[Qgis-user] MMQGIS - Reverse geocoding -REQUEST_DENIED
krishna Ayyala
ayyalakrishna at gmail.com
Fri Sep 20 10:27:56 PDT 2024
Thank you Greg. Figured it out and renewed the subscription with google.
Now the API key is working.
Thank you and Regards
On Fri, Sep 20, 2024 at 9:26 AM Greg Troxel via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> krishna Ayyala via QGIS-User <qgis-user at lists.osgeo.org> writes:
> > In continuation to the below email, I wish to add that, the keys are
> good.
> > Just purchased. Still getting the same error. REQUEST_DENIED. Tried on a
> > different computer. Getting the same error. My qgis version is 3.28. If
> > this error cannot be rectified, Is there an alternate plugin that can use
> > google API key for reverse geocoding.The reason is; I am trying to
> reverse
> > geocode using google only. Or is there a simple way to rectify the error?
> > When you get a chance, can you please reply.
> You got advice to make a manual request for a URL from Keith. You did
> not clearly present what happened when you tried that. It really seems
> like you need support from google, not from the qgis user community.
> And, because this is a proprietary service requiring signing up and
> paying, and because you didn't publish your API key to the list :-),
> most of us can't just check if it works for us.
> So, as Keith very helpfully said:
> https://maps.googleapis.com/maps/api/geocode/json?latlng=40.0262,-75.0301&key={your_api_key}
> and use curl or wget. If you can't make that work, then you need
> help from google. Only if manual requests work and qgis does not, does
> it make sense to ask for help here.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240920/bfee4085/attachment.htm>
More information about the QGIS-User
