[Qgis-user] Tools for point cloud fil
Andrea Giudiceandrea
andreaerdna at libero.it
Mon Sep 30 10:34:38 PDT 2024
Hi Pierre,
you need to install and use a QGIS distribution that is built against a
PDAL library version >= 2.5.0.
It is not sufficient to somehow install PDAL somewhere on your system
and use a QGIS distribution that is not build against such PDAL version.
So, if you want to use QGIS distributed by MacPorts, then you need to
install QGIS from MacPorts and use QGIS installed from MacPorts [1].
Regards.
Andrea
[1] https://qgis.org/resources/installation-guide/#macports
Il 30/09/2024 16:17, pierreboivin ha scritto:
> Hello Andrea
> I followed your recommendations:
> I downloaded MacPorts
> I installed Xcode 14.2, which was necessary
> Then I was able to install PDAL with Ports
> Everything seems to have gone well
> ... but when I open a point cloud file with QGis I don't have the desired processing tools
> What can I do?
More information about the QGIS-User
