[Qgis-user] FW: "Phantom" point in created layer
Abdou SENE / Geo - Tech - Dev seneabdou460 at gmail.com
Thu Apr 3 06:23:29 PDT 2025
Hi Nora and all,
I struggled sometimes with a similar problem but didn't know that the
phantom points was plotted at lat/long (0.0).
I knew that they didn't have valid geometry.
I guessed that it happened when I use a shapefile and deleted some points
during in editing mode (using backspace). I think, it deletes the geometry
only, but not the (line in attribute table).
Can you try this ?
Thanks
On Thu, Apr 3, 2025, 09:00 Nora Badenhorst via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi Tobias,
> Hope you are well?
> Thanks for the feedback.
> I have created a NEW shapefile for each of my areas.
> Attached find one of these layers. It was created (geometry type: points)
> and saved. I then "edited" the layer and adding points using "add pint
> feature"
> When realising that there were "phantom" points, I selected the visible
> points and saved it as a new layer.
> I do not use GeoPackage as as layers but will definitely try it in future.
> Thanks again - have a great day.
> Nôra Badenhorst
> RESEARCH ASSISTANT AND OFFICE ADMINISTRATOR
> nôrabadenhorst at nova.org.za
> +27 (0) 72 146 3633
> Office 1, Aura Aesta Building, 2 Witteboom Street, Hartenbos
> <https://www.google.com/maps/search/2+Witteboom+Street,+Hartenbos?entry=gmail&source=g>
> 6520
> nova.org.za
> Quality of life
> begins at home
> -----Original Message-----
> From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Tobias
> Schula via QGIS-User
> Sent: Wednesday, 02 April 2025 14:46
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] FW: "Phantom" point in created layer
> > I created a shapefile layer
> This seems to be the culprit. Did you create the shapefile specifically
> and newly in QGIS, or did you reuse some old shapefile where you just
> deleted features? Shape is a brittle format and can easily get corrupted,
> especially if different apps and programs got their hands on the same file.
> QGIS always had bugs with shapefiles, e.g. this one:
> > https://github.com/qgis/QGIS/issues/19349
> I don't work with shapefiles at all anymore, I just treat them as data-
> interchange format. If you receive a shapefile, import it into geopackage,
> spatialite or postgis, when your done editing, export it again as a new
> shapefile. Saved me a lot of headaches.
> Export your points in a temporary scratch layer that you then save as a
> new shapefile under a new name, so QGIS won't use the old sidecars anymore.
> Try editing the "new" shapefile and see if the error persists.
> Try to create a completely new shapefile with the same columns and see if
> the error persists, try to save your shapefile into a different format and
> continue editing the new format. I highly suspect the shapefile is broken
> and thus creates phantom/mystery geometries.
> Do you have any other layers joined or connected to the offending layer?
> It could be that the creation of a point triggers further action. What are
> your settings in Layer > Layer Properties. , tabs "Actions" and "Attributes
> Form"?
> Do you have an expression saved somewhere as an automatic input field?
> I had similar problems with mystery points added in QField, no more
> problems since only using geopackage. I also tried to recreate your
> problem, but my newly created shapefile layer only shows the points I
> added. Can you share your shape with us, or does it have confidential data?
> Best Regards
> Tobias A Schula
> Forestry Expert
> geospatial at schula.org
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250403/7c6d6e7a/attachment.htm>
More information about the QGIS-User mailing list
