[Qgis-user] MMQGIS - Reverse geocoding -REQUEST_DENIED
Greg Troxel gdt at lexort.com
Fri Sep 20 08:26:26 PDT 2024
krishna Ayyala via QGIS-User <qgis-user at lists.osgeo.org> writes:
> In continuation to the below email, I wish to add that, the keys are good.
> Just purchased. Still getting the same error. REQUEST_DENIED. Tried on a
> different computer. Getting the same error. My qgis version is 3.28. If
> this error cannot be rectified, Is there an alternate plugin that can use
> google API key for reverse geocoding.The reason is; I am trying to reverse
> geocode using google only. Or is there a simple way to rectify the error?
> When you get a chance, can you please reply.
You got advice to make a manual request for a URL from Keith.  You did
not clearly present what happened when you tried that.  It really seems
like you need support from google, not from the qgis user community.
And, because this is a proprietary service requiring signing up and
paying, and because you didn't publish your API key to the list :-),
most of us can't just check if it works for us.
So, as Keith very helpfully said:
  https://maps.googleapis.com/maps/api/geocode/json?latlng=40.0262,-75.0301&key={your_api_key}
and use curl or wget. If you can't make that work, then you need
help from google.  Only if manual requests work and qgis does not, does
it make sense to ask for help here.
More information about the QGIS-User mailing list
