index])
			except:
				feature_radius = 0.0
		if feature_radius <= 0:
			continue
		# Buffer radii are always in meters
		if radius_unit == "Kilometers":
			feature_radius = feature_radius * 1000
		elif radius_unit == "Feet":
			feature_radius = feature_radius / 3.2808399
		elif radius_unit == "Miles":
			feature_radius = feature_radius * 1609.344
		elif radius_unit == "Nautical Miles":
			feature_radius = feature_radius * 1852
			continue
		if edge_attribute_index < 0:
			feature_edges = edge_count
		else:
			try:
				feature_edges = int(feature.attributes()[edge_attribute_index])
			except:
				feature_edges = 32 # default to circle
		if rotation_attribute_index < 0:
			feature_rotation = rotation_degrees
		else:
			try:
				feature_rotation = float(feature.attributes()[rotation_attribute_index])
			except:
				feature_rotation = 0.0
		geometry = feature.geometry()
		geometry.transform(transform) # Needs to be WGS 84 to use Haversine distance calculation
		# print "Transform " + str(x) + ": " + str(geometry.centroid().asPoint().x())
		if (geometry.wkbType() in [QgsWkbTypes.Point, QgsWkbTypes.PointZ, QgsWkbTypes.Point25D, \
			newgeometry = mmqgis_buffer_point(geometry.asPoint(), feature_radius, feature_edges, feature_rotation)
		elif (geometry.wkbType() in [QgsWkbTypes.LineString, QgsWkbTypes.LineStringZ, \
				QgsWkbTypes.LineString25D, QgsWkbTypes.MultiLineString, \
				QgsWkbTypes.MultiLineStringZ, QgsWkbTypes.MultiLineString25D]):
			if (edge_attribute == "Flat End"):
				# newgeometry = mmqgis_buffer_line_flat_end(geometry, feature_radius)
				north = mmqgis_buffer_line_side(QgsGeometry(geometry), feature_radius, 0)
				south = mmqgis_buffer_line_side(QgsGeometry(geometry), feature_radius, 180)
				newgeometry = north.combine(south)
			elif (edge_attribute == "North Side"):
				newgeometry = mmqgis_buffer_line_side(geometry, feature_radius, 0)
			elif (edge_attribute == "East Side"):
				newgeometry = mmqgis_buffer_line_side(geometry, feature_radius, 90)
			elif (edge_attribute == "South Side"):
				newgeometry = mmqgis_buffer_line_side(geometry, feature_radius, 180)
			elif (edge_attribute == "West Side"):
				newgeometry = mmqgis_buffer_line_side(geometry, feature_radius, 270)
			else: # "Rounded"
				newgeometry = mmqgis_buffer_geometry(geometry, feature_radius)
		else:
		if newgeometry == None:
			return "Failure converting geometry for feature " + str(buffercount)
		else:
			newfeature.setGeometry(newgeometry)
			newfeature.setAttributes(feature.attributes())
		buffercount = buffercount + 1
	del outfile
	if status_callback:
		status_callback(100, str(buffercount) + " buffers created for " + str(feature_count) + " features")
	return None
#    mmqgis_change_projection - change a layer's projection (reproject)
def mmqgis_change_projection(input_layer, new_crs, output_file_name, status_callback = None):
	# Error checks
	if type(input_layer) not in [ QgsMapLayer, QgsVectorLayer ]:
		return "Invalid layer type for modification: " + str(type(input_layer))
	if type(new_crs) != QgsCoordinateReferenceSystem:
		return "Invalid CRS"
		input_layer.wkbType(), new_crs, output_file_format)
	transform = QgsCoordinateTransform(input_layer.crs(), new_crs, QgsProject.instance())
		if status_callback and ((index % 50) == 0):
			if status_callback(100 * index / input_layer.featureCount(), "Feature " + str(index)):
				return "Cancelled on feature " + str(index) + " of " + str(input_layer.featureCount())
		new_feature = QgsFeature()
		new_feature.setAttributes(feature.attributes())
		new_geometry = feature.geometry()
		try:
			new_geometry.transform(transform)
			return "Feature " + str(index) + " could not be transformed to the new projection: " + str(e)
		new_feature.setGeometry(new_geometry)
		outfile.addFeature(new_feature)
	if status_callback:
		status_callback(100, "Changed projection for " + str(input_layer.featureCount()) + " features")
	return None
#    mmqgis_delete_duplicate_geometries - Save to shaperile while removing duplicate shapes
def mmqgis_delete_duplicate_geometries(input_layer, output_file_name, status_callback = None):
	# Error checks
	try:
			return "Invalid layer type for modification: " + str(input_layer.type())
	# Read geometries into an array
	# Have to save as WKT because saving geometries causes segfault
	# when they are used with equal() later
	geometries = []
	for feature in input_layer.getFeatures():
		geometries.append(feature.geometry().asWkt())
	# NULL duplicate geometries
	for x in range(0, len(geometries) - 1):
		if geometries[x] == None:
			continue
		if status_callback and ((x % 50) == 0):
			if status_callback(100 * x / len(geometries), "Feature " + str(x)):
				return "Cancelled on feature " + str(x) + " of " + str(len(geometries))
		for y in range(x + 1, len(geometries)):
			#print "Comparing " + str(x) + ", " + str(y)
			if geometries[x] == geometries[y]:
				#print "None " + str(x)
				geometries[y] = None
	writecount = 0
		if geometries[index] != None:
			writecount += 1
			outfile.addFeature(feature)
	del outfile
	if status_callback:
		status_callback(100, str(writecount) + " unique of " + str(input_layer.featureCount()))
	return None
#    mmqgis_float_to_text - String format numeric fields
def mmqgis_float_to_text(input_layer, attributes, separator, \
			 decimals, multiplier, prefix, suffix, \
	# Error checks
	try:
		if input_layer.type() != QgsMapLayer.VectorLayer:
			return "Input layer must be a vector layer"
	except:
		return "Invalid input layer"
	if decimals < 0:
		return "Invalid number of decimals: " + str(decimals)
	if not multiplier:
		return "Invalid multiplier: " + str(multiplier)
	if not separator:
		separator = ""
	if not prefix:
		prefix = ""
	if not suffix:
		suffix = ""
	# Build dictionary of fields with selected fields for conversion to floating point
	changecount = 0
	fieldchanged = []
	destfields = QgsFields();
		if field.name() in attributes:
			if not (field.type() in [QVariant.Double, QVariant.Int, QVariant.UInt, \
					QVariant.LongLong, QVariant.ULongLong]):
				return "Cannot convert non-numeric field: " + str(field.name())
			changecount += 1
			fieldchanged.append(True)
			destfields.append(QgsField (field.name(), QVariant.String, field.typeName(), \
				20, 0, field.comment()))
		else:
			fieldchanged.append(False)
			destfields.append(QgsField (field.name(), field.type(), field.typeName(), \
				field.length(), field.precision(), field.comment()))
	if (changecount <= 0):
		return "No numeric fields selected for conversion"
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", destfields, \
	# Write the features with modified attributes
			if status_callback(100 * feature_index / feature_count, \
					"Feature " + str(feature_index) + " of " + str(feature_count)):
				return "Cancelled on feature " + str(feature_index) + " of " + str(feature_count)
			if fieldchanged[index]:
				# floatvalue, test = attributes[index].toDouble()
				try:
					floatvalue = multiplier * float(attributes[index])
				except:
					floatvalue = 0
				value = ("{:,." + str(decimals) + "f}").format(floatvalue)
				if (separator == ' ') or (separator == '.'):
					# European-style numbers: 1.203.347,42
					value = value.replace(".", "dec")
					value = value.replace(",", separator)
					value = value.replace("dec", ",")
				elif separator == "":
					value = value.replace(",", "")
				else:
				attributes[index] = str(prefix) + str(value) + str(suffix)
	del outfile
	if status_callback:
		status_callback(100, str(len(attributes)) + " fields, " + str(input_layer.featureCount()) + " features")
	return None
#    mmqgis_geocode_reverse - Reverse geocode locations to addresses
def mmqgis_proxy_settings():
	# Load proxy settings from qgis options settings
	try:
		settings = QSettings()
		proxyEnabled = settings.value("proxy/proxyEnabled", "")
		proxyType = settings.value("proxy/proxyType", "" )
		proxyHost = settings.value("proxy/proxyHost", "" )
		proxyPort = settings.value("proxy/proxyPort", "" )
		proxyUser = settings.value("proxy/proxyUser", "" )
		proxyPassword = settings.value("proxy/proxyPassword", "" )
		# http://stackoverflow.com/questions/1450132/proxy-with-urllib2
		if proxyEnabled == "true":
			if proxyUser:
				proxy = urllib.request.ProxyHandler({'http': 'http://' +  proxyUser + ':' +
					proxyPassword + '@' + proxyHost + ':' + proxyPort})
			else:
				proxy = urllib.request.ProxyHandler({'http': 'http://' + proxyHost + ':' + proxyPort})
			opener = urllib.request.build_opener(proxy)
			urllib.request.install_opener(opener)
	except:
		pass
def mmqgis_geocode_reverse(input_layer, web_service, api_key, use_first, output_file_name, status_callback = None):
	# Error checks
	web_services = ["Google", "OpenStreetMap / Nominatim"]
	if web_service not in web_services:
		return "Invalid web service name: " + str(web_service)
	if (web_service == "Google") and (not api_key):
		return "A Google Maps API key is required\n" + \
			"https://developers.google.com/maps/documentation/javascript/get-api-key"
	try:
		fields = input_layer.fields()
	except:
	if web_service == "Google":
		for field_name in ["result_num", "status", "formatted_address", "place_id", \
				   "location_type", "latlong"]:
			fields.append(QgsField (field_name, QVariant.String))
	elif web_service == "OpenStreetMap / Nominatim":
		for field_name in ["result_num", "osm_id", "display_name", "category", "type", "latlong"]:
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", fields, \
	# HTTP(S) proxy settings from qgis options settings
	# Coordinates to the web services assumed to be WGS 84 latitude/longitude
	result_count = 0
		if status_callback and ((feature_index % 3) == 0):
		# Use the centroid as the latitude and longitude
		point = feature.geometry().centroid().asPoint()
		point = transform.transform(point)
		latitude = point.y()
		longitude = point.x()
		# API URL
			url = "https://maps.googleapis.com/maps/api/geocode/json?latlng=" + \
				str(latitude) + "," + str(longitude) + "&key=" + api_key
		else:
			url = "https://nominatim.openstreetmap.org/reverse?&format=geojson&lat=" + \
				str(latitude) + "&lon=" + str(longitude)
		# Query the API
		max_attempts = 5
		for attempt in range(1, max_attempts + 1):
			try:
				# Avoids the dreaded SSL: CERTIFICATE_VERIFY_FAILED error
				# https://datumorphism.com/til/data/python-urllib-ssl/
				# Ignore SSL certificate errors
				request_context = ssl.create_default_context()
				request_context.check_hostname = False
				request_context.verify_mode = ssl.CERT_NONE
				# https://operations.osmfoundation.org/policies/nominatim/
				user_agent = "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_3)"
				request = urllib.request.Request(url, headers={'User-Agent': user_agent})
				json_string = urllib.request.urlopen(request, context=request_context).read()
				break
				if (attempt >= max_attempts):
					return "Failure connecting to API: " + str(e)
				# Wait a second and try again
				time.sleep(1)
		new_feature.setGeometry(feature.geometry())
		try:
			json_array = json.loads(json_string.decode("utf-8"))
			attributes.append(str(-1))
			attributes.append(str(e))
			continue
			# Check status
			# https://developers.google.com/maps/documentation/geocoding/intro#GeocodingRequests
			if "status" in json_array:
				status = json_array["status"]
			else:
				status = "No status"
			if "error_meessage" in json_array:
				error_messsage = json_array["error_message"]
			else:
				error_message = ""
			if (status == "REQUEST_DENIED") or (status == "OVER_QUERY_LIMIT"):
				return status + ": " + error_message
			if status != "OK":
				attributes.append(status)
				attributes.append(error_message)
				new_feature.setAttributes(attributes)
				continue
			# No results found (shouldn't happen?)
			if (not "results" in json_array) or (len(json_array["results"]) <= 0):
				attributes.append("No results")
				continue
			# Iterate through results
			for result_num, result in enumerate(json_array['results']):
				# Collect attributes
				attributes.append(str(result_num))
				if "formatted_address" in result:
					attributes.append(str(result["formatted_address"]))
				else:
					attributes.append("")
				if "place_id" in result:
					attributes.append(str(result["place_id"]))
				else:
				try:
					latitude = float(result["geometry"]["location"]["lat"])
					longitude = float(result["geometry"]["location"]["lng"])
					attributes.append(str(result["geometry"]["location_type"]))
					attributes.append(str(latitude) + "," + str(longitude))
				# Add feature
				result_count = result_count + 1
				if use_first:
					break
		else: # OSM/Nominatim
			# https://nominatim.org/release-docs/develop/api/Reverse/
			if "error" in json_array:
				if "message" in json_array["error"]:
					error_message = json_array["error"]["message"]
				else:
					error_message = "Undefined Error"
				continue
			if (not "features" in json_array) or (len(json_array["features"]) <= 0):
				continue
			for result_num, result in enumerate(json_array['features']):
				for property_name in ["osm_id", "display_name", "category", "type"]:
					if ("properties" in result) and (property_name in result["properties"]):
						attributes.append(str(result["properties"][property_name]))
					else:
				try:
					latitude = float(result["geometry"]["coordinates"][1])
					longitude = float(result["geometry"]["coordinates"][0])
				# Add feature
				if use_first:
					break
	del outfile
	if status_callback:
		status_callback(100, str(result_count) + " of " + str(input_layer.featureCount()) + " reverse geocoded")
	return None
#    mmqgis_geocode_street_layer - Geocode addresses from street address finder layer
# Use common address abbreviations to reduce naming discrepancies and improve hit ratio
def mmqgis_searchable_streetname(name):
	# print "searchable_name(" + str(name) + ")"
	if not name:
		return ""
	# name = str(name).strip().lower()
	name = name.strip().lower()
	name = name.replace(".", "")
	name = name.replace(" street", " st")
	name = name.replace(" avenue", " av")
	name = name.replace(" plaza", " plz")
	name = name.replace(" drive", " dr")
	name = name.replace("saint ", "st ")
	name = name.replace("fort ", "ft ")
	name = name.replace(" ave", " av")
	name = name.replace("east", "e")
	name = name.replace("west", "w")
	name = name.replace("north", "n")
	name = name.replace("south", "s")
	name = name.replace("1st", "1")
	name = name.replace("2nd", "2")
	name = name.replace("3rd", "3")
	name = name.replace("4th", "4")
	name = name.replace("5th", "5")
	name = name.replace("6th", "6")
	name = name.replace("7th", "7")
	name = name.replace("8th", "8")
	name = name.replace("9th", "9")
	name = name.replace("0th", "0")
	name = name.replace("1th", "1")
	name = name.replace("2th", "2")
	name = name.replace("3th", "3")
	name = name.replace("first", "1")
	name = name.replace("second", "2")
	name = name.replace("third", "3")
	name = name.replace("fourth", "4")
	name = name.replace("fifth", "5")
	name = name.replace("sixth", "6")
	name = name.replace("seventh", "7")
	name = name.replace("eighth", "8")
	name = name.replace("ninth", "9")
	name = name.replace("tenth", "10")
	return name
def mmqgis_geocode_street_layer(input_csv_name, number_column, street_name_column, zip_column, \
	input_layer, street_name_attr, left_from_attr, left_to_attr, left_zip_attr, \
	right_from_attr, right_to_attr, right_zip_attr, \
	from_x_attr, from_y_attr, to_x_attr, to_y_attr, setback, \
	output_file_name, not_found_file, status_callback = None):
	# Error checks
	try:
	except:
		return "Invalid input street layer"
	if (input_layer.wkbType() != QgsWkbTypes.LineString) and \
	   (input_layer.wkbType() != QgsWkbTypes.LineString25D) and \
	   (input_layer.wkbType() != QgsWkbTypes.MultiLineString) and \
	   (input_layer.wkbType() != QgsWkbTypes.MultiLineString25D):
		return "Street layer must be lines or multilines (WKB Type " + str(input_layer.wkbType()) + ")"
	if (not street_name_attr) or (input_layer.dataProvider().fieldNameIndex(str(street_name_attr)) < 0):
		return "Invalid street name attribute: " + str(street_name_attr)
	if (not left_from_attr) or (input_layer.dataProvider().fieldNameIndex(str(left_from_attr)) < 0):
		return "Invalid left from attribute: " + str(left_from_attr)
	if (not left_to_attr) or (input_layer.dataProvider().fieldNameIndex(str(left_to_attr)) < 0):
		return "Invalid left to attribute: " + str(left_to_attr)
	if left_zip_attr and (input_layer.dataProvider().fieldNameIndex(str(left_zip_attr)) < 0):
		return "Invalid left ZIP Code attribute: " + str(left_zip_attr)
	if (not right_from_attr) or (input_layer.dataProvider().fieldNameIndex(str(right_from_attr)) < 0):
		return "Invalid right from attribute: " + str(right_from_attr)
	if (not right_to_attr) or (input_layer.dataProvider().fieldNameIndex(str(right_to_attr)) < 0):
		return "Invalid right to attribute: " + str(right_to_attr)
	if right_zip_attr and (input_layer.dataProvider().fieldNameIndex(str(right_zip_attr)) < 0):
		return "Invalid right ZIP Code attribute: " + str(right_zip_attr)
	if from_x_attr and (input_layer.dataProvider().fieldNameIndex(str(from_x_attr)) < 0):
		return "Invalid from x attribute: " + str(from_x_attr)
	if from_y_attr and (input_layer.dataProvider().fieldNameIndey(str(from_y_attr)) < 0):
		return "Invalid from y attribute: " + str(from_y_attr)
	if to_x_attr and (input_layer.dataProvider().fieldNameIndex(str(to_x_attr)) < 0):
		return "Invalid to x attribute: " + str(to_x_attr)
	if to_y_attr and (input_layer.dataProvider().fieldNameIndey(str(to_y_attr)) < 0):
		return "Invalid to y attribute: " + str(to_y_attr)
	try:
		setback = float(setback)
		return "Invalid setback value: " + str(e)
	# Open CSV file and validate fields
	if status_callback:
		status_callback(0, "Opening Files")
	if input_csv.dataProvider().fieldNameIndex(str(number_column)) < 0:
		return "Invalid CSV number column: " + str(number_column)
	if input_csv.dataProvider().fieldNameIndex(str(street_name_column)) < 0:
		return "Invalid CSV street name column: " + str(street_name_column)
	if zip_column and (input_csv.dataProvider().fieldNameIndex(str(zip_column)) < 0):
		return "Invalid CSV ZIP Code column: " + str(zip_column)
	# Create the not found file for addresses that were not valid or not found
	not_found = QgsVectorFileWriter(not_found_file, "utf-8", input_csv.fields(), \
		QgsWkbTypes.Unknown, driverName = "CSV")
	if (not_found.hasError() != QgsVectorFileWriter.NoError):
		return "Failure creating not found CSV file: " + str(not_found.errorMessage())
	new_fields = input_csv.fields()
	new_fields.append(QgsField("Longitude", QVariant.Double, "real", 24, 16))
	new_fields.append(QgsField("Latitude", QVariant.Double, "real", 24, 16))
	new_fields.append(QgsField("Side", QVariant.String))
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", new_fields, QgsWkbTypes.Point, \
	# Iterate through each CSV row
	matched_count = 0
	for address_index, address in enumerate(input_csv.getFeatures()):
		if status_callback and ((address_index % 2) == 0):
			if status_callback(100 * address_index / input_csv.featureCount(),
			   str(matched_count) + " of " + str(address_index) + " matched"):
				return "Cancelled geocode at address " + \
					str(address_index) + " of " + str(input_csv.featureCount())
		# Find parts of this address
		street = mmqgis_searchable_streetname(str(address.attribute(street_name_column)))
		if not street:
			new_feature.setAttributes(address.attributes())
			not_found.addFeature(new_feature)
			continue
		try:
			number = int(address.attribute(number_column))
		except:
			number = 0
		zip_code = None
		if zip_column:
			zip_code = str(address.attribute(zip_column))
		# Iterate through each feature in the street layer
		found = False
			# Compare street names
			feature_street = mmqgis_searchable_streetname(str(feature.attribute(street_name_attr)))
			if (not feature_street) or (feature_street != street):
				# Not on this street
				continue
			# Compare street numbers and find distance along the side
			try:
				left_to_number = int(feature.attribute(left_to_attr))
				left_from_number = int(feature.attribute(left_from_attr))
				right_to_number = int(feature.attribute(right_to_attr))
				right_from_number = int(feature.attribute(right_from_attr))
			except:
				left_to_number = 0
				left_from_number = 0
				right_to_number = 0
				right_from_number = 0
			left_side = False
			right_side = False
			if ((left_from_number < left_to_number) and \
			    (number >= left_from_number) and (number <= left_to_number)) or \
			   ((number <= left_from_number) and (number >= left_to_number)):
				left_side = True
				if left_from_number == left_to_number:
					distance_ratio = 0
				else:
					distance_ratio = (number - left_from_number) / (left_to_number - left_from_number)
			if ((right_from_number < right_to_number) and \
			    (number >= right_from_number) and (number <= right_to_number)) or \
			   ((number <= right_from_number) and (number >= right_to_number)):
				# Check odd/even numbering match
				if (not left_side) or ((number % 2) == (right_from_number % 2)):
					left_side = False
					right_side = True
					if right_from_number == right_to_number:
						distance_ratio = 0
					else:
						distance_ratio = (number - right_from_number) / \
							(right_to_number - right_from_number)
			if (not left_side) and (not right_side):
				continue
			#print("Street match " + feature_street + " number " + \
			#	str(number) + " right " + str(right_from_number) + " - " + str(right_to_number) + \
			#	", left " + str(left_from_number) + " - " + str(left_to_number) + " = " + \
			#	str(left_side) + ", " + str(right_side))
			# Compare ZIP Codes
			# Exclusion condition to filter duplicate street/number addresses in different zip codes
			if zip_code:
				if left_zip_attr and (zip_code != str(feature.attribute(left_zip_attr))) and \
				   right_zip_attr and (zip_code != str(feature.attribute(right_zip_attr))):
					#print("ZIP exclude " + str(zip_code) + " <> " \
					#	+ str(feature.attribute(left_zip_attr)) \
					#	+ " <> " + str(feature.attribute(right_zip_attr)))
					continue
			# Find line start and end points
			if (geometry.wkbType() == QgsWkbTypes.LineString) or \
			   (geometry.wkbType() == QgsWkbTypes.LineString25D):
				line = geometry.asPolyline()
			elif (geometry.wkbType() == QgsWkbTypes.MultiLineString) or \
				line = []
				for polyline in geometry.asMultiPolyline():
					for point in polyline:
						line.append(point)
			else:
				continue # errant geometry type?!
			# Assume from/to x/y ignores input layer geometry
			if from_x_attr and feature.attributes(from_x_attr) and \
			   from_y_attr and feature.attributes(from_y_attr) and \
			   to_x_attr and feature.attributes(to_x_attr) and \
			   to_y_attr and feature.attributes(to_y_attr):
				try:
					polyline = [QgsPointXY(float(feature.attributes(from_x_attr)),
							float(feature.attributes(from_y_attr))),
						    QgsPointXY(float(feature.attributes(to_x_attr)),
							float(feature.attributes(to_y_attr)))]
					line = QgsGeometry.fromPolyline(polyline)
				except:
					line = line
			# Find total line length
			total_length = 0
			for z in range(len(line) - 1):
				x_diff = line[z + 1][0] - line[z][0]
				y_diff = line[z + 1][1] - line[z][1]
				total_length = total_length + pow(pow(x_diff, 2) + pow(y_diff, 2), 0.5)
			# Find the position along the street centerline
			x = line[0][0]
			y = line[0][1]
			start_distance = 0;
			distance_along_centerline = setback + (distance_ratio * (total_length - (2 * setback)))
				segment_length = pow(pow(x_diff, 2) + pow(y_diff, 2), 0.5)
				end_distance = start_distance + segment_length
				if distance_along_centerline > end_distance:
					start_distance = end_distance
					continue
				segment_ratio = (distance_along_centerline - start_distance) / (end_distance - start_distance)
				x = line[z][0] + (segment_ratio * (line[z + 1][0] - line[z][0]))
				y = line[z][1] + (segment_ratio * (line[z + 1][1] - line[z][1]))
				# Setback from centerline
				bearing = atan2(y_diff, x_diff)
				# print("Number " + str(number) + ", segment " + str(z) \
				#	+ ", bearing, " + str(bearing) + ", left " \
				#	+ str(left_side) + ", right odd agreement " \
				#	+ str((not left_side) or ((number % 2) == (right_from_number % 2))))
				if right_side:
					x = x + (setback * sin(bearing))
					y = y - (setback * cos(bearing))
				else:
					x = x - (setback * sin(bearing))
					y = y + (setback * cos(bearing))
				break
			# Create the output feature
			new_attributes = address.attributes()
			new_attributes.append(x)
			new_attributes.append(y)
			if left_side:
				new_attributes.append("Left")
			else:
				new_attributes.append("Right")
			newfeature.setAttributes(new_attributes)
			newfeature.setGeometry(QgsGeometry.fromPointXY(QgsPointXY(x, y)))
			matched_count = matched_count + 1
			found = True
			break
		if not found:
	# Done
	if status_callback:
		status_callback(100, str(matched_count) + " of " + str(input_csv.featureCount()) + " geocoded")
	return None
#    mmqgis_geocode_web_service - Geocode CSV points from a web service
def mmqgis_geocode_web_service(input_csv_name, parameter_attributes, web_service, api_key, use_first,
	output_file_name, not_found_file_name, status_callback = None):
	# Error checks
	supported_services = ["Google", "OpenStreetMap / Nominatim", "US Census Bureau", "ESRI Server", "NetToolKit"]
	if web_service not in supported_services:
	if (web_service in ["Google", "NetToolKit"]) and (not api_key):
		return "A " + web_service + " API key is required to use this service"
	if (web_service == "ESRI Server") and ((not api_key) or (api_key[0:5] != "https")):
		return "An ESRI server URL is required to use ESRI geocoding"
	# Load the CSV file
	# Dictionary of key indices into attributes
	if not parameter_attributes or (not len(parameter_attributes)):
		return "Invalid search parameters"
	parameter_indices = []
	for attribute in parameter_attributes:
		index = input_csv.fields().indexOf(attribute[1])
		if index < 0:
			return "Invalid parameter attribute: " + attribute[1]
		parameter_indices.append((attribute[0], index))
	# Create attributes from field names in header
	# Add fields for the <type> and <location_type> returned by Google
	# or the class and type returned by OSM
	for field in input_csv.fields():
		for field_name in ["result_num", "status", "formatted_address", "place_id", "location_type", "latlong"]:
	elif web_service == "ESRI Server":
		for field_name in ["result_num", "score", "address_match", "Loc_name", "Addr_type", "User_fld", "latlong"]:
	elif web_service == "US Census Bureau":
		for field_name in ["result_num", "matchedAddress", "tigerLineId", "side", "latlong"]:
	elif web_service == "NetToolKit":
		for field_name in ["result_num", "address", "provider", "latlong"]:
	# Create the CSV file for ungeocoded records
	try:
		notfound = open(not_found_file_name, 'w')
		return str(e)
	# Kludge to prevent writer from crashing in Windoze
	# Opening in local encoding rather than UTF-8?
	# dialect.escapechar = '\\'
	notwriter = csv.writer(notfound)
	notwriter.writerow([x.name() for x in input_csv.fields()])
	# Web geocoders use WGS 84 lat/long
	crs = QgsCoordinateReferenceSystem()
	crs.createFromSrid(4326)
	# Create the output spatial file
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", fields, QgsWkbTypes.Point, \
	# Proxy settings from qgis options settings
	# Geocode and import
	matched_count = 0
	for row_number, row in enumerate(input_csv.getFeatures()):
		if status_callback and ((row_number % 5) == 0):
			if status_callback(100 * row_number / input_csv.featureCount(), \
			   str(row_number) + " of " + str(input_csv.featureCount()) + " = " + str(matched_count) + " found"):
				return "Cancelled a row " + str(row_number) + " of " + str(input_csv.featureCount())
		# Build escaped search parameters
		parameters = []
		for index in parameter_indices:
			if index[1] < len(row.attributes()):
				value = row.attributes()[index[1]]
			else:
				value = ""
			try:
				# The str coversion throws an exception on non-utf-8 characters
				# However, urllib.quote() requires the encoded string or it throws an error
				# utf8_test = str(row[x], "utf-8").strip()
				# print utf8_test
				value = urllib.parse.quote(value.strip())
				value = value.replace(" ","+")
				value = ""
			parameters.append((index[0], value))
		# Build composite address used by Google and Nominatim
		address = ""
		sorted_names = list
		for parameter in parameters:
			if len(address) > 0:
				address += "%2C"
			address += parameter[1]
		# Skip if no search keys
		if len(address) <= 0:
			notwriter.writerow(attributes)
			continue
		# Create API URL
			url = "https://maps.googleapis.com/maps/api/geocode/json?sensor=false&address=" \
				+ address + "&key=" + api_key
			url = "http://nominatim.openstreetmap.org/search?format=geojson&q=" + address
			# api_key field is used as the server URL with ESRI servers
			url = api_key + "?SingleLine=" + address + \
				"&category=&outFields=*&maxLocations=&outSR=4326" + \
				"&searchExtent=&location=&distance=&magicKey=&f=json"
			url = "https://geocoding.geo.census.gov/geocoder/locations/address?&benchmark=4&format=json"
			# street, city, state
				if parameter[0].lower() == "address":
					url = url + "&street=" + str(parameter[1])
				else:
					url = url + "&" + str(parameter[0]).lower() + "=" + str(parameter[1])
			# API key is passed in the HTTP header below
			url = "https://api.nettoolkit.com/v1/geo/geocodes?address=" + address
		# Query the API
		max_attempts = 5
			try:
				headers = {'User-Agent': "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_3)"}
					headers['X-NTK-KEY'] = api_key
				# print(headers)
				request = urllib.request.Request(url, headers = headers)
				# print(str(json_string) + "\n\n")
				break
				time.sleep(1)
		try:
			continue
		# Interpret the response
			if (not "status" in json_array) or \
			   (not "results" in json_array) or \
			   (len(json_array['results']) <= 0):
				notwriter.writerow(row.attributes())
				continue
				error_message = json_array["error_message"]
			else:
				error_message = ""
			if (json_array["status"] == "REQUEST_DENIED") or \
			   (json_array["status"] == "OVER_QUERY_LIMIT"):
				return str(json_array["status"]) + ": " + str(error_message)
			if json_array["status"] != "OK":
				continue
			for result_num, result in enumerate(json_array["results"]):
				try:
					# Invalid result
					break
				attributes = row.attributes()
				attributes.append(str(json_array["status"]))
				else:
				else:
				if "location_type" in result["geometry"]:
				else:
				# Add new feature
				newfeature.setGeometry(QgsGeometry.fromPointXY(QgsPointXY(longitude, latitude)))
				matched_count += 1
				if use_first:
					break
			# https://nominatim.org/release-docs/develop/api/Search/
				continue
			for result_num, result in enumerate(json_array["features"]):
				try:
					# Invalid result
					break
					if property_name in result["properties"]:
					else:
				# Create feture
				matched_count += 1
				if use_first:
					break
			if ("candidates" not in json_array) or (len(json_array["candidates"]) <= 0):
				continue
			for result_num, result in enumerate(json_array["candidates"]):
				try:
					latitude = float(result["location"]["y"])
					longitude = float(result["location"]["x"])
					break
				if "score" in result:
					attributes.append(str(result["score"]))
				else:
				if "address" in result:
					attributes.append(str(result["address"]))
				else:
				for attribute_name in ["Loc_name", "Addr_type", "User_fld"]:
					if attribute_name in result["attributes"]:
						attributes.append(str(result["attributes"][attribute_name]))
					else:
				# Add feature
				matched_count += 1
				if use_first:
					break
			if (not "result" in json_array) or \
			   (not "addressMatches" in json_array["result"]) or \
			   (len(json_array["result"]["addressMatches"]) <= 0):
				continue
			for result_num, result in enumerate(json_array["result"]["addressMatches"]):
				try:
					latitude = float(result["coordinates"]["y"])
					longitude = float(result["coordinates"]["x"])
					break
				if "matchedAddress" in result:
					attributes.append(str(result["matchedAddress"]))
				else:
				if "tigerLine" in result:
					if "tigerLineId" in result["tigerLine"]:
						attributes.append(str(result["tigerLine"]["tigerLineId"]))
					else:
					if "side" in result["tigerLine"]:
						attributes.append(str(result["tigerLine"]["side"]))
					else:
				# Add feature
				matched_count += 1
				if use_first:
					break
		elif (web_service == "NetToolKit"):
			if not "results" in json_array:
				continue
				try:
					latitude = float(result["latitude"])
					longitude = float(result["longitude"])
					break
				attributes.append(str(result_num + 1))
				else:
				if "provider" in result:
					attributes.append(str(result["provider"]))
				else:
				# Add feature
				matched_count += 1
				if use_first:
					break
		else:
			return "Invalid web service: " + web_service
	del outfile
	del notwriter
	if status_callback:
		status_callback(100, "Geocoded " + str(matched_count) + " of " + str(input_csv.featureCount()))
	return None
#    mmqgis_geometry_convert - Convert geometries to simpler types
def mmqgis_line_center(geometry, distance_percent):
	try:
		geometry_type = geometry.wkbType()
	except:
		return None
	# Find the list of node points
	# This function is only really meaningful for linestrings
	if (geometry_type in [QgsWkbTypes.Point, QgsWkbTypes.PointZ, QgsWkbTypes.Point25D]):
		return geometry
	elif (geometry_type in [QgsWkbTypes.LineString, QgsWkbTypes.LineStringZ, QgsWkbTypes.LineString25D]):
	elif (geometry_type in [QgsWkbTypes.Polygon, QgsWkbTypes.PolygonZ, QgsWkbTypes.Polygon25D]):
		points = geometry.asPolygon()[0]
	elif (geometry_type in [QgsWkbTypes.MultiPoint, QgsWkbTypes.MultiPointZ, QgsWkbTypes.MultiPoint25D]):
		points = geometry.asMultiPoint()
	elif (geometry_type in [QgsWkbTypes.MultiLineString, QgsWkbTypes.MultiLineStringZ, QgsWkbTypes.MultiLineString25D]):
		points = geometry.asMultiPolyline()[0]
	elif (geometry_type in [QgsWkbTypes.MultiPolygon, QgsWkbTypes.MultiPolygonZ, QgsWkbTypes.MultiPolygon25D]):
		points = geometry.asMultiPolygon()[0][0]
	else:
		return None
	# Returns for invalid parameters
	if (len(points) <= 0):
		return None
	if (len(points) <= 1):
		return QgsGeometry.fromPointXY(points[0])
	if (distance_percent <= 0):
	if (distance_percent >= 100):
		return QgsGeometry.fromPointXY(points[len(points) - 1])
	# Find lengths of segments between nodes
	segment_length = []
	for index in range(0, len(points) - 1):
		point1 = points[index]
		point2 = points[index + 1]
		length = sqrt(((point1.x() - point2.x())**2) + ((point1.y() - point2.y())**2))
		segment_length = segment_length + [length]
	# Find the point on the appropriate segment line
	segment_start = 0
	distance = sum(segment_length) * distance_percent / 100.0
	for index in range(0, len(segment_length)):
		segment_end = segment_start + segment_length[index]
		if (distance >= segment_start) and (distance <= segment_end):
			if (segment_length[index] <= 0):
				ratio = 0
			else:
				ratio = (distance - segment_start) / segment_length[index]
			xdiff = points[index + 1].x() - points[index].x()
			ydiff = points[index + 1].y() - points[index].y()
			linex = points[index].x() + (xdiff * ratio)
			liney = points[index].y() + (ydiff * ratio)
			return QgsGeometry.fromPointXY(QgsPointXY(linex, liney))
		segment_start = segment_end
	# Graceful failure - Shouldn't ever get here
def mmqgis_geometry_convert(input_layer, new_geometry, output_file_name, status_callback = None):
	if (not input_layer) or (input_layer.type() != QgsMapLayer.VectorLayer):
		return "Vector layer required"
	# Create output file
	if (new_geometry == "Points") or (new_geometry == "Centroids") or \
	   (new_geometry == "Nodes") or (new_geometry == "Line Centers"):
		new_geometry_wkb = QgsWkbTypes.Point
	elif (new_geometry == "Lines"):
		new_geometry_wkb = QgsWkbTypes.LineString
	elif (new_geometry == "Polygons"):
		new_geometry_wkb = QgsWkbTypes.Polygon
	elif (new_geometry == "Multipoints"):
		new_geometry_wkb = QgsWkbTypes.MultiPoint
	elif (new_geometry == "Multilines"):
		new_geometry_wkb = QgsWkbTypes.MultiLineString
	elif (new_geometry == "Multipolygons"):
		new_geometry_wkb = QgsWkbTypes.MultiPolygon
	else:
		return "Invalid type for new geometry: " + str(new_geometry)
		new_geometry_wkb, input_layer.crs(), output_file_format)
	out_count = 0
	for feature_index, feature in enumerate(input_layer.getFeatures()):
		# shapeid = str(feature.id()).strip()
		if status_callback and ((feature_index % 10) == 0):
				"Feature " + str(feature_index) + " of " + str(input_layer.featureCount())):
				return "Canceled on feature " + str(feature_index) + " of" + str(input_layer.featureCount())
		if (feature.geometry().wkbType() in [QgsWkbTypes.Point, QgsWkbTypes.PointZ, QgsWkbTypes.Point25D]):
			if (new_geometry == "Points"):
				newfeature.setGeometry(QgsGeometry.fromPointXY(feature.geometry().asPoint()))
				out_count = out_count + 1
			else:
				return "Invalid Conversion: " + \
					QgsWkbTypes.displayString(feature.geometry().wkbType()) + \
					" to " + str(new_geometry)
		elif (feature.geometry().wkbType() == QgsWkbTypes.LineString) or \
		     (feature.geometry().wkbType() == QgsWkbTypes.LineString25D):
			if (new_geometry == "Nodes"):
				polyline = feature.geometry().asPolyline()
					newfeature.setGeometry(QgsGeometry.fromPointXY(point))
			elif (new_geometry == "Centroids"):
				newfeature.setGeometry(feature.geometry().centroid())
			elif (new_geometry == "Line Centers"):
				point = mmqgis_line_center(feature.geometry(), 50.0)
				if (not point):
					continue
				newfeature.setGeometry(point)
				newfeature.setGeometry(QgsGeometry.fromMultiPolyline([feature.geometry().asPolyline()]))
			else:
					" to " + new_geometry
		elif (feature.geometry().wkbType() == QgsWkbTypes.Polygon) or \
		     (feature.geometry().wkbType() == QgsWkbTypes.Polygon25D):
				polygon = feature.geometry().asPolygon()
				for polyline in polygon:
					newfeature.setGeometry(QgsGeometry.fromPolylineXY(polyline))
				linestrings = []
					linestrings.append(polyline)
				newfeature.setGeometry(QgsGeometry.fromMultiPolyline(linestrings))
			else:
				return "Invalid Conversion: " + QgsWkbTypes.displayString(feature.geometry().wkbType()) + \
		elif (feature.geometry().wkbType() in \
				points = feature.geometry().asMultiPoint()
				for point in points:
			else:
		elif (feature.geometry().wkbType() == QgsWkbTypes.MultiLineString) or \
		     (feature.geometry().wkbType() == QgsWkbTypes.MultiLineString25D):
				polylines = feature.geometry().asMultiPolyline()
				for polyline in polylines:
				linestrings = feature.geometry().asMultiPolyline()
				for linestring in linestrings:
					newfeature.setGeometry(QgsGeometry.fromPolylineXY(linestring))
					line_center = mmqgis_line_center(QgsGeometry.fromPolylineXY(linestring), 50.0)
					newfeature.setGeometry(line_center)
			else:
		elif (feature.geometry().wkbType() == QgsWkbTypes.MultiPolygon) or \
		     (feature.geometry().wkbType() == QgsWkbTypes.MultiPolygon25D):
				polygons = feature.geometry().asMultiPolygon()
				for polygon in polygons:
					newfeature.setGeometry(QgsGeometry.fromPolygonXY(polygon))
			elif (new_geometry == "Multilines") or (new_geometry == "Multipolygons"):
				newfeature.setGeometry(QgsGeometry.fromMultiPolygonXY(polygons))
			else:
	del outfile
	if status_callback:
		status_callback(100, str(input_layer.featureCount()) + " features converted to " + str(out_count))
	return None
#    mmqgis_geometry_to_multipart - Convert singlepart to multipart geometries
def mmqgis_geometry_to_multipart(input_layer, merge_field, attribute_handling, output_file_name, status_callback = None):
	# Error checking
		return "Invalid Vector Layer"
	point_types = [ QgsWkbTypes.Point, QgsWkbTypes.PointZ, QgsWkbTypes.Point25D,
		QgsWkbTypes.MultiPoint, QgsWkbTypes.MultiPointZ, QgsWkbTypes.MultiPoint25D ]
	line_types = [ QgsWkbTypes.LineString, QgsWkbTypes.LineStringZ, QgsWkbTypes.LineString25D,
		QgsWkbTypes.MultiLineString, QgsWkbTypes.MultiLineStringZ, QgsWkbTypes.MultiLineString25D ]
	polygon_types = [ QgsWkbTypes.Polygon, QgsWkbTypes.PolygonZ, QgsWkbTypes.Polygon25D,
		QgsWkbTypes.MultiPolygon, QgsWkbTypes.MultiPolygonZ, QgsWkbTypes.MultiPolygon25D ]
	if (input_layer.wkbType() in point_types):
		new_type = QgsWkbTypes.MultiPoint
	elif (input_layer.wkbType() in line_types):
		new_type = QgsWkbTypes.MultiLineString
	elif (input_layer.wkbType() in polygon_types):
		new_type = QgsWkbTypes.MultiPolygon
	else:
		return "Geometry is already multipart: " + QgsWkbTypes.displayString(input_layer.wkbType())
	merge_index = input_layer.dataProvider().fieldNameIndex(merge_field)
	if merge_index < 0:
		return "Invalid merge field: " + merge_field
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", input_layer.fields(), new_type, input_layer.crs(),
		output_file_format)
	# Get a list of all unique keys
	keys = []
		attribute = feature.attributes()[merge_index]
		if not attribute in keys:
			keys.append(attribute)
	# Iterate through each key and each feature in the source layer
	merge_count = 0
	for index, key in enumerate(keys):
		new_geometry = []
		new_attributes = []
		if status_callback and ((index % 5) == 0):
			if status_callback(100 * index / len(keys),
				"Converting " + str(index) + " of " + str(len(keys))):
				return "Canceled on feature " + str(index) + " of " + str(len(keys))
			if feature.attributes()[merge_index] != key:
				continue
			# Convert geometry
			if new_type == QgsWkbTypes.MultiPoint:
					new_geometry.append(feature.geometry().asPoint())
					for point in feature.geometry().asMultiPoint():
						new_geometry.append(point)
				else:
					return "Invalid multipoint geometry type: " + str(feature.geometry().wkbType())
			elif new_type == QgsWkbTypes.MultiLineString:
					[ QgsWkbTypes.LineString, QgsWkbTypes.LineStringZ, QgsWkbTypes.LineString25D]):
					new_geometry.append(feature.geometry().asPolyline())
					[QgsWkbTypes.MultiLineString, QgsWkbTypes.MultiLineStringZ, \
					for polyline in feature.geometry().asMultiPolyline():
						new_geometry.append(polyline)
				else:
					return "Invalid multilinestring geometry type: " + \
			else: # new_type == QgsWkbTypes.MultiPolygon:
					new_geometry.append(feature.geometry().asPolygon())
					for polygon in feature.geometry().asMultiPolygon():
						new_geometry.append(polygon)
				else:
					return "Invalid multipolygon geometry type: " + \
			# Convert attributes
			if len(new_attributes) <= 0:
				new_attributes = feature.attributes()
			elif attribute_handling == "Sum":
				for zindex, zfield in enumerate(input_layer.fields()):
					zvalue = feature.attributes()[zindex]
					if (zfield.type() == QVariant.Int):
						#xval, test = attributes[zindex].toInt()
						#yval, test = features[y].attributes()[zindex].toInt()
						#attributes[zindex] = QVariant(xval + yval)
						try:
							xval = int(new_attributes[zindex])
							yval = int(zvalue)
							new_attributes[zindex] = xval + yval
						except:
							new_attributes[zindex] = 0
					elif (zfield.type() == QVariant.Double):
						# xval, test = attributes[zindex].toDouble()
						# yval, test = features[y].attributes()[zindex].toDouble()
						# attributes[zindex] = QVariant(xval + yval)
						try:
							xval = float(new_attributes[zindex])
							yval = float(zvalue)
						except:
					# print "      Sum " + str(zindex) + ": " + \
					#	str(attributes[zindex].typeName())
			# print str(key) + ": " + str(type(newgeometry)) + ": " + str(len(newgeometry))
		new_feature.setAttributes(new_attributes)
			new_feature.setGeometry(QgsGeometry.fromMultiPointXY(new_geometry))
			new_feature.setGeometry(QgsGeometry.fromMultiPolylineXY(new_geometry))
		else: # WKBMultiPolygon:
			new_feature.setGeometry(QgsGeometry.fromMultiPolygonXY(new_geometry))
	del outfile
	if status_callback:
		status_callback(100, str(input_layer.featureCount()) + " features merged to " + str(len(keys)))
	return None
#    mmqgis_geometry_export_to_csv - Shape node dump to CSV
def mmqgis_geometry_export_to_csv(input_layer, node_file_name, attribute_file_name, \
	field_delimiter = ",", line_terminator = "\n", status_callback = None):
		return "Invalid Vector Layer " + input_layername
	# CSV Options
	layer_options = []
	else:
	else:
	# Build field list for CSV file
	node_fields = QgsFields()
	node_fields.append(QgsField("shapeid", QVariant.Int))
	node_fields.append(QgsField("partid", QVariant.Int))
	node_fields.append(QgsField("x", QVariant.Double))
	node_fields.append(QgsField("y", QVariant.Double))
	attribute_fields = QgsFields()
	attribute_fields.append(QgsField("shapeid", QVariant.Int))
		if input_layer.wkbType() in [QgsWkbTypes.Point, QgsWkbTypes.PointZ, QgsWkbTypes.Point25D]:
			node_fields.append(field)
		else:
			attribute_fields.append(field)
	# Create file writers
	node_file = QgsVectorFileWriter(node_file_name, "utf-8", node_fields, \
	if (node_file.hasError() != QgsVectorFileWriter.NoError):
		return "Failure creating output node file: " + str(node_file.errorMessage())
	attribute_file = None
	if not input_layer.wkbType() in [QgsWkbTypes.Point, QgsWkbTypes.PointZ, QgsWkbTypes.Point25D]:
		attribute_file = QgsVectorFileWriter(attribute_file_name, "utf-8", \
			attribute_fields, QgsWkbTypes.Unknown, \
		if (attribute_file.hasError() != QgsVectorFileWriter.NoError):
			return "Failure creating output attribute file: " + str(attribute_file.errorMessage())
	feature_type = ""
	for shape_id, feature in enumerate(input_layer.getFeatures()):
		feature_type = str(QgsWkbTypes.displayString(feature.geometry().wkbType()))
		# print "Feature " + str(feature_index) + " = " + feature_type
		if status_callback and ((shape_id % 10) == 0):
			if status_callback(100 * shape_id / input_layer.featureCount(), \
					"Exporting " + str(shape_id) + " of " + str(input_layer.featureCount())):
				return "Cancelled " + str(shape_id) + " of " + str(input_layer.featureCount())
		# Build attributes
		node = [ shape_id, None, None, None ]
		attributes = [ shape_id ]
		for attribute in feature.attributes():
			node.append(attribute)
			attributes.append(attribute)
		# Write attributes
		if not feature.geometry().wkbType() in [QgsWkbTypes.Point, QgsWkbTypes.PointZ, QgsWkbTypes.Point25D]:
			attribute_file.addFeature(new_feature)
		# Write nodes
		if (feature.geometry() == None):
			new_feature.setAttributes(node)
			node_file.addFeature(new_feature)
		elif feature.geometry().wkbType() in [QgsWkbTypes.Point, QgsWkbTypes.PointZ, QgsWkbTypes.Point25D]:
			point = feature.geometry().asPoint()
			node[2] = point.x()
			node[3] = point.y()
		elif feature.geometry().wkbType() in \
			[QgsWkbTypes.MultiPoint, QgsWkbTypes.MultiPointZ, QgsWkbTypes.MultiPoint25D]:
			for part_id, point in enumerate(feature.geometry().asMultiPoint()):
				node[1] = part_id
				node[2] = point.x()
				node[3] = point.y()
			[QgsWkbTypes.LineString, QgsWkbTypes.LineStringZ, QgsWkbTypes.LineString25D]:
			for point in feature.geometry().asPolyline():
				node[2] = point.x()
				node[3] = point.y()
		elif feature.geometry().wkbType() in [QgsWkbTypes.MultiLineString, QgsWkbTypes.MultiLineString25D]:
			for part_id, polyline in enumerate(feature.geometry().asMultiPolyline()):
					node[1] = part_id
					node[2] = point.x()
					node[3] = point.y()
		elif feature.geometry().wkbType() in [QgsWkbTypes.Polygon, QgsWkbTypes.PolygonZ, QgsWkbTypes.Polygon25D]:
			# The first polyline in the polygon is the outer ring
			# Subsequent polylines (if any) are inner rings (holes)
			for part_id, polyline in enumerate(feature.geometry().asPolygon()):
					node[1] = part_id
					node[2] = point.x()
					node[3] = point.y()
					row = [ shape_id, str(point.x()), str(point.y()) ]
					node_file.writerow(row)
			[QgsWkbTypes.MultiPolygon, QgsWkbTypes.MultiPolygonZ, QgsWkbTypes.MultiPolygon25D]:
			# This needs to deal with multipolygon -> polygon -> ring/holes -> nodes
			for part_id, polygon in enumerate(feature.geometry().asMultiPolygon()):
						node[1] = part_id
						node[2] = point.x()
						node[3] = point.y()
		else:
			return "Unsupported geometry: " + str(QgsWkbTypes.displayString(feature.geometry().wkbType()))
	# Close and return
	del node_file
	if attribute_file:
		del attribute_file
	if status_callback:
		status_callback(100, str(feature_count) + " " + feature_type + " exported")
	return None
#    mmqgis_geometry_import_from_csv - Shape node import from CSV
def mmqgis_geometry_import_from_csv(input_csv_name, shape_id_field, part_id_field, \
		geometry_type, latitude_field, longitude_field, \
	# Parameter error checks and conversions
	if input_csv.featureCount() <= 0:
		return "Invalid CSV node file"
	if geometry_type != "Point":
		shape_id_index = input_csv.fields().indexFromName(shape_id_field)
		if shape_id_index < 0:
			return "Invalid shape ID field"
	else:
		shape_id_index = -1
	if geometry_type in ["MultiPoint", "MultiLineString", "MultiPolygon"]:
		part_id_index = input_csv.fields().indexFromName(part_id_field)
		if part_id_index < 0:
			return "Invalid part ID field"
	else:
		part_id_index = shape_id_index
	latitude_index = input_csv.fields().indexFromName(latitude_field)
	if latitude_index < 0:
		return "Invalid latitude field"
	longitude_index = input_csv.fields().indexFromName(longitude_field)
	if longitude_index < 0:
		return "Invalid longitude field"
	geometry_types = {
		"Point": QgsWkbTypes.Point,
		"LineString": QgsWkbTypes.LineString,
		"Polygon": QgsWkbTypes.Polygon,
		"MultiPoint": QgsWkbTypes.MultiPoint,
		"MultiLineString": QgsWkbTypes.MultiLineString,
		"MultiPolygon": QgsWkbTypes.MultiPolygon }
	if not geometry_type in geometry_types:
		return "Invalid geometry type: " + geometry_type
	else:
		wkb_type = geometry_types[geometry_type]
	if (geometry_type == "Point"):
	else:
		fields.append(input_csv.fields()[shape_id_index])
	# Assume WGS 84?
	crs.createFromSrid(4326) # WGS 84
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", fields, wkb_type, crs, output_file_format)
	if (outfile.hasError() != QgsVectorFileWriter.NoError):
		return "Failure creating output file: " + str(outfile.errorMessage())
	multi = []
	polyline = []
	shape_count = 0
	current_part_id = False
	current_shape_id = False
		if status_callback and ((row_number % 10) == 0):
					"Node " + str(row_number) + " of " + str(input_csv.featureCount())):
				return "Canceled at node " + str(row_number)
		if (latitude_index >= len(row.attributes())) or (latitude_index >= len(row.attributes())):
			return "Node file missing lat/long at row " + str(row_number + 1)
		point = QgsPointXY(float(row.attributes()[longitude_index]), float(row.attributes()[latitude_index]))
		# Each node is a separate feature in a point file
		if geometry_type == "Point":
			newfeature = QgsFeature()
			newfeature.setAttributes(row.attributes())
			geometry = QgsGeometry.fromPointXY(point)
			newfeature.setGeometry(geometry)
			outfile.addFeature(newfeature)
			shape_count += 1
			continue
		if shape_id_index >= len(row.attributes()):
			return "Node file missing shape ID at row " + str(row_number + 1)
		else:
			row_shape_id = row.attributes()[shape_id_index]
		if part_id_index >= len(row.attributes()):
			return "Node file missing part ID at row " + str(row_number + 1)
		else:
			row_part_id = row.attributes()[part_id_index]
		# First line starts the current feature
		if row_number <= 0:
			current_part_id = row_part_id
			current_shape_id = row_shape_id
		#print("Shape " + str(row_shape_id) + ", Part " + str(row_part_id) + \
		#	", Current shape " + str(current_shape_id) + ", Current part " + str(current_part_id))
		if row_shape_id == current_shape_id:
			if geometry_type == "MultiPoint":
				polyline.append(point)
			elif row_part_id == current_part_id:
			else:
				multi.append(polyline)
				polyline = [point]
			# If adding to an existing shape and not on the last row
			if row_number < (input_csv.featureCount() - 1):
				continue
		# Special case kludge = when the final feature when the last line is a new single point multipoint
		elif (geometry_type == "MultiPoint") and (row_number >= (input_csv.featureCount() - 1)):
			geometry = QgsGeometry.fromMultiPointXY([ point ])
			newfeature.setAttributes([ row_shape_id ])
			shape_count += 1
		if geometry_type == "LineString":
			geometry = QgsGeometry.fromPolylineXY(polyline)
		elif geometry_type == "MultiPoint":
			geometry = QgsGeometry.fromMultiPointXY(polyline)
		elif geometry_type == "MultiLineString":
			if len(polyline) > 0:
			geometry = QgsGeometry.fromMultiPolylineXY(multi)
		elif geometry_type == "MultiPolygon":
			geometry = QgsGeometry.fromMultiPolygonXY([ multi ])
		else: # Polygon
			if len(polyline) < 3:
				return "Polygon with less than 3 nodes at row " + str(index)
			geometry = QgsGeometry.fromPolygonXY([polyline])
		newfeature.setAttributes([ current_shape_id ])
		shape_count += 1
		multi = []
		polyline = [ point ]
	del outfile
	if status_callback:
		status_callback(100, str(shape_count) + " shapes, " + str(input_csv.featureCount()) + " nodes")
	return None
#    mmqgis_grid - Grid shapefile creation
def mmqgis_grid(geometry_type, crs, x_spacing, y_spacing, x_left, y_bottom, x_right, y_top, \
	# Error Checks
	if len(output_file_name) <= 0:
		return "No output filename given"
	if (x_spacing <= 0) or (y_spacing <= 0):
		return "Grid spacing must be positive: " + str(x_spacing) + " x " + str(y_spacing)
	if (x_left >= x_right):
		return "Invalid extent width: " + str(x_left) + " - " + str(x_right)
	if (y_bottom >= y_top):
		return "Invalid extent height: " + str(y_bottom) + " - " + str(y_top)
	if (x_spacing >= (x_right - x_left)):
		return "X spacing too wide for extent: " + str(x_spacing)
	if (y_spacing >= (y_top - y_bottom)):
		return "Y spacing too tall for extent: " + str(y_spacing)
	# Fields containing coordinates
	fields.append(QgsField("left", QVariant.Double))
	fields.append(QgsField("bottom", QVariant.Double))
	fields.append(QgsField("right", QVariant.Double))
	fields.append(QgsField("top", QVariant.Double))
	# Determine shapefile type
	if (geometry_type == "Points") or (geometry_type == "Random Points"):
	elif geometry_type == "Lines":
	elif (geometry_type == "Rectangles") or (geometry_type == "Diamonds") or (geometry_type == "Hexagons"):
	else:
		return "Invalid output shape type: " + str(geometry_type)
	if not output_file_name:
		return "No output file name given"
	file_formats = { ".shp":"ESRI Shapefile", ".geojson":"GeoJSON", ".kml":"KML", ".sqlite":"SQLite", ".gpkg":"GPKG" }
	if os.path.splitext(output_file_name)[1] not in file_formats:
		return "Unsupported output file format: " + str(output_file_name)
	output_file_format = file_formats[os.path.splitext(output_file_name)[1]]
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", fields, geometry_wkb, crs, output_file_format)
	# (column + 1) and (row + 1) calculation is used to maintain
	# topology between adjacent shapes and avoid overlaps/holes
	# due to rounding errors
	rows = int(ceil((y_top - y_bottom) / y_spacing))
	columns = int(ceil((x_right - x_left) / x_spacing))
	feature_count = 0
		for column in range(0, columns + 1):
			for row in range(0, rows + 1):
				x1 = x_left + (column * x_spacing)
				x2 = x_left + ((column + 1) * x_spacing)
				y1 = y_bottom + (row * y_spacing)
				y2 = y_bottom + ((row + 1) * y_spacing)
				# Horizontal line
				if (column < columns):
					line = QgsGeometry.fromPolylineXY([QgsPointXY(x1, y1), QgsPointXY(x2, y1)])
					feature.setGeometry(line)
					feature.setAttributes([x1, y1, x2, y1])
					feature_count = feature_count + 1
				# Vertical line
				if (row < rows):
					line = QgsGeometry.fromPolylineXY([QgsPointXY(x1, y1), QgsPointXY(x1, y2)])
					feature.setAttributes([x1, y1, x1, y2])
	elif geometry_type == "Rectangles":
		for column in range(0, columns):
			for row in range(0, rows):
				polygon = QgsGeometry.fromPolygonXY([[QgsPointXY(x1, y1), QgsPointXY(x2, y1), \
					QgsPointXY(x2, y2), QgsPointXY(x1, y2), QgsPointXY(x1, y1)]])
				feature.setGeometry(polygon)
				feature.setAttributes([x1, y1, x2, y2])
	elif (geometry_type == "Points"):
				x = x_left + (column * x_spacing)
				y = y_bottom + (row * y_spacing)
				point = QgsGeometry.fromPointXY(QgsPointXY(x, y))
				feature.setAttributes([x, y, x, y])
	elif (geometry_type == "Random Points"):
				x = x_left + (column * x_spacing) + (random.random() * x_spacing)
				y = y_bottom + (row * y_spacing) + (random.random() * y_spacing)
	elif geometry_type == "Diamonds":
		for column in range(0, (columns * 2) - 1):
			x1 = x_left + ((column + 0) * (x_spacing / 2))
			x2 = x_left + ((column + 1) * (x_spacing / 2))
			x3 = x_left + ((column + 2) * (x_spacing / 2))
				if (column % 2) == 0:
					y1 = y_bottom + (((row * 2) + 0) * (y_spacing / 2))
					y2 = y_bottom + (((row * 2) + 1) * (y_spacing / 2))
					y3 = y_bottom + (((row * 2) + 2) * (y_spacing / 2))
				else:
					y1 = y_bottom + (((row * 2) + 1) * (y_spacing / 2))
					y2 = y_bottom + (((row * 2) + 2) * (y_spacing / 2))
					y3 = y_bottom + (((row * 2) + 3) * (y_spacing / 2))
				polygon = [[QgsPointXY(x1,  y2), QgsPointXY(x2,  y1), QgsPointXY(x3,  y2), \
					QgsPointXY(x2,  y3), QgsPointXY(x1,  y2)]]
				feature.setAttributes([ x1, y1, x3, y3 ])
	elif geometry_type == "Hexagons":
		# To preserve symmetry, hspacing is fixed relative to vspacing
		xvertexlo = 0.288675134594813 * y_spacing;
		xvertexhi = 0.577350269189626 * y_spacing;
		x_spacing = xvertexlo + xvertexhi
		for column in range(0, int(floor(float(x_right - x_left) / x_spacing))):
			# _topology between adjacent shapes and avoid overlaps/holes
			x1 = x_left + (column * x_spacing)	# far _left
			x2 = x1 + (xvertexhi - xvertexlo)	# _left
			x3 = x_left + ((column + 1) * x_spacing)	# _right
			x4 = x3 + (xvertexhi - xvertexlo)	# far _right
			for row in range(0, int(floor(float(y_top - y_bottom) / y_spacing))):
					y1 = y_bottom + (((row * 2) + 0) * (y_spacing / 2))	# hi
					y2 = y_bottom + (((row * 2) + 1) * (y_spacing / 2))	# mid
					y3 = y_bottom + (((row * 2) + 2) * (y_spacing / 2))	# lo
				else:
					y1 = y_bottom + (((row * 2) + 1) * (y_spacing / 2))	# hi
					y2 = y_bottom + (((row * 2) + 2) * (y_spacing / 2))	# mid
					y3 = y_bottom + (((row * 2) + 3) * (y_spacing / 2))	#lo
				polygon = [[QgsPointXY(x1, y2), QgsPointXY(x2, y1), QgsPointXY(x3, y1),
					QgsPointXY(x4, y2), QgsPointXY(x3, y3), QgsPointXY(x2, y3), QgsPointXY(x1, y2)]]
				feature.setAttributes([ x1, y1, x4, y3 ])
	del outfile
	if status_callback:
		status_callback(100, str(feature_count) + " feature grid")
	return None
#    mmqgis_gridify - Snap shape verticies to grid
def mmqgis_gridify_points(points, horizontal_spacing, vertical_spacing):
	# Align points to grid
	point_count = 0
	deleted_points = 0
	newpoints = []
		point_count += 1
		newpoints.append(QgsPointXY(round(point.x() / horizontal_spacing, 0) * horizontal_spacing, \
				    round(point.y() / vertical_spacing, 0) * vertical_spacing))
	# Delete overlapping points
	z = 0
	while z < (len(newpoints) - 2):
		if newpoints[z] == newpoints[z + 1]:
			newpoints.pop(z + 1)
			deleted_points += 1
		else:
			z += 1
	# Delete line points that go out and return to the same place
	z = 0
	while z < (len(newpoints) - 3):
		if newpoints[z] == newpoints[z + 2]:
			deleted_points += 2
			# Step back to catch arcs
			if (z > 0):
				z -= 1
		else:
			z += 1
	# Delete overlapping start/end points
	while (len(newpoints) > 1) and (newpoints[0] == newpoints[len(newpoints) - 1]):
		newpoints.pop(len(newpoints) - 1)
		deleted_points += 2
	return newpoints, point_count, deleted_points
def mmqgis_gridify_layer(input_layer, horizontal_spacing, vertical_spacing, output_file_name, status_callback = None):
	# Error checks
	if (horizontal_spacing <= 0) or (vertical_spacing <= 0):
		return "Invalid grid spacing: " + str(horizontal_spacing) + "/" + str(vertical_spacing)
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", input_layer.fields(), input_layer.wkbType(), \
	point_count = 0
	deleted_points = 0
			if status_callback(100 * feature_index / input_layer.featureCount(),
				return "Canceled on feature " + str(feature_index) + " of " + str(input_layer.featureCount())
		if not geometry:
			continue;
		if geometry.wkbType() in [QgsWkbTypes.Point, QgsWkbTypes.PointZ, QgsWkbTypes.Point25D]:
			points, added, deleted = mmqgis_gridify_points([geometry.asPoint()], \
			geometry = geometry.fromPointXY(points[0])
			point_count += added
			deleted_points += deleted
		elif geometry.wkbType() in [QgsWkbTypes.LineString, QgsWkbTypes.LineStringZ, QgsWkbTypes.LineString25D]:
			#print "LineString"
			polyline, added, deleted = mmqgis_gridify_points(geometry.asPolyline(), \
			if len(polyline) < 2:
				geometry = None
			else:
				geometry = geometry.fromPolylineXY(polyline)
		elif geometry.wkbType() in [QgsWkbTypes.Polygon, QgsWkbTypes.PolygonZ, QgsWkbTypes.Polygon25D]:
			newpolygon = []
			for polyline in geometry.asPolygonXY():
				newpolyline, added, deleted = mmqgis_gridify_points(polyline, \
				if len(newpolyline) > 1:
					newpolygon.append(newpolyline)
			if len(newpolygon) <= 0:
				geometry = None
			else:
				geometry = geometry.fromPolygonXY(newpolygon)
		elif geometry.wkbType() in [QgsWkbTypes.MultiPoint, QgsWkbTypes.MultiPointZ, QgsWkbTypes.MultiPoint25D]:
			newmultipoints = []
			for index, point in enumerate(geometry.asMultiPoint()):
				# print str(index) + ": " + str(type(point))
				gridded, added, deleted = mmqgis_gridify_points([ point ], \
					horizontal_spacing, vertical_spacing, [ point ])
				# append() causes fail in fromMultiPoint(), extend() doesn't
				newmultipoints.extend(gridded)
			geometry = geometry.fromMultiPointXY(newmultipoints)
		elif geometry.wkbType() in \
			[QgsWkbTypes.MultiLineString, QgsWkbTypes.MultiLineStringZ, QgsWkbTypes.MultiLineString25D]:
			#print "MultiLineString"
			newmultipolyline = []
					newmultipolyline.append(newpolyline)
			if len(newmultipolyline) <= 0:
				geometry = None
			else:
				geometry = geometry.fromMultiPolylineXY(newmultipolyline)
		elif geometry.wkbType() in [QgsWkbTypes.MultiPolygon, QgsWkbTypes.MultiPolygonZ, QgsWkbTypes.MultiPolygon25D]:
			#print "MultiPolygon"
			newmultipolygon = []
			for polygon in geometry.asMultiPolygon():
				newpolygon = []
					if len(newpolyline) > 2:
				if len(newpolygon) > 0:
					newmultipolygon.append(newpolygon)
			if len(newmultipolygon) <= 0:
				geometry = None
			else:
				geometry = geometry.fromMultiPolygonXY(newmultipolygon)
		else:
			return "Unknown geometry type " + QgsWkbTypes.displayString(geometry.wkbType()) + \
				" on feature " + str(feature_index)
		# print "Closing feature"
		if geometry:
			out_feature = QgsFeature()
			out_feature.setGeometry(geometry)
			out_feature.setAttributes(feature.attributes())
			outfile.addFeature(out_feature)
	del outfile
	if status_callback:
		status_callback(100, "Gridify deleted " + str(deleted_points) + " of " + str(point_count) + " points")
	return None
#    mmqgis_hub_distance - Create layer of distances from points to nearest hub
def mmqgis_distance(start, end):
	# Assumes points are WGS 84 lat/long
	# Returns great circle distance in meters
	radius = 6378137 # meters
	flattening = 1/298.257223563
	# Convert to radians with reduced latitudes to compensate
	# for flattening of the earth as in Lambert's formula
	start_lon = start.x() * pi / 180
	start_lat = atan2((1 - flattening) * sin(start.y() * pi / 180), cos(start.y() * pi / 180))
	end_lon = end.x() * pi / 180
	end_lat = atan2((1 - flattening) * sin(end.y() * pi / 180), cos(end.y() * pi / 180))
	# Haversine formula
	arc_distance = (sin((end_lat - start_lat) / 2) ** 2) + \
		(cos(start_lat) * cos(end_lat) * (sin((end_lon - start_lon) / 2) ** 2))
	return 2 * radius * atan2(sqrt(arc_distance), sqrt(1 - arc_distance))
def mmqgis_hub_lines(hub_layer, hub_name_field, spoke_layer, spoke_hub_name_field, \
	allocation_criteria, distance_unit, output_geometry, output_file_name, status_callback = None):
	# Error checks
	if (not spoke_layer) or (spoke_layer.type() != QgsMapLayer.VectorLayer):
		return "Invalid point layer"
	if (not hub_layer) or (hub_layer.type() != QgsMapLayer.VectorLayer):
		return "Invalid hub layer"
	if spoke_layer == hub_layer:
		return "Same layer given for both hubs and spokes"
	hub_name_index = hub_layer.dataProvider().fieldNameIndex(hub_name_field)
	if hub_name_index < 0:
		return "Invalid hub name field: " + hub_name_field
	if spoke_hub_name_field:
		spoke_hub_name_index = spoke_layer.dataProvider().fieldNameIndex(spoke_hub_name_field)
		if spoke_hub_name_index < 0:
			return "Invalid spoke hub name field: " + spoke_hub_name_field
	allocation_options = [ "Nearest Hub", "Hub Name in Spoke Layer", "Evenly Distribute" ]
	if not allocation_criteria in allocation_options:
		return "Invalid allocation criteria"
		return "Invalid output filename given"
	outfields = spoke_layer.fields()
	outfields.append(QgsField("HubName", QVariant.String))
	outfields.append(QgsField("HubDist", QVariant.Double))
	wgs84 = QgsCoordinateReferenceSystem("PROJ4:+proj=longlat +datum=WGS84 +no_defs")
	if output_geometry == "Lines to Hubs":
		geometry_type = QgsWkbTypes.LineString
	elif output_geometry == "Points":
		geometry_type = QgsWkbTypes.Point
	else:
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", outfields, geometry_type, wgs84, output_file_format)
	# Distance calculations using mmqgis_distance() need
	# points in unprojected WGS 84 coordinates
	htransform = QgsCoordinateTransform(hub_layer.crs(), wgs84, QgsProject.instance())
	stransform = QgsCoordinateTransform(spoke_layer.crs(), wgs84, QgsProject.instance())
	# Create array of hubs in memory with WGS84 centroids and hub name
	hubs = [] # point, hub_name
	for index, feature in enumerate(hub_layer.getFeatures()):
		if status_callback and ((index % 100) == 0):
			if status_callback(20, "Reading hub " + str(feature.id())):
				return "Cancelled while reading hubs"
		if not feature.geometry():
			continue
		wgs84_hub = feature.geometry().centroid().asPoint()
		if distance_unit != "Layer Units":
			wgs84_hub = htransform.transform(wgs84_hub)
		hubs.append([wgs84_hub, feature.attributes()[hub_name_index]])
	# Create array of points in memory with WGS84 centroids and attributes
	spokes = [] # point, attributes
	for index, feature in enumerate(spoke_layer.getFeatures()):
			if status_callback(40, "Reading point " + str(feature.id())):
				return "Canceled while reading spokes"
			continue
		wgs84_point = feature.geometry().centroid().asPoint()
			wgs84_point = stransform.transform(wgs84_point)
		spokes.append([wgs84_point, feature.attributes()])
	lines = [] # source_point, hub_point, source_attributes, hub_name, hub_distance (meters)
	if allocation_criteria == "Hub Name in Spoke Layer":
		# Scan spoke spokes
		for spoke_index, spoke in enumerate(spokes):
			if status_callback and ((spoke_index % 5) == 0):
				if status_callback(100 * spoke_index / len(spokes),
						"Spoke " + str(spoke_index) + " of " + str(len(spokes))):
					return "Cancelled at spoke " + str(spoke_index)
			spokeid = str(spoke[1][spoke_hub_name_index])
			# Scan hub spokes to find first matching hub
			for hub in hubs:
				if hub[1] != spokeid:
					continue
				if distance_unit == "Layer Units":
					hub_distance = sqrt(pow(spoke[0].x() - hub[0].x(), 2.0) + \
						pow(spoke[0].y() - hub[0].y(), 2.0))
				else:
					hub_distance = mmqgis_distance(spoke[0], hub[0])
				lines.append([spoke[0], hub[0], spoke[1], hub[1], hub_distance])
				break
	elif allocation_criteria == "Evenly Distribute":
		# Sequentially assign spokes to hubs for even distribution
		for index in range(0, len(spokes)):
			lines.append([spokes[index][0], hubs[index % len(hubs)][0],
				spokes[index][1], hubs[index % len(hubs)][1], 0])
		# Optimize distances by swapping hubs when distance would be shorter for both
		# Arbitrary loop limit of 100 to prevent infinite looping
		for optimizing in range(0, 100):
			swaps = 0
			for x in range(0, len(lines) - 1):
					if status_callback(60, "Optimizing line " + \
							str(x) + " of " + str(len(spokes)) + \
							"(pass " + str(optimizing + 1) + ")"):
						return "Canceled while optimizing lines"
				for y in range(x + 1, len(lines)):
					# Calculate distances with possible point/hub combinations
					xx = sqrt(pow(lines[x][0].x() - lines[x][1].x(), 2) + \
						  pow(lines[x][0].y() - lines[x][1].y(), 2))
					yy = sqrt(pow(lines[y][0].x() - lines[y][1].x(), 2) + \
						  pow(lines[y][0].y() - lines[y][1].y(), 2))
					xy = sqrt(pow(lines[x][0].x() - lines[y][1].x(), 2) + \
						  pow(lines[x][0].y() - lines[y][1].y(), 2))
					yx = sqrt(pow(lines[y][0].x() - lines[x][1].x(), 2) + \
						  pow(lines[y][0].y() - lines[x][1].y(), 2))
					# Swap hubs if that would shorten both lines or overall length is less
					# if ((xy < xx) and (yx < yy)) or ((xy + yx) < (xx + yy)):
					if ((xy + yx) < (xx + yy)):
						hubx = lines[x][1]
						namex = lines[x][3]
						lines[x][1] = lines[y][1]
						lines[x][3] = lines[y][3]
						lines[y][1] = hubx
						lines[y][3] = namex
						swaps = swaps + 1
			# Keep repeating until minimal length has been reached
			if swaps <= 0:
				break
		# Calculate actual distance
		for x in range(0, len(lines)):
				lines[x][4] = sqrt(pow(lines[x][0].x() - lines[x][1].x(), 2.0) + \
					pow(lines[x][0].y() - lines[0][1].y(), 2.0))
			else:
				lines[x][4] = mmqgis_distance(lines[x][0], lines[x][1])
	else: # "Find Closest Hub"
			# Status message
			if status_callback and ((spoke_index % 50) == 0):
				if status_callback(80, "Creating line " + str(spoke_index) + " of " + str(len(spokes))):
					return "Canceled while assigning spokes to hubs"
			# Find closest hub
			closest_index = -1
			closest_distance = 0
			for hub_index, hub in enumerate(hubs):
				else:
				if (closest_index < 0) or (hub_distance < closest_distance):
					closest_index = hub_index
					closest_distance = hub_distance
			# Append to line
			lines.append([spoke[0], hubs[closest_index][0], spoke[1],
				hubs[closest_index][1], closest_distance])
	# Write spokes to file
	for index, line in enumerate(lines):
		# Status message
		if status_callback and ((index % 50) == 0):
			if status_callback(90, "Writing feature " + str(index) + " of " + str(len(lines))):
				return "Canceled while writing features"
		# Convert distance to appropriate output unit
		if distance_unit == "Feet":
			hub_distance = line[4] * 3.2808399
		elif distance_unit == "Miles":
			hub_distance = line[4] / 1609.344
		elif distance_unit == "Nautical Miles":
			hub_distance = line[4] / 1852
		elif distance_unit == "Kilometers":
			hub_distance = line[4] / 1000
		else: # default meters = Euclidian distance in layer units?
		# Create feature
		attributes = line[2]
		attributes.append(line[3])
		attributes.append(hub_distance)
		outfeature = QgsFeature()
		outfeature.setAttributes(attributes)
		if geometry_type == QgsWkbTypes.Point:
			outfeature.setGeometry(QgsGeometry.fromPointXY(line[0]))
		else:
			outfeature.setGeometry(QgsGeometry.fromPolylineXY([line[0], line[1]]))
		outfile.addFeature(outfeature)
	del outfile
	if status_callback:
		status_callback(100, str(len(lines)) + " nodes created")
	return None
#    mmqgis_kml_export - Export attributes to KML file suitable for display in Google Maps
def mmqgis_kml_cdata(value):
	# Converts string to text appropriate for CDATA in KML
	# Chosen over XML entity conversion to avoid unexpected conversion isues
	value = str(value)
	value = value.replace('&', '&')
	value = value.replace('[', '\\[')
	value = value.replace(']', '\\]')
	return value
def mmqgis_kml_export(input_layer, name_field, description, export_data, output_file_name, status_callback = None):
	# Error checks
		return "Invalid input layer"
	name_index = input_layer.dataProvider().fieldNameIndex(name_field)
	if name_index < 0:
		return "Invalid name field: " + name_field
	# Parse description string to find field names
	scan = 0
	descstrings = []
	descattributes = []
	while scan < len(description):
		start = description.find("{{", scan)
		if (start < 0):
			descstrings.append(description[scan:len(description)]);
			descattributes.append(-1)
			break;
		descstrings.append(description[scan:start])
		start = start + 2
		end = description.find("}}", scan)
		if (end < 0):
			return "Unclosed description field name"
		descindex = -1;
		fieldname = description[start:end]
		for index, field in enumerate(input_layer.fields()):
			if (field.name() == fieldname):
				descindex = index;
				break;
		# descindex = input_layer.dataProvider().fieldNameIndex(fieldname)
		if (descindex < 0):
			return "Invalid description attribute: " + fieldname
		descattributes.append(descindex)
		scan = end + 2
	try:
		outfile = io.open(output_file_name, 'w', encoding="utf-8")
		# outfile = sys.stdout
	except:
		return "Failure opening " + output_file_name
	outfile.write(u'<?xml version="1.0" encoding="UTF-8"?>\n')
	outfile.write(u'<kml xmlns="http://earth.google.com/kml/2.2">\n')
	outfile.write(u'<Document>\n')
	# 6/4/2019 - a KML file must have a name or Google Maps will fail the import with no meaningful explanation
	if input_layer.name():
		outfile.write(u'<name>' + str(input_layer.name()) + u'</name>\n')
	else:
		outfile.write(u'<name>' + str(output_file_name) + u'</name>\n')
	#  <description><![CDATA[Test description]]></description>
	# 8/25/2014 startRender()/stopRender() kludge needed so symbolsForFeature() does not crash
	# http://osgeo-org.1560.x6.nabble.com/symbolForFeature-does-not-works-td5149509.html
	renderer = input_layer.renderer()
	render_context = QgsRenderContext()
	renderer.startRender(render_context, input_layer.fields())
	# print str(renderer.dump())
	# Build stylesheet
	stylecount = 0
	symbolcount = len(renderer.symbols(render_context))
	for index, symbol in enumerate(renderer.symbols(render_context)):
		# print u'<Style id="style' + str(index + 1) + u'">'
		outfile.write(u'<Style id="style' + str(index + 1) + u'">\n')
		if symbol.type() == QgsSymbol.Fill:
			outfile.write(u'\t<LineStyle>\n')
			outfile.write(u'\t\t<color>40000000</color>\n')
			outfile.write(u'\t\t<width>3</width>\n')
			outfile.write(u'\t</LineStyle>\n')
			# Opacity can be set in three ways:
			# 1) Symbol color alpha (in the color wheel dialogue) = 0 - 255
			# 2) Symbol opacity (top of the symbology dialogue) = 0 - 1.0
			# 3) Layer rendering opacity (bottom of the symbology dialogue) = 0 - 1.0
			alpha = int(round(symbol.color().alpha() * symbol.opacity() * input_layer.opacity()))
			# KML colors are AABBGGRR
			color = (alpha << 24) + (symbol.color().blue() << 16) + \
				(symbol.color().green() << 8) + symbol.color().red()
			#print("Color = " + str(symbol.color().alpha()) + "/" + str(input_layer.opacity()) + \
			#	"/" + str(symbol.opacity()) + " = " + str(alpha) + \
			#	", " + str(symbol.color().blue()) + ", " + str(symbol.color().green()) + \
			#	", " + str(symbol.color().red()) + " = " + str(format(color, '08x')))
			outfile.write(u'\t<PolyStyle>\n')
			outfile.write(u'\t\t<color>' + str(format(color, '08x')) + u'</color>\n')
			outfile.write(u'\t\t<fill>1</fill>\n')
			outfile.write(u'\t\t<outline>1</outline>\n')
			outfile.write(u'\t</PolyStyle>\n')
		elif symbol.type() == QgsSymbol.Line:
			alpha = int(round(symbol.color().alpha() * input_layer.opacity()))
			outfile.write(u'\t\t<width>5</width>\n')
		else: # Marker
			# Placemarks in Google (tm) maps are images referenced with a URL
			# These are the standard placemark icons used in Google maps
			# red = (color & 0xff0000) >> 16
			# green = (color & 0xff00) >> 8
			# blue = (color & 0xff)
			red = symbol.color().red()
			green = symbol.color().green()
			blue = symbol.color().blue()
			threshold = (min(red, green, blue) + max(red, green, blue)) / 2
			composite = 0
			if red >= threshold:
				composite = composite + 4
			if green >= threshold:
				composite = composite + 2
			if blue >= threshold:
				composite = composite + 1
			# print "rgb(" + str(red) + "," + str(green) + "," + str(blue) + ") = " + str(composite)
			if composite == 0: # black
				icon = 'http://maps.gstatic.com/mapfiles/ms2/micons/blue-dot.png'
			elif composite == 1: # blue
			elif composite == 2: # green
				icon = 'http://maps.gstatic.com/mapfiles/ms2/micons/green-dot.png'
			elif composite == 3: # cyan
				icon = 'http://maps.gstatic.com/mapfiles/ms2/micons/ltblue-dot.png'
			elif composite == 4: # red
				icon = 'http://maps.gstatic.com/mapfiles/ms2/micons/red-dot.png'
			elif composite == 5: # magenta
				icon = 'http://maps.gstatic.com/mapfiles/ms2/micons/pink-dot.png'
			elif composite == 6: # yellow
				icon = 'http://maps.gstatic.com/mapfiles/ms2/micons/yellow-dot.png'
			else: # 7: white
				icon = 'http://maps.gstatic.com/mapfiles/ms2/micons/purple-dot.png'
			outfile.write(u'\t<IconStyle>\n')
			outfile.write(u'\t\t<Icon>\n')
			outfile.write(u'\t\t\t<href>' + str(icon) + u'</href>\n')
			outfile.write(u'\t\t</Icon>\n')
			outfile.write(u'\t</IconStyle>\n')
		# print str(index) + ") " + str(symbol.color().name())
		outfile.write(u'</Style>\n')
	# Transform projection to WGS84 long/lat
	wgs84 = QgsCoordinateReferenceSystem()
	wgs84.createFromProj4("+proj=longlat +datum=WGS84 +no_defs")
	transform = QgsCoordinateTransform(input_layer.crs(), wgs84, QgsProject.instance())
	# Write features to KML
	feature_count = 0
	for featureindex, feature in enumerate(input_layer.getFeatures()):
		# Must have a geometry
		if feature.geometry() == None:
			continue;
		# Find style for feature
		# Some renderers return multiple symbols when QgsFeatureRenderer::Capability == MoreSymbolsPerFeature
		# This uses only the first symbol. Is the second one a default of some kind?!
		style = []
		for symbolsindex, featuresymbol in enumerate(renderer.symbolsForFeature(feature, render_context)):
			# print("  Feature symbol " + str(symbolsindex) + ": " + str(featuresymbol.dump()))
			for renderindex, rendersymbol in enumerate(renderer.symbols(render_context)):
				# print("    Render symbol: " + str(rendersymbol.dump()))
				if featuresymbol.dump() == rendersymbol.dump():
					style = style + ['#style' + str(renderindex + 1)]
					# print("      Render: " + str(style))
					break
		if (len(style) <= 0):
			style = ['#style0']
		# print("Style for " + str(featureindex) + " = " + style[0]);
		# Build name strings for feature
		# name = str(feature.attributes()[name_index].toString())
		# name = str(feature.attributes()[name_index])
		# Name and description strings
		featurename = mmqgis_kml_cdata(feature.attributes()[name_index])
		featuredesc = ""
		for index in range(0, len(descstrings)):
			featuredesc = featuredesc + mmqgis_kml_cdata(descstrings[index])
			fieldindex = descattributes[index]
			if (fieldindex >= 0) and (fieldindex < len(feature.attributes())):
				featuredesc = featuredesc + mmqgis_kml_cdata(feature.attributes()[fieldindex])
		# Placemark header
		outfile.write(u'<Placemark>\n')
		outfile.write(u'<name>' + featurename + u'</name>\n')
		outfile.write(u'<description><![CDATA[' + featuredesc + u']]></description>\n')
		# Optional attribute data
		if export_data:
			outfile.write(u'<ExtendedData>\n')
			for index in range(0, len(feature.fields())):
				name = str(feature.fields().field(index).name())
				value = mmqgis_kml_cdata(feature.attributes()[index])
				outfile.write(u'\t<Data name="' + name + u'"><displayName>' + name +
					u'</displayName><value><![CDATA[' + value + u']]></value></Data>\n')
			outfile.write(u'</ExtendedData>\n')
		# KML always in WGS 84 long/lat
		geometry = feature.geometry()
		geometry.transform(transform)
		# print str(geometry.wkbType()) + ": " + str(geometry.type()) + ": " + name
		# Write features
		if (geometry.wkbType() in [QgsWkbTypes.Point, QgsWkbTypes.PointZ, QgsWkbTypes.Point25D]):
			point = geometry.asPoint()
			outfile.write(u'<styleUrl>' + str(style[0]) + u'</styleUrl>\n')
			outfile.write(u'\t<Point>\n')
			outfile.write(u'\t\t<coordinates>' + str(point.x()) + u',' + \
				str(point.y()) + u',0.000</coordinates>\n')
			outfile.write(u'\t</Point>\n')
		elif (geometry.wkbType() in [QgsWkbTypes.MultiPoint, QgsWkbTypes.MultiPointZ, QgsWkbTypes.MultiPoint25D]):
			for point in geometry.asMultiPoint():
		elif (geometry.wkbType() in [QgsWkbTypes.LineString, QgsWkbTypes.LineStringZ, QgsWkbTypes.LineString25D]):
			outfile.write(u'\t<LineString>\n')
			outfile.write(u'\t\t<tessellate>1</tessellate>\n')
			outfile.write(u'\t\t<coordinates>\n')
			for point in line:
				outfile.write(u'\t\t\t' + str(point.x()) + u',' + \
					str(point.y()) + u',0.000\n')
			outfile.write(u'\t\t</coordinates>\n')
			outfile.write(u'\t</LineString>\n')
		elif (geometry.wkbType() in \
			for line in geometry.asMultiPolyline():
				for point in line:
		elif (geometry.wkbType() in [QgsWkbTypes.Polygon, QgsWkbTypes.PolygonZ, QgsWkbTypes.Polygon25D]):
			polygon = geometry.asPolygon()
			outfile.write(u'\t<Polygon>\n')
			for ringnum, ring in enumerate(polygon):
				if (ringnum == 0):
					outfile.write(u'\t\t<outerBoundaryIs>\n')
				else:
					outfile.write(u'\t\t<innerBoundaryIs>\n')
				outfile.write(u'\t\t\t<LinearRing>\n')
				outfile.write(u'\t\t\t\t<tessellate>1</tessellate>\n')
				outfile.write(u'\t\t\t\t<coordinates>\n')
				for point in ring:
					outfile.write(u'\t\t\t\t\t' + str(point.x()) + u',' + \
				outfile.write(u'\t\t\t\t</coordinates>\n')
				outfile.write(u'\t\t\t</LinearRing>\n')
				if (ringnum == 0):
					outfile.write(u'\t\t</outerBoundaryIs>\n')
				else:
					outfile.write(u'\t\t</innerBoundaryIs>\n')
			outfile.write(u'\t</Polygon>\n')
		elif (geometry.wkbType() in [QgsWkbTypes.MultiPolygon, QgsWkbTypes.MultiPolygonZ, QgsWkbTypes.MultiPolygon25D]):
			outfile.write(u'<MultiGeometry>\n')
					if (ringnum == 0):
					else:
					for point in ring:
						outfile.write(u'\t\t\t\t\t' + str(point.x()) + \
							u',' + str(point.y()) + u',0.000\n')
					if (ringnum == 0):
					else:
			outfile.write(u'</MultiGeometry>\n')
		else:
			return "Unknown geometry type " + str(geometry.wkbType()) +\
				". Use the convert geometry tool to change to point, line, or polygon";
		outfile.write(u'</Placemark>\n\n')
	outfile.write(u'</Document>\n')
	outfile.write(u'</kml>')
	outfile.close()
	renderer.stopRender(render_context)
	if status_callback:
		status_callback(100, str(feature_count) + " KML features")
	return None
#    mmqgis_merge - Merge layers to single shapefile
def mmqgis_merge(input_layers, output_file_name, status_callback = None):
	field_list = []
	total_feature_count = 0
	if not input_layers:
		return "No layers given to merge"
	for layer_index, input_layer in enumerate(input_layers):
		# Verify that all layers are the same type (point, polygon, etc)
		if (layer_index > 0):
			if (input_layer.wkbType() != input_layers[0].wkbType()):
				return "Merged input_layers must all be same type of geometry (" + \
					QgsWkbTypes.displayString(input_layer.wkbType()) + " != " + \
					QgsWkbTypes.displayString(input_layers[0].wkbType()) + ")"
		total_feature_count += input_layer.featureCount()
		# Add any fields not in the composite field list
		for sindex, sfield in enumerate(input_layer.fields()):
			found = None
			for dindex, dfield in enumerate(field_list):
				if (dfield.name().upper() == sfield.name().upper()):
					found = dfield
					if (dfield.type() != sfield.type()):
						# print "Mismatch", dfield.typeName(), sfield.typeName(), input_layername
						field_list[dindex].setType(QVariant.String)
						field_list[dindex].setTypeName("String")
						field_list[dindex].setLength(254)
						field_list[dindex].setPrecision(0)
					break
			if not found:
				field_list.append(QgsField(sfield))
	# Convert field list to structure.
	# Have to do this as a list because fields in structure cannot be
	# modified after appending, and conflicting types need to be converted to string
	for field in field_list:
	# Create the output shapefile
		input_layers[0].wkbType(), input_layers[0].crs(), output_file_format)
	# Copy layer features to output file
	feature_count = 0
	for input_layer in input_layers:
		# print "Layer", str(feature_count)
		for feature in input_layer.getFeatures():
			sattributes = feature.attributes()
			dattributes = []
			for dindex, dfield in enumerate(fields):
				# dattribute = QVariant(dfield.type())
				# print str(dindex) + ": " + str(dfield.type())
				if (dfield.type() in [QVariant.Int, QVariant.UInt, QVariant.LongLong, QVariant.ULongLong]):
					dattribute = 0
				elif (dfield.type() == QVariant.Double):
					dattribute = 0.0
				else:
					dattribute = ""
					if (sfield.name().upper() == dfield.name().upper()):
						if (sfield.type() == dfield.type()):
							dattribute = sattributes[sindex]
						elif (dfield.type() == QVariant.String):
							dattribute = str(sattributes[sindex])
						else:
							return "Attribute " + str(sfield.name()) + \
								" type mismatch " + sfield.typeName() + \
								" != " + dfield.typeName()
						break
				dattributes.append(dattribute)
			#for dindex, dfield in dattributes.items():
			#	print input_layer.name() + " (" + str(dindex) + ") " + str(dfield.toString())
			feature.setAttributes(dattributes)
			outfile.addFeature(feature)
			feature_count += 1
			if status_callback and ((feature_count % 50) == 0):
				if status_callback(100 * feature_count / total_feature_count,
						"Merging " + str(feature_count) + " of " + str(total_feature_count)):
					return "Canceled at feature " + str(feature_count)
	del outfile
	if status_callback:
		status_callback(100, str(feature_count) + " features merged")
	return None
#    mmqgis_sort - Sort layer by attribute
def mmqgis_sort(input_layer, sort_field, sort_direction, output_file_name, status_callback = None):
	sort_index = input_layer.dataProvider().fieldNameIndex(sort_field)
	if sort_index < 0:
		return "Invalid sort field name: " + sort_field
	table = []
	for index, feature in enumerate(input_layer.getFeatures()):
			if status_callback(25, "Reading " + str(feature.id())):
				return "Canceled at feature " + str(feature.id())
		table.append([ feature.id(), feature.attributes()[sort_index] ])
	if status_callback:
		status_callback(50, "Sorting")
	if (sort_direction.lower() == "descending"):
		table.sort(key = operator.itemgetter(1), reverse=True)
	else:
		table.sort(key = operator.itemgetter(1))
	writecount = 0
	for index, record in enumerate(table):
		feature = input_layer.getFeature(record[0])
		writecount += 1
			if status_callback(100 * index / len(table), "Writing " + str(writecount) + " of " + str(len(table))):
				return "Canceled at feature " + str(index)
	del outfile
	if status_callback:
		status_callback(100, str(writecount) + " Features sorted")
	return None
#    mmqgis_spatial_join - Spatial Join
def mmqgis_spatial_join(target_layer, spatial_operation, join_layer, field_names, field_operation, \
	# Error checks
	if (not target_layer) or (target_layer.type() != QgsMapLayer.VectorLayer):
		return "Invalid target layer"
	# Rasters don't have fields()
	if (not hasattr(target_layer, "fields")):
		return "Target layer has no fields (raster layer?)";
	if not spatial_operation in [ "Intersects", "Within", "Contains" ]:
		return "Invalid spatial operation"
	if (not join_layer) or (join_layer.type() != QgsMapLayer.VectorLayer):
		return "Invalid join layer"
	if (not hasattr(join_layer, "fields")):
		return "Join layer has no fields (raster layer?)";
	if len(field_names) != len(set(field_names)):
		return "Duplicate output field names from different layers"
	if not field_operation in ["First", "Sum", "Proportional Sum", "Average", "Weighted Average", "Largest Proportion"]:
		return "Invalid field operation"
	#wgs84 = QgsCoordinateReferenceSystem("PROJ4:+proj=longlat +datum=WGS84 +no_defs")
	#transform = QgsCoordinateTransform(wgs84, azimuthal_equidistant, QgsProject.instance())
	#geometry.transform(transform)
	transform = None
	#print(type(join_layer))
	#print(type(join_layer.crs()))
	if join_layer.crs() != target_layer.crs():
		transform = QgsCoordinateTransform(join_layer.crs(), target_layer.crs(), QgsProject.instance())
	# Build composite field list
	field_info = [] # [ layer, index, QgsField ]
	newfields = QgsFields()
	for index, field in enumerate(target_layer.fields()):
		if field.name() in field_names:
			newfields.append(field)
			field_info.append([target_layer, index, field])
			# print str(len(field_info) - 1) + " = " + field.name()
	# Add fields from join features
	for index, field in enumerate(join_layer.fields()):
			if target_layer.dataProvider().fieldNameIndex(field.name()) >= 0:
				return "Ambiguous field name in both target and join layers: " + field.name()
			# INT fields converted to DOUBLE to avoid overflow and rounding errors
			# 12/28/2016: LongLong types needed for 64-bit Windows shapefiles.
			# Precision kludge to avoid bogus OGR shapefile input precision zero,
			# which would result in conversion to int on write
			if (field.type() in [ QVariant.Int, QVariant.LongLong, \
					QVariant.UInt, QVariant.ULongLong, QVariant.Double ]):
				field = QgsField(field.name(), QVariant.Double, "Double", 12, 4)
			field_info.append([join_layer, index, field])
			# print str(len(field_info) - 1) + " = " + field.name() + " " + str(field.type())
	# Add field to count number of joined features
	count_field = QgsField("COUNT", QVariant.Int)
	newfields.append(count_field)
	field_info.append([None, 0, count_field])
	# Open file (delete any existing)
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", newfields, \
		target_layer.wkbType(), target_layer.crs(), output_file_format)
	# Interate through target features
	total_joins = 0
	target_count = 0
	feature_count = target_layer.featureCount()
	for target_index, target_feature in enumerate(target_layer.getFeatures()):
		if status_callback and ((target_index % 10) == 0):
			status_callback(100 * target_index / target_layer.featureCount(),
				"Joining " + str(target_index) + " of " + str(target_layer.featureCount()))
		target_geometry = target_feature.geometry()
		# Copy all selected target attributes
		attributes = []
		for fieldlayer, fieldindex, field in field_info:
			if fieldlayer == target_layer:
				attributes.append(target_feature.attributes()[fieldindex])
			elif fieldlayer == join_layer:
				attributes.append(None)
			else:
				attributes.append(0) # count
		# Iterate through join features
		join_count = 0
		last_join_area = 0 # to keep track of feature with largest intersection area
		for join_index, join_feature in enumerate(join_layer.getFeatures()):
			# Get the geometry of the join feature
			join_geometry = join_feature.geometry()
			if transform:
				join_geometry.transform(transform)
			# print("\tTest: " + str(target_index) + " -> " + str(join_index))
			# Only analyze features that meet spatial join criteria
			if ((spatial_operation == 'Intersects') and (not target_geometry.intersects(join_geometry))) or \
			   ((spatial_operation == 'Within') and (not target_geometry.within(join_geometry))) or \
			   ((spatial_operation == 'Contains') and (not target_geometry.contains(join_geometry))):
				continue
			# print("\t\tMatch: " + str(target_index) + " -> " + str(join_index) + " = " + str(total_joins))
			# The count of joined features is added as an attribute, and used for averaging
			join_count = join_count + 1
			total_joins = total_joins + 1
			# If you only need the first matching feature, there is no need to test other features
			if (field_operation == "First"):
				for dest_index, field in enumerate(field_info):
					if field[0] == join_layer:
						attribute = join_feature.attributes()[field[1]]
						attributes[dest_index] = attribute
				break
			# Calculate areas
			join_area = join_geometry.area()
			target_area = target_geometry.area()
			intersect_area = target_geometry.intersection(join_geometry).area()
			# For each field
				# Only process fields selected for joining
				if field[0] != join_layer:
					continue
				# Join this field if the match is larger than any previous match
				if field_operation == "Largest Proportion":
					if last_join_area <= intersect_area:
						last_join_area = intersect_area
					continue
				# Non-real fields can only be copied, not proportionately summed or averaged
				if (field[2].type() != QVariant.Double):
					if join_count == 1:
					continue
				# Ratios for summing when doing proportional operations
				ratio = 1.0
				if (field_operation == "Proportional Sum"):
					if (join_area > 0):
						ratio = intersect_area / join_area
				elif (field_operation == "Weighted Average"):
					if (target_area > 0):
						ratio = intersect_area / target_area
				# Sum the values
				try:
					if join_count <= 1:
						target_value = 0
					else:
						target_value = float(attributes[dest_index])
					join_value = float(join_feature.attributes()[field[1]])
					attributes[dest_index] = target_value + (ratio * join_value)
					# print "Join " + str(attributes[dest_index]) + " = " + \
					#	str(target_value) + " + (" + str(ratio) + \
					#	" * " + str(join_value) + ")"
				except:
					attributes[dest_index] = 0
				# print str(target_index) + ":" + str(join_index) + ") " + \
				#	str(target_value) + " + " + str(join_value) + " * " + \
				#	str(ratio)
		# Divide sums to get averages
		if (field_operation == "Average") and (join_count > 0):
				if (field[0] == join_layer) and (field[2].type() == QVariant.Double):
					attributes[dest_index] = float(attributes[dest_index]) / float(join_count)
		# Counter
		attributes[len(field_info) - 1] = join_count
		# print "Join count(" + str(len(field_info) - 1) + "): " + str(join_count)
		# Add the feature
		# if join_count > 0:
		target_count = target_count + 1
		newfeature.setGeometry(target_feature.geometry())
		newfeature.setAttributes(attributes)
		# print str(target_count) + ") " + str(attributes[0].toString())
		if not outfile.addFeature(newfeature):
			return "Failure writing feature to output"
	del outfile
	if status_callback:
		status_callback(100, str(total_joins) + " features joined to " + str(target_count) + " output features")
	return None
#    mmqgis_text_to_float - Change text fields to numbers
def mmqgis_text_to_float(input_layer, field_names, output_file_name, status_callback = None):
	# Error checks
	# Build list of fields with selected fields changed to floating point
	changecount = 0
	destfields = QgsFields()
	field_changed = []
		if (field.name() in field_names) and ((field.type() == QVariant.String) or (field.type() == QVariant.Int)):
			field_changed.append(True)
			# Arbitrary floating point length/precision 14.6 = nnnnnnnnnnnnnn.dddddd
			destfields.append(QgsField (field.name(), QVariant.Double, field.typeName(), \
				14, 6, field.comment()))
			changecount += 1
		else:
			field_changed.append(False)
			destfields.append(QgsField (field.name(), field.type(), field.typeName(), \
				field.length(), field.precision(), field.comment()))
	if (changecount <= 0):
		return "No string or integer fields selected for conversion to floating point"
	# Create the output file
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", destfields, input_layer.wkbType(), input_layer.crs(), \
		output_file_format)
	# Write the features with modified field_names
	feature_count = input_layer.featureCount();
		if status_callback and ((feature_index % 50) == 0):
			status_callback(100 * feature_index / input_layer.featureCount(), \
		new_values = []
		for field_index, field in enumerate(input_layer.fields()):
			if not field_changed[field_index]:
				new_values.append(feature.attribute(field_index))
				continue
			string = str(feature.attribute(field_index))
			multiplier = 1.0
			if string.find("%") >= 0:
				multiplier = 1 / 100.0
				string = string.replace("%", "")
			if string.find(",") >= 0:
				string = string.replace(",", "")
			string = string.replace(" ", "")
			start = 0
			while (start < len(string)) and (string[start] not in "0123456789."):
				start = start + 1
			end = start
			while (end < len(string)) and (string[end] in "0123456789."):
				end = end + 1
			if (start < len(string)) or (start < end):
				string = string[start:end]
			else:
				string = "0"
			try:
				value = float(string) * multiplier
			except:
				value = 0
			new_values.append(value)
		feature.setAttributes(new_values)
	del outfile
	if status_callback:
		status_callback(100, str(len(field_names)) + " fields, " + str(input_layer.featureCount()) + " features")
	return None
#    mmqgis_voronoi - Voronoi diagram creation
class mmqgis_voronoi_line:
	def __init__(self, x, y):
		self.x = x
		self.y = y
		self.angle = 0
		self.distance = 0
	def list(self, title):
		print(title + ", " + str(self.x) + ", " + str(self.y) + \
			", angle " + str(self.angle * 180 / pi) + ", distance " + str(self.distance))
	def angleval(self):
		return self.angle
def mmqgis_voronoi_diagram(input_layer, output_file_name, status_callback = None):
	# Error checks
	outfile = QgsVectorFileWriter(output_file_name, "utf-8", input_layer.fields(), \
			QgsWkbTypes.Polygon, input_layer.crs(), output_file_format)
	points = []
	xmin = 0
	xmax = 0
	ymin = 0
	ymax = 0
		# Re-read by feature ID because nextFeature() doesn't always seem to read attributes
		# input_layer.featureAtId(feature.id(), feature)
		if status_callback:
			status_callback(0, "Feature " + str(feature.id()) + " of " + str(input_layer.featureCount()))
		# print str(feature.id()) + ": " + str(geometry.wkbType())
		if geometry.wkbType() == QgsWkbTypes.Point:
			points.append( (geometry.asPoint().x(), geometry.asPoint().y(), feature.attributes()) )
			if (len(points) <= 1) or (xmin > geometry.asPoint().x()):
				xmin = geometry.asPoint().x()
			if (len(points) <= 1) or (xmax < geometry.asPoint().x()):
				xmax = geometry.asPoint().x()
			if (len(points) <= 1) or (ymin > geometry.asPoint().y()):
				ymin = geometry.asPoint().y()
			if (len(points) <= 1) or (ymax < geometry.asPoint().y()):
				ymax = geometry.asPoint().y()
	if (len(points) < 3):
		return "Too few points to create diagram"
	for point_number, center in enumerate(points):
	# for center in [ points[17] ]:
		# print "\nCenter, " + str(center[0]) + ", " + str(center[1])
		if (point_number % 20) == 0:
			#status_callback("Processing point " + \
			#	str(center[0]) + ", " + str(center[1]))
			status_callback(100 * point_number / len(points),
				"Point " + str(point_number) + " of " + str(len(points)))
		# Borders are tangents to midpoints between all neighbors
		tangents = []
		for neighbor in points:
			border = mmqgis_voronoi_line((center[0] + neighbor[0]) / 2.0, (center[1] + neighbor[1]) / 2.0)
			if ((neighbor[0] != center[0]) or (neighbor[1] != center[1])):
				tangents.append(border)
		# Add edge intersections to clip to extent of points
		offset = (xmax - xmin) * 0.01
		tangents.append(mmqgis_voronoi_line(xmax + offset, center[1]))
		tangents.append(mmqgis_voronoi_line(center[0], ymax + offset))
		tangents.append(mmqgis_voronoi_line(xmin - offset, center[1]))
		tangents.append(mmqgis_voronoi_line(center[0], ymin - offset))
		#print "Extent x = " + str(xmax) + " -> " + str(xmin) + ", y = " + str(ymax) + " -> " + str(ymin)
		# Find vector distance and angle to border from center point
		for scan in range(0, len(tangents)):
			run = tangents[scan].x - center[0]
			rise = tangents[scan].y - center[1]
			tangents[scan].distance = sqrt((run * run) + (rise * rise))
			if (tangents[scan].distance <= 0):
				tangents[scan].angle = 0
			elif (tangents[scan].y >= center[1]):
				tangents[scan].angle = acos(run / tangents[scan].distance)
			elif (tangents[scan].y < center[1]):
				tangents[scan].angle = (2 * pi) - acos(run / tangents[scan].distance)
			elif (tangents[scan].x > center[0]):
				tangents[scan].angle = pi / 2.0
			else:
				tangents[scan].angle = 3 * pi / 4
			#print "  Tangent, " + str(tangents[scan].x) + ", " + str(tangents[scan].y) + \
			#	", angle " + str(tangents[scan].angle * 180 / pi) + ", distance " + \
			#	str(tangents[scan].distance)
		# Find the closest line - guaranteed to be a border
		closest = -1
			if ((closest == -1) or (tangents[scan].distance < tangents[closest].distance)):
				closest = scan
		# Use closest as the first border
		border = mmqgis_voronoi_line(tangents[closest].x, tangents[closest].y)
		border.angle = tangents[closest].angle
		border.distance = tangents[closest].distance
		borders = [ border ]
		#print "  Border 0) " + str(closest) + " of " + str(len(tangents)) + ", " \
		#	+ str(border.x) + ", " + str(border.y) \
		#	+ ", (angle " + str(border.angle * 180 / pi) + ", distance " \
		#	+ str(border.distance) + ")"
		# Work around the tangents in a CCW circle
		circling = 1
		while circling:
			next = -1
			scan = 0
			while (scan < len(tangents)):
				anglebetween = tangents[scan].angle - borders[len(borders) - 1].angle
				if (anglebetween < 0):
					anglebetween += (2 * pi)
				elif (anglebetween > (2 * pi)):
					anglebetween -= (2 * pi)
				#print "    Scanning " + str(scan) + " of " + str(len(borders)) + \
				#	", " + str(tangents[scan].x) + ", " + str(tangents[scan].y) + \
				#	", angle " + str(tangents[scan].angle * 180 / pi) + \
				#	", anglebetween " + str(anglebetween * 180 / pi)
				# If border intersects to the left
				if (anglebetween < pi) and (anglebetween > 0):
					# A typo here with a reversed slash cost 8/13/2009 debugging
					tangents[scan].iangle = atan2( (tangents[scan].distance /
						borders[len(borders) - 1].distance) \
						- cos(anglebetween), sin(anglebetween))
					tangents[scan].idistance = borders[len(borders) - 1].distance \
						/ cos(tangents[scan].iangle)
					tangents[scan].iangle += borders[len(borders) - 1].angle
					# If the rightmost intersection so far, it's a candidate for next border
					if (next < 0) or (tangents[scan].iangle < tangents[next].iangle):
						# print "      Take idistance " + str(tangents[scan].idistance)
						next = scan
				scan += 1
			# iangle/distance are for intersection of border with next border
			borders[len(borders) - 1].iangle = tangents[next].iangle
			borders[len(borders) - 1].idistance = tangents[next].idistance
			# Stop circling if back to the beginning
			if (borders[0].x == tangents[next].x) and (borders[0].y == tangents[next].y):
				circling = 0
			else:
				# Add the next border
				border = mmqgis_voronoi_line(tangents[next].x, tangents[next].y)
				border.angle = tangents[next].angle
				border.distance = tangents[next].distance
				border.iangle = tangents[next].iangle
				border.idistance = tangents[next].idistance
				borders.append(border)
				#print "  Border " + str(len(borders) - 1) + \
				#	") " + str(next) + ", " + str(border.x) + \
				#	", " + str(border.y) + ", angle " + str(border.angle * 180 / pi) +\
				#	", iangle " + str(border.iangle * 180 / pi) +\
				#	", idistance " + str(border.idistance) + "\n"
			# Remove the border from the list so not repeated
			tangents.pop(next)
			if (len(tangents) <= 0):
				circling = 0
		polygon = []
		if len(borders) >= 3:
			for border in borders:
				ix = center[0] + (border.idistance * cos(border.iangle))
				iy = center[1] + (border.idistance * sin(border.iangle))
				#print "  Node, " + str(ix) + ", " + str(iy) + \
				#	", angle " + str(border.angle * 180 / pi) + \
				#	", iangle " + str(border.iangle * 180 / pi) + \
				#	", idistance " + str(border.idistance) + ", from " \
				polygon.append(QgsPointXY(ix, iy))
			#print "Polygon " + str(point_number)
			#for x in range(0, len(polygon)):
			#	print "  Point " + str(polygon[x].x()) + ", " + str(polygon[x].y())
			# Remove duplicate nodes
			# Compare as strings (str) to avoid odd precision discrepancies
			# that sometimes cause duplicate points to be unrecognized
			dup = 0
			while (dup < (len(polygon) - 1)):
				if (str(polygon[dup].x()) == str(polygon[dup + 1].x())) and \
				   (str(polygon[dup].y()) == str(polygon[dup + 1].y())):
					polygon.pop(dup)
					# print "  Removed duplicate node " + str(dup) + \
					#	" in polygon " + str(point_number)
				else:
					# print "  " + str(polygon[dup].x()) + ", " + \
					#	str(polygon[dup].y()) + " != " + \
					#	str(polygon[dup + 1].x()) + ", " + \
					#	str(polygon[dup + 1].y())
					dup = dup + 1
			# attributes = { 0:QVariant(center[0]), 1:QVariant(center[1]) }
		if len(polygon) >= 3:
			geometry = QgsGeometry.fromPolygonXY([ polygon ])
			feature.setAttributes(center[2])
	del outfile
	if status_callback:
		status_callback(100, "Created " + str(len(points)) + " polygons")
	return None
More information about the QGIS-User mailing list
