[Qgis-user] Unable to open MrSID file in QGIS even if gdalinfo can read it
Even Rouault
even.rouault at spatialys.com
Sat Sep 28 10:33:34 PDT 2024
Andrew,
> $ ldd /bin/qgis.bin | grep gdal
> libgdal.so.34 => /lib/x86_64-linux-gnu/libgdal.so.34 (0x00007a0581a00000)
> But I'm not sure what to do with that information.
/lib/x86_64-linux-gnu/libgdal.so.34 is the version of GDAL that comes
with package manager, so 3.8.4 here
I'm not sure how you are familiar with the dynamic linking concepts and
tools, but if you're not, reading
https://opensource.com/article/22/5/dynamic-linking-modular-libraries-linux
or related resources on dynamic linking might help you understand why
those seemlingly "weird" behaviors are totally explainable. Takes time,
and even with experience, mixing up several versions of a library on a
system and being confused is not uncommon
I'm going to hate myself for the below suggestion, and you probably too
when it will hit you back in the face (so forget I've told you about it
;-), ... but ... to quickly workaround your issue, you can do:
sudo ln -s /usr/lib/libgdal.so.35 /usr/lib/libgdal.so.34 # i'm
already hating myself
sudo mv /lib/x86_64-linux-gnu/libgdal.so.34
/lib/x86_64-linux-gnu/libgdal.so.34.disabled # I'm hating myself even
more...
And now launch QGIS.... As GDAL keeps a backwards compatible C ABI, this
ugly substitution of the expected GDAL 3.8.4 version at build time is
supposed to (mostly) work. That said, you might run in occasional bugs,
where QGIS tries to workaround GDAL specific bug, based on the version
of GDAL QGIS was built against...
OK, I believe you've been sufficienly warned this is *not* the normal
way of proceeding, just a quick&dirty workaround
To undo the above mess:
sudo mv /lib/x86_64-linux-gnu/libgdal.so.34.disabled
sudo mv /usr/lib/libgdal.so.34 /usr/lib/libgdal.so.34.disabled (i'm
always nervous doing a rm in /usr territory, so I tend to just rename ...)
The clean solution would be that you rebuild QGIS against your installed
GDAL, but that would be for another episode. Another friendly advice
would be that when doing a custom build you don't do
CMAKE_INSTALL_PREFIX=/opt , but here something like
CMAKE_INSTALL_PREFIX=/opt/gdal_3_10_master to avoid messing with /usr
which should be only the territory of your package manager tool.
Another less ugly alternative would be that you download
http://download.osgeo.org/gdal/3.8.4/gdal-3.8.4.tar.gz, build it with
support of the MrSID driver as a plugin, with
-DGDAL_ENABLE_DRIVER_MRSID_PLUGIN=ON, install it in /opt/gdal_3_8_4, and
then just set the GDAL_DRIVER_PATH=/opt/gdal_3_8_4/lib/gdalplugins
environment variable. That way you would use the system GDAL library
with just the addition of the MrSID driver.
Actually that might not be terribly harder to do than my above hacks, so
I'm definitely encouraging you to explore that way
And ... you should know that the company behind the MrSID SDK has
declared they won't ever release any new binary version of it. This
means that at most in a few years, this SDK will likely be totally
unusable on modern systems. So everyone using SID files had better
convert them to something else, like COG, when they still have a chance...
/me taking a passport to an undisclosed country without extradition
agreement.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240928/bcf7f3ba/attachment.htm>
More information about the QGIS-User
